Old 03-18-2013, 04:47 PM   #1
SteamSpeed.com
Member#: 339860
Default JDM on USDM fuelrails?
Do you know which JDM STI version would have compatible fuel rails with USDM top feed models?
This one looks like a top feed fuel rail, but I am not sure what the GDB version WRX came with.
Kinugawa Fuel Rail High Flow SUBARU JDM STI Spec C GDB EJ20 EJ25
These seem like side feed fuel rails..
Kinugawa Fuel Rail High Flow SUBARU WRX STI GC8 GF8 V3 V4 EJ20
Kinugawa Fuel Rail High Flow SUBARU WRX STI GC8 GF8 V5 V6 EJ20
SteamSpeed.com is online now   Reply With Quote
Old 03-19-2013, 10:50 AM   #2
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Its best to ask them. The rev A spec C had TGV's (V7).
This may be a reason for which they include EJ25 in the same description.
This would mean that it fits USDM, but not JDM V8,9.
Old 03-19-2013, 12:04 PM   #3
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
I think even the JDM top feed rails have different mount hole location so it wouldn't be a direct bolt up. There are plenty of manufacturers that make top feed rail for the USDM application, why not use parts that fit?
Old 03-19-2013, 01:46 PM   #4
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
JDM Sti's with long runner manifolds (no tgv risers) must use adapters when using aftermarket usdm rails. Couple of members on the board make them custom.
example http://forums.nasioc.com/forums/show...6#post34054036
Old 03-21-2013, 10:02 PM   #5
SteamSpeed.com
Member#: 339860
Thanks for the feedback.
It will probably be best to stick a US specific fuel rails unless the customer has a JDM intake/TGVs.
Old 04-03-2013, 08:48 PM   #6
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
I'm using these : Kinugawa Fuel Rail High Flow SUBARU JDM STI Spec C GDB EJ20 EJ25
w/ my 2005 STi top feed conversion set up/manifold.. fits like a charm
Old 04-03-2013, 09:18 PM   #7
ogboot
Member#: 170906
psm
Interesting, would that be the same rails for the 2L since you've done the conversion?
ogboot is offline   Reply With Quote
Old 04-03-2013, 10:27 PM   #8
sense of nature
Member#: 112759
SexyRP
Yes , as long as top feed tgv's r used the rails bolt right up .
Old 04-03-2013, 10:40 PM   #9
ogboot
Member#: 170906
psm
Sweet, i've been wanting to get these rails for my ej205.
Old 07-22-2014, 09:16 PM   #10
gianttcr
Member#: 108790
2002 WRX 2.2 Wagon
Sorry to pull up old thread. Sense, you wouldnt happen to know the ORB threading IN the rail would you? I'm doing hard SS lines and want to run a 90 swivel to have clearance, but both the ORB6 and ORB8 are the wrong size. It is something in between. Maybe 12x1.25? Anyway, thanks.
gianttcr is online now   Reply With Quote
