Old 06-28-2010, 03:11 PM   #1
sixthgearjunkie
Member#: 219497
1997 Impreza L
Default Speed sensor short out
So it would seem that my speed sensor has shorted out and therefore is making my rev limiter kick in at 4.5k
this is a problem! now i have heard that the only way to get to my speed sensor is to go back and drop the engine and tranny again to get to it, and i don't have the tools or the money to be able to get that done. Is there any way I can disable the CEL for short periods of time. To be honest i don't really need the speedometer as I have the tach and only ever really use it. I want to either disable just that one particular CEL from coming on or the thing entirely and I only want to disable it sometimes, so not permanantly. Any speculations?
sixthgearjunkie is offline   Reply With Quote
Old 06-29-2010, 02:54 AM   #2
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
Assuming you have a manual transmission you do not have to drop the engine or tranny to get to the speed sensor. It is located on the passenger side of the tranny facing up about half way down the tranny.
Empty tranny...
With speed sensor inserted
Sorry for the crappy pics but the iPhone is only so good. Anyways...you get the idea of where it is located. You can't completely see the sensor from underneath but you can see the pigtail and follow it down. A crescent wrench will get it loose for you. You'll have to contort your hand a bit to screw it back in but its not too hard.
As far as I know, it cannot be bypassed since the ECU needs to see the pulse it creates in order to not be in safe mode.
PhilSine is offline   Reply With Quote
Old 07-02-2010, 12:45 AM   #3
sixthgearjunkie
Member#: 219497
1997 Impreza L
I did find the sensor and your right it isn't hard to see at all, now i just need to locate a used one or something to suffice for the time being.
Old 07-02-2010, 12:46 AM   #4
sixthgearjunkie
Member#: 219497
1997 Impreza L
By the way those pictures are extremely helpful to be honest. found the baby in a matter of seconds lol
Old 07-12-2010, 08:45 PM   #5
Deus ex Machina
Member#: 79815
06 Mazda 6S
Does anyone know the part number for that sensor? Or any place that I might be able to find it?
EDIT: Doing some more searching, it seems that the part number is 85082ae000.. can anyone confirm/deny?
Deus ex Machina is offline   Reply With Quote
Old 12-06-2010, 03:17 PM   #6
sith005
Member#: 144629
2005 WRX Wagon
WR Blue Pearl
Ditto on the pics, they are great! This is perfect, this just happened to me late last week. Thanks for the thread and the great pics/instructions!
sith005 is offline   Reply With Quote
Old 12-06-2010, 03:26 PM   #7
99imprezd
Member#: 198964
2015 WRX
crystal white pearl
I swapped my trans on my '03 and the new speedo sensor was beat.. The only thing that happened was my speedo didnt work and had a CEL (P0502). I put the sensor from my old trans in and everything works fine now..
99imprezd is offline   Reply With Quote
Old 12-07-2010, 01:09 AM   #8
bangedlegacywagon97
Member#: 215017
97OB 2004 civic
Speed sensor does put the ECU in limp mode. $130 part
bangedlegacywagon97 is offline   Reply With Quote
Old 12-07-2010, 02:49 AM   #9
sith005
Member#: 144629
2005 WRX Wagon
WR Blue Pearl
Bummer, so turns out my sensor is fine, it's the sensor gear INSIDE the tranny that is worn down and needs to be replaced. Need to drop the tranny, open it up, swap it, and put back. Ugh...
Old 12-07-2010, 10:09 PM   #10
doobarugt
Member#: 265207
05 Legacy GT
So I drive an 05 Legacy GT and I replaced my terrible factory rear wheel bearings and now it rides like a dream, however, I'm having an issue with my speed sensor. When I did my bearings I also did brakes all around. Now I get an ABS light and the ER SS message. The ABS light is on at the start of driving but then goes off. When I pass around 49mph it comes on. Also, if I cruise at slower speed, the cruise will work but then feel a tiny brake check and I lose all functionality with my cruise. Any ideas? Also, I noticed I've lost power even with my accessport map. Is that the "limp" mode?
doobarugt is offline   Reply With Quote
Old 12-08-2010, 06:31 AM   #11
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
I am having this same problem on my 1997 2.2ltr Outback Sport. Thanks for the pics above. I will be taking a look at it.
Post up any part numbers if you can guys! My problem actually came after having an Apexi SAFC NEO installed. Shop has since closed down and I suck fiddling with electrical stuff. So the car has been sitting. This is the only thing preventing me from taking it through motor vehicle. It's triggering the check engine light.
Kevin Thomas is offline   Reply With Quote
Old 01-22-2011, 01:53 PM   #12
treborcd
Member#: 196519
05 WRX
black
I'm having the same problem, speedometer doesn't work, sensor's fine, it's the small gear. Did you end up getting it fixed and is this a repair that only a Subaru dealership should look at? I know it'll be expensive but is it asking to get gouged by going to a dealership?
Also, does anyone know the part number for that small gear?
treborcd is offline   Reply With Quote
Old 04-04-2013, 03:05 AM   #13
Seanbreweraz
Member#: 352329
1996 Impreza outback
Default Speedo tranny gear
I saw on a bother forum that you may be able to get to the gear from underneath behing the axel. The internal gear is shaved off and trying to find a way not the have to drop the transmission. Here is the post
http://www.ultimatesubaru.org/forum/...cement-in-car/
Also does any know a part number for the gear.
Seanbreweraz is offline   Reply With Quote
Just bough Eclipse Navi and can't figure out how to install speed sensor JASWRX Car Audio, Video & Security 3 09-29-2010 04:24 PM
ABS light on, what sensors trigger it? wheel ABS sensor, speed sensor, what else? kirbykirb Legacy Forum 4 06-19-2010 11:37 PM
CEL figured out!! what is speed sensor? kick_boxur Pre-2002 Factory Turbo Powertrain 7 10-30-2008 01:04 PM
Anyone yank out the speed sensor? sidewayz Transmission (AT/MT) & Driveline 8 10-05-2001 07:53 PM
O2 sensor and speed sensor Seca2man New England Impreza Club Forum -- NESIC 3 04-06-2001 05:16 PM
