Welcome to the North American Subaru Impreza Owners Club Sunday December 4, 2016
Old 04-03-2013, 08:04 PM   #1
zylent
Member#: 320339
2009 Forester XT Ltd
Spark Silver
Default 2002 wrx bad misfire
When I had my timing done my mechanic pointed out that my car was misfiring, so today I changed my plugs to see if that would correct the issue. None of the plugs seemed to be fouled put, but I changed them anyway. I used ngk iridium one step colder plugs. After the change, my car was misfiring much worse, and ignition timing was all over the place (it was around 13 before). Any ideas? I'm going to check the connections to all the coil packs and clean them but I'm not that knowledgeable with issues like this.
2002 wrx
Catless Uppipe/down pipe
Manual boost controller 15 psi
Borla hush exhaust
Open source mild tune (a little rich but not enough to cause problems)
zylent is offline   Reply With Quote
Old 04-03-2013, 08:09 PM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
well you can rule out the plugs unless you gapped them incorrectly.
so that leaves injectors or coil packs
Old 04-03-2013, 08:32 PM   #3
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Listen to Jax.
Move coilpacks around to see if the miss changes cylilnders. If that's not it, move injectors around.
Wouldn't be the first time we've seen either of those issues. Coilpacks are a more common issue.
Old 04-03-2013, 10:26 PM   #4
zylent
Member#: 320339
Spark Silver
I checked the gaps on the plugs before installing, ill try wiggling the packs to see if that helps
Old 04-03-2013, 10:38 PM   #5
zylent
Member#: 320339
Spark Silver
I think that was it! I wiggled the coil packs back and forth towards the plugs and the idle smoothed out quite a bit, now that I know that was the issue, how do I make sure all the coil packs are seated properly?
Old 04-03-2013, 11:32 PM   #6
neurosis05
Member#: 230265
2005 WRX stage II
I don't know how it is on an 02 but on my 05 they seat properly because you bolt them down. I think what they meant by moving coil packs around is move them to a different cylinder. move 1 to 2, 3, to 4. Thats what I got out of it anyhow, maybe I'm missing something. What cylinders are misfiring?
Also I've heard it iridium plugs all come pre gaped and unless your really careful you can screw up the plug even checking them.
neurosis05 is offline   Reply With Quote
Old 04-04-2013, 12:30 PM   #7
Member#: 301037
2004 Forester XT
The 02-03's are the same way the coil pack bolts to the valve cover. I would be sure that the wire harness is plugged in correctly and in the right order as the clips have a tendency to break as they get old and brittle.
art@grimmspeed is offline   Reply With Quote
