Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 04-03-2013, 11:48 AM   #1
Cocoa Beach Bum
Member#: 17355
Default 2.0L DIT Factory-Equpped Oil Catch Can
This might not be the appropriate forum for discussion of FHI's new 2.0L DIT engine found in the 2014 Forester XT. Maybe a new forum should be created since the FA20 DIT is significantly different that the old EJ20 turbo engines.
Subaru apparently uses the more-technical term "tank" instead of "can" but I'm sure they are synonymous. If you search the 2014 Forester 2.0L turbo service manual for the terms "oil catch tank" (click here), you get some hits. But there are no hits from a similar search of the 2013 Forester 2.5L turbo service manual. There is a new Technician Reference Booklet for the 2014 Forester (Module 924) which probably has a description of this new system, but I don't have the subscription necessary to view it.
The system seems to be "closed" because I couldn't find any mention of an inspection/service interval for the oil catch tank in the Owner's Manual.
The FA20 engine used in the BRZ is equipped with Toyota's D4-S fuel injection system which utilizes both port- and direct-fuel-injection. The gasoline introduced into the intake manifold by the port injection acted as a solvent to prevent the intake valves from becoming gunked up by blowby oil mist. The new FA20 DIT engine eliminated the port injectors, so FHI needed a way to prevent blowby oil mist from entering the intake manifold.
A year ago, an FHI patent application in the US titled "Breather Apparatus for Engine" was published. You can view it here. According to the application's "Field Of The Invention" statement:
The present invention relates to an engine breather apparatus that separates oil mist from blowby gas that is led from the crankcase toward the air intake system.
Now, just because FHI is trying to patent some ideas doesn't necessarily mean that any of those ideas have been incorporated into the FA20 DIT.
If anyone with STIS access could provide some additional detail (and I don't mean entire service manual dumps), I would appreciate it. A screen-grab of a diagram showing the oil catch tank and its connections would be nice.
Cocoa Beach Bum is offline   Reply With Quote
Old 04-03-2013, 01:10 PM   #2
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
never really thought about it, but I guess blowby control is pretty important when you go to a full DI engine.
Old 04-25-2013, 11:53 AM   #4
fredzy
Member#: 317270
15 WRX, WRB 6MT
14 CX-5
So something in the intake indeed seems to separate oil from the air and sends it to this tank. Then the turbo takes care of it somehow? I'm assuming the separated oil is sent back to the engine.
Maybe the turbo just keeps the contents of the can hot and water-free and they eventually trickle down into the engine.
*edit* So hot turbo oil is pumped through the can and the vapors that are generated go back to the intake via the PCV hose. I still can't see how the bulk of the contents leave the can (or enter???) - perhaps there's a few feed/drain lines not mentioned in these pics. Otherwise the heat would have to keep liquid oil from accumulating and everything would leave through the PCV. Then the oil would be back in your intake
These types of things are sensitive to clogging failure modes... I see some plugs that will pop if it gets clogged/full so they've thought of that.
fredzy is offline   Reply With Quote
Old 04-26-2013, 01:46 AM   #5
miracle_whip4130
Member#: 343854
2005 WRX
Very interesting. I'm sure there is a lot more going on than those diagrams show. I agree that the oil from the turbo is used to warm the catch can. There must be some type of drain back to the engine for both the oil from the turbo oil line, as well as oil passing through the PCV valve.
miracle_whip4130 is offline   Reply With Quote
Old 04-26-2013, 02:27 PM   #6
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
I think the turbo in the DIT is front mount, like in the timing belt area. This appears to be a catch tank that's shares it's output with the oil return from the turbo. The oil from the turbo keeps things warm enough that water stays vapor and since you need an oil return for the turbo anyway, the catch tank just kinda piggybacks onto that.
That's what it looks like to me anyway. Who knows how the air part is baffled. Not sure this matters a whole lot, the novel patentable art appears to be the use of the turbo oil return to provide both a drain path and the means of preventing condensate.
Old 01-15-2014, 01:52 PM   #7
SeeeeeYa
Member#: 129681
2016 WRX w/EyeSight
Lapis Blue Pearl
A year ago, an FHI patent application in the US titled "Breather Apparatus for Engine" was published. You can view it here. According to the application's "Field Of The Invention" statement:Now, just because FHI is trying to patent some ideas doesn't necessarily mean that any of those ideas have been incorporated into the FA20 DIT.
Old thread, but current concerns.
Part of the reason I jumped into a 2014 Forester XT was because I had read the "Subaru AOS patent" papers and believed they had addressed the carbon-deposit issue. That has not proven to be the case, unfortunately. After obtaining the manual and looking for the patented device in vain I'm now concerned about the long term reliability of my FA20DIT engine.
The Oil Catch Tank is just that... the oil catch tank from the low-mount turbo's oil cooling system. The oil it catches immediately after cooling the turbo is returned to the oil supply by a scavenge pump. It's the same system in the 5th Gen Legacy. High-mount EJ turbo's oil simply drains directly back into the oil pan.
There is an Oil Separator in the rear of the block, but then there's been one in Subaru engines for generations. Nothing new, and nothing to do with addressing the issues unique to a direct injection engine.
I thought it was funny that there has been no more mention over these months since the 2014 FXT came out about how Subaru addressed the carbon issue. Now that the new 2015 WRX uses essentially the same motor the lack of a dialogue on the subject is even more strange.
The FA20DIT has now been in production for at least two years, one here and one in Japan. Unfortunately, however, there doesn't appear to be enough accumulated mileage to generate field data on carbon buildup in the engine. The disturbing fact remains that at some point there will be carbon buildup in this engine. There's simply no reason to believe otherwise.
For some disgusting pictures showing what happens in one DI engine, go here: http://www.bgfueltest.com/
I got rid of the best Subaru I've ever owned, my '11 STi Limited, because I didn't trust the EJ engine anymore. I'm beginning to regret that decision, as it appears I traded potential ringland problems for the certainty of carbon problems.
Personally, despite the rabid fervent over the 2015 STi having retained an "old and outdated" EJ engine, the 2015 STi is looking better all the time...
SeeeeeYa is online now   Reply With Quote
Old 01-16-2014, 03:42 PM   #8
fredzy
Member#: 317270
15 WRX, WRB 6MT
14 CX-5
I'm trying to follow what you're saying regarding this oil catch system doing nothing to separate oil/moisture from the air recirculated back into the intake (and considering you have some tech pubs you aught to know.)
But why is this catch can connected to the PCV system, and what is the purpose of the air intake duct? Is that all just for letting this can breathe? Are you certain it doesn't condense anything out of the air before sending it to the Intake manifold?
Old 01-16-2014, 03:48 PM   #9
SoapBox
Member#: 204578
S54 E46, N54 E82,
N55 E84, AKA REX8
Are you serious? Ringland problems mean $texas/new motor. Carbon buildup means a 2-3 hour manual cleaning in your driveway, or a $400, 1.5 hr. media blast from your mechanic, once every 5 years or so.
One is a catastrophic engine failure, the other is really what amounts to maintenance item.
How the hell can you even begin to equate the two?
Old 01-16-2014, 03:57 PM   #10
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Holy crap, there are explosions in internal combustion engines. I traded my safe steam engine in for this?!?! I thought the fire in my steam engine was bad!
ProfessWRX is offline   Reply With Quote
Old 01-16-2014, 03:59 PM   #11
SoapBox
Member#: 204578
S54 E46, N54 E82,
N55 E84, AKA REX8
Old 01-16-2014, 04:24 PM   #12
fredzy
Member#: 317270
15 WRX, WRB 6MT
14 CX-5
Let's not make this a DI politics thread guys... contribute to the oil catch tank discussion only, or you can post it in news and rumors.
Old 02-02-2014, 11:50 PM   #13
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Haven't seen the manual for the '14 Forester yet, but as you said, that's certainly how it appears to work in the 5th gen LGT.
DrD is offline   Reply With Quote
Old 10-23-2014, 05:00 PM   #14
spectra
Member#: 15763
2015 WRX
I have a 2015 WRX and was wondering if this should be something I need to get. Mishimoto has a two can system that is out now but the system is around $500. Mishimoto also has 3-port catch cans on there website which means that you can connect the PCV & CCV to just the one catch can for $170. My question is would there be any reason why you would want a two catch can system vs just have a one catch can system? I just wonder if there is really a benefit or if they just want to sell the more expensive system. Let me know. Thanks
Sent from my iPhone using NASIOC
spectra is offline   Reply With Quote
Old 11-27-2014, 02:52 AM   #15
wrxgarage
Member#: 404542
2015 WRX
GBP
I put my Mishimoto Dual Catch on my 2015 WRX at 1000 miles. The two systems are separate to not interfere with direction of oil/vapor to the baffled cans? I checked cans at 3500 miles. After 2500 miles there was maybe by guess 1/2 teaspoon in each can. I will take accurate measurements after 5000 miles when there's something to measure. I'm no mechanic so this is opinion/speculation. Please somebody chime in with better explanation.
wrxgarage is offline   Reply With Quote
Old 11-27-2014, 02:18 PM   #16
SeeeeeYa
Member#: 129681
2016 WRX w/EyeSight
Lapis Blue Pearl
Thank you for this feedback! It is the most significant post yet about the subject. All the rest is conjecture and speculation... but this information, while only pertinent to your car, makes me rest easier with regards to the subject at hand.
Old 01-31-2015, 10:14 PM   #17
FleaDog
Member#: 96267
'06 20G-XT'd STI
CGM & NT03+M
Excellent info been wondering about this for my '14 FXT.
FleaDog is offline   Reply With Quote
Old 02-01-2015, 01:34 AM   #18
berserkerx
Member#: 412344
How many have installed an OCC on the car? this will most likely be my first mod. I bought one for my evo and I will probably use the same one on this car.
berserkerx is offline   Reply With Quote
Old 02-05-2015, 12:59 PM   #19
ryager
Member#: 342391
2015 WRX
I installed one, the dual setup is explained by Mishimoto, it is because of how the new engines work and how the PCV and CCV are setup. I do not remember the exact reason, however if you look for Mishimoto on this site you should be able to find it and read into it a little bit more. You should be running a dual catch can type of setup, this is not to say that you cannot just buy two catch cans and do it. I utilize the Mishimoto one, because (1) I trust them, (2) they have always answered all of questions, (3) great customer support, (4) they did all the hard stuff, lol, they already have the lines and everything else so the install is easy, lastly (5) they have a lifetime warranty. I just did it about 500 miles ago so I have not even checked them yet, however with the winter that we just had in Chicago I am thinking that there will be some water in there along with a little bit of oil. I will be checking in about 500 more miles and then get a baseline until I get up to my first oil change, as Mishimoto says to do.
ryager is offline   Reply With Quote
Old 02-06-2015, 10:30 PM   #20
RenoGrimace
Member#: 412556
You guys have me worried about such a new motor now. Guess I'll keep following this.
RenoGrimace is offline   Reply With Quote
Old 02-07-2015, 09:52 AM   #21
dirtroadjunkie
Member#: 399247
2016 WRX
New motors aren't for the faint of heart.
dirtroadjunkie is offline   Reply With Quote
Old 02-27-2015, 10:45 PM   #22
Quirt
Member#: 409176
We have our Crawford V3 DIT AOS specifically designed for the new Turbo FA motor on sale now.
Quirt is offline   Reply With Quote
Old 02-28-2015, 02:24 AM   #23
ryager
Member#: 342391
2015 WRX
What about Subaru upper engine cleaner? Wouldn't this work to help with the valves, or is this only for the EJ engines (I wouldn't see why it would be but you never know). Part number SOA868V9340 it is only 19 bucks for the whole kit. Anybody utilize this, is it a waste of time or does it actually work? I do not understand why Subaru would come out with a product and put their name on it if they did not think it would actually work or if they did not have some type of evidence that it does work.
Old 02-28-2015, 01:20 PM   #24
Raginrok
Member#: 402098
I am going on with my dremel brushes once it gets warm enough to install my TiC deletes a little sea foam and some rags should be good as new in a few hours. Also waiting to get my Crawford AOS v3.
Raginrok is offline   Reply With Quote
Old 02-28-2015, 09:03 PM   #25
purpleano
Member#: 414303
I installed the Mishimoto dual-can system at 25 miles and had very little (a few drops) in the cans at 1500 miles. Pretty easy install to provide some peace of mind...
purpleano is offline   Reply With Quote
