Old 04-01-2013, 04:33 AM   #1
danci1973
Member#: 19018
1995 Legacy Wagon
Default Replacement ECU question - A/T vs. M/T
My car recently developed a P0607 (link to my post about it) issue and reading through many forums and posts it seems sometimes the cause was the ECU going south.
If I was 100% sure that was my case too, I'd just get a new ECU and be done with it. But since it's not 100% and a new ECU costs serious money, I'm on the lookout for a used one.
I could only find two on eBay right now and one seems to be a perfect fit - the donor car is almost exactly like mine - except it's a RHD. However, the seller doesn't ship to my country and he still didn't respond to my question about it.
The other one is from a sedan that had an automatic transmission - while my car is a wagon with dual-range manual gearbox...
My car VIN: JF1BP5LM46G
The donor car VIN: JF1BL5LS56G
I also asked a local dealer to check the part number for the ECU (or UNIT ASSEMBLY - E.G.I. CONTROL) based on the VIN and my car's part # is 22611AK772 while the donor car's part # is 22611AK771 (even though the photo of the donor ECU clearly shows the 22611AK772)...
So I basically have two questions:
A - Should the donor ECU work normally in my car?
B - Can I have two ECU's 'mated' to my immobiliser so I can swap back and forth as I please?
Thanks,
Danilo
danci1973 is offline   Reply With Quote
Old 04-02-2013, 08:11 AM   #2
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
A) don't know.
B) yes, the immobilizer is just a 4 digit code that can be changed with any tuning software.
Cathexis is offline   Reply With Quote
Old 04-02-2013, 08:54 AM   #3
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
You would need help getting the memory space defined for open source tuning to modify the immobilzer code. Once defined it should work just like Evo ECUs(where you can override the immobilizer or effectively disable it). You would need to define and record the immobilizer code from your old ECU, and put that into the new ECU. I dont know if you will want to use an AT ecu in your MT car though. That doesnt seem like a smart move but that is just based on speculation.
You may have better luck asking in the subaru conversion area as well.
endrswrd is offline   Reply With Quote
Old 04-02-2013, 08:14 PM   #4
arangov3
Member#: 278414
a- yes but after you get your immobilizer to work you have to understand that AT fuel maps are different then MT because of the transmissions 1 less gear
b-yes(what they said^)
arangov3 is offline   Reply With Quote
Old 04-03-2013, 04:13 AM   #5
danci1973
Member#: 19018
1995 Legacy Wagon
Thank you all.
So - if Tactrix manages to get the OpenPort 2.0 / EcuFlash working with my ECU (which they promised it does) I'm good to go with the AT ECU and re-flash it with the ROM of my current MT ECU.
Sweet.
D.
PS: The P0607 mysteriously cleared itself - about 2 hours after checking all the wires between the TB and ECU it just went away.
