Old 04-02-2013, 10:46 PM   #1
jsteuer23
Member#: 294173
2002 wrx
Default 2002 wrx front subframe removal
Hey guys has any changed out their front subframe? the stealership wants a fortune to do it. The main thing I'm afraid of breaking a bolt off. Any help would be appreciated.
jsteuer23 is offline   Reply With Quote
Old 04-02-2013, 10:49 PM   #2
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I don't think you are strong enough to break a bolt off unless they are completely rusted. Bolts on the subframe are pretty large.
Old 04-02-2013, 10:56 PM   #3
jsteuer23
Member#: 294173
2002 wrx
even if it is rusted out bad?
Old 04-02-2013, 11:02 PM   #4
id get some liquid wrench(i like it better than pb blaster) and spray them all down from the top....and wait and spray them again...and get an impact and have at it
sometimes ya gotta rock them..in and out several times to get them to come out
Old 04-02-2013, 11:41 PM   #5
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
Like scotty said use some sort of penetrating oil, some of the bolts can be accessed from above the subframe, allowing you to spray the threads letting the oil work its way down into the threads.
The bolts are mostly large and you would need a huge breaker bar to snap them, its highly unlikely they will break after letting them soak in liquid wrench.
2gnt2wrx is offline   Reply With Quote
Old 04-03-2013, 12:02 AM   #6
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
The subframe gets rusted out pretty bad in the snow belt.
If a bolt breaks off, you use an EZ-OUT and re-tap / chase the hole while you drive around without a subframe for a while while your stainless bolts ship in from Fastenal. Then you install them with anti-seize so that doesn't happen again... Even paying for the EZ-OUT, taps and stainless bolts... it's cheaper than the dealer AND next time you'll actually be able to remove the bolts.
Old 04-03-2013, 12:10 AM   #7
ogboot
Member#: 170906
psm
Love it.
ogboot is online now   Reply With Quote
Old 04-03-2013, 10:54 PM   #8
jsteuer23
Member#: 294173
2002 wrx
thanks for all the help guys ill give the liquid wrench a try
Old 04-04-2013, 01:10 AM   #9
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
Yeah, and if you manage to break one off the dealer would have broken it too. Then charged you more to replace it.
bushflyr is offline   Reply With Quote
Old 04-04-2013, 10:55 AM   #10
Member#: 301037
2004 Forester XT
It is a pretty straight forward removal. You will need a 12mm,14mm and 19mm. If it is the first time they have been off you will likely need a breaker bar or impact to get them off.
art@grimmspeed is offline   Reply With Quote
Old 04-04-2013, 02:36 PM   #11
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I hate cars from the east but when I do work on them its time for the penetrating oil. Give it plenty of time to work before you try to remove the bolts. Good luck on that.
