Old 03-31-2013, 07:21 PM   #1
Adremann
Member#: 351994
2003 Impreza WRX
Midnight Blue
Default Bad Wastegate?
Alrighty guys before anything I'd like to point out that I have done alot of looking and cannot come up with a solution. My Wastegate is bad (i think) because i read one post about how if you can easily pull on the accuator arm then it's likely junk. Not to mention adjusting the accuator arm doesn't do anything to help it. The symptoms are the turbo will hold pressure perfectly fine during normal applications but as soon as you open up the throttle and get into the higher rpms the boost with fluctuate between about .08-.13 MPA on the standard boost gauge (which i have heard alot about being inaccurate) and it also feels as if im having a powerloss when i hit the higher RPMs due to this. There is no leaks in the vac lines that i have detected but like i said i can pull on the accuator arm to the waste gate and move it easily. My question from this point is what to do to fix this? External waste gate? i cant seem to find any stock ones.. nor am i sure of what exact turbo i am dealing with because it is an 03 WRX with the turbo off of an 06. Any and all help is appreciated because i am a new subie owner
Adremann is offline   Reply With Quote
Old 03-31-2013, 07:22 PM   #2
Adremann
Member#: 351994
2003 Impreza WRX
Midnight Blue
Also i would like to point out i have an aftermarket boost gauge from sunpro and a sunpro air/fuel ratio gauge im going to install soon so i can get accurate readings then and i am on a slight limited budget of about 300-350 but do have access to about any tools i could possibly need to do it myself if that is possible
Old 03-31-2013, 07:25 PM   #3
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
Can you log? That would help greatly.
Cathexis is offline   Reply With Quote
Old 03-31-2013, 08:30 PM   #4
Adremann
Member#: 351994
2003 Impreza WRX
Midnight Blue
How exactly would i accomplish that? not exactly sure besides like an OBD2 port on most american cars but the subie doesnt have that and i do not know the name of the plug to connect to it
Old 04-01-2013, 04:16 AM   #5
aberg12012
Member#: 127614
2008 WRX
Obsidian Black
Oh boy. You have a lot of reading to do sir. I don't mean to pick on you... we all started some where. But really- Search and do some reading. And for gods sake don't do anything under the hood until you procure a tuner and a way to log.
aberg12012 is offline   Reply With Quote
Old 04-01-2013, 04:25 AM   #6
Amazinman
Member#: 332340
Originally Posted by aberg12012 View Post
Oh boy. You have a lot of reading to do sir. I don't mean to pick on you... we all started some where. But really... search and do some reading. And don't do anything under the hood until you procure a tuner and a way to log.
And a little hint: If your vehicle doesn't have an OBDII port it is likely eligible for collector plates.
This seams a simple wastegate problem. I don't know what turbo is on your car but if it its off a 06, you need to check the vacuum pipes from the high pressure end of the turbo to the wastegate, there should be a restrictor pill in it which has a 0.9mm hole in it. Please check.
Cheers
Amazinman is offline   Reply With Quote
Old 04-01-2013, 05:34 AM   #7
aberg12012
Member#: 127614
2008 WRX
Obsidian Black
There's absolutely no way to know its a waste gate problem from the info provided. And I don't think the OP has the background knowledge to be able to provide such info here yet. As such I suggest he enlist the help of a local guru or tuner who can physically diagnose the car and guide him through. Not some random nasioc newb (me) who will only send him in ten different directions if I try to say what I think it is based on the very limited info provided here.
Sorry this isn't more sugar coated.
Old 04-01-2013, 08:31 AM   #8
Cathexis
Member#: 335445
2012 WRX - BLK STIG
All cars, 1996 and newer are required to have OBDII.
Now, find you local subies and start meeting with them. Casual conversation will teach you a lot. My point though is, one of those guys should have an accessport or tactrix they can let you use and show you how to run a log.
Logging is an excellent diagnostic tool, and imho, everyone should do it from time to time and know how to spot issues in them as well.
Old 04-01-2013, 09:46 AM   #9
Adremann
Member#: 351994
2003 Impreza WRX
Midnight Blue
Well if it helps I do have a personal guru of my own he's been working as a mechanic on everything for over 15 years right now he's working for cummins and he's helped me a lot through the problems I have had but I could probably get some logging stuff from him and get it done if necessary because it is kind of a drive to see him now lol
Old 04-01-2013, 11:01 AM   #10
Adremann
Member#: 351994
2003 Impreza WRX
Midnight Blue
Also just a tidbid what kind of information do you need to diagnose this because I can get about anything needed since you guys say its so little of information and vague? And if I do log what am I looking for? Misfires? Because I know that is not the case and I do not have any check engine lights currently or have ever been on. And the turbo is just the stock model off of an 06 wrx so I think it's still the TD 04? By all means correct me if I am wrong on anything I am a newb to subies but I know a great deal in general (not turbos though lol but slowly learning it all)
Old 04-01-2013, 01:44 PM   #11
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
Yes it is still a td04, to log look into getting taxtrex cable and u will need a laptop. another alternative is to buy a Cobb access port if you plan on doing performance modifications in the future.
Shortpersonbk is offline   Reply With Quote
Old 04-01-2013, 02:22 PM   #12
Cathexis
Member#: 335445
2012 WRX - BLK STIG
I woukd like to see your wastegate duty cycles. That of course requires logging though. Ask on your regional/chapter forum for anyone willing to bring their kit over (or you go to them,) and help you get a log done. It's quick and easy, a 6 pack of beer should cover it. ;p
Old 04-02-2013, 08:40 PM   #13
Adremann
Member#: 351994
2003 Impreza WRX
Midnight Blue
Well update.. I'm probably going to be ordering an AccessPort here tomorrow maybe. But thats dependent on the fact of what the hell im reading right now. I found the OBD2 port and plugged in my personal obd2 and ran the torque app on my phone. and well its either really off or my car is having some issues. its reading my max rpm at 5k even if i go above that. my boost is at apparently -56 in/hg. and yea a number of things are off despite my calibrations of weight engine size turbo pressure and such. idk whats wrong it might be the adapter but it worked perfectly for my grand prix. (i know not an import but still) HELP!
Old 04-02-2013, 09:19 PM   #14
Cathexis
Member#: 335445
2012 WRX - BLK STIG
I would say way, way off. You can alwaus buy a used ap from the classifieds here, and sell it anytime for likely what you paid for it. They sell in seconds on here lol. Cobb also has a buyback program.
Old 04-03-2013, 12:31 PM   #15
mikeydrives1
Member#: 262117
I vaguelly remember having to work a kink out like this, and it ended up being a turbo dynamics table that was too sensitive.
To correct it, my tuner and i Zero'd out the tables and took some trial and error runs to work it back in to be smooth. I saw this more in longer gear pulls (4th / 5th / 6th) rather than down low though.
mikeydrives1 is offline   Reply With Quote
Old 04-03-2013, 07:24 PM   #16
Adremann
Member#: 351994
2003 Impreza WRX
Midnight Blue
Honestly im beginning to think the guy i bought the car from said he had it tuned before i bought it. and im thinking he got a really crappy tuner to do it and its just a bad tune for the car. im buying a new accessport because im liking going to keep it forever and not sell it :P and make sure im getting my full warranty and also my mechanic is coming up this weekend so im gonna have a fun day hopefully lol also do you think fedex overnight shipping if i ordered it right now would get it here friday by the latest?
Old 04-03-2013, 07:28 PM   #17
Adremann
Member#: 351994
2003 Impreza WRX
Midnight Blue
Also why is there different accessports for the different years? if i got one for just a 2003 WRX sedan i couldnt use it on a new wrx or sti? from what i understand when i read about it
Old 04-03-2013, 09:45 PM   #18
Adremann
Member#: 351994
2003 Impreza WRX
Midnight Blue
Ok i bought my AccessPort for the 2003 WRX Sedan and did fedex overnight shipping so i should have it friday and should be able to do some logging and some work with my mechanic over the weekend ill try to get some logs up before we do stuff with it though
Old 04-04-2013, 04:01 AM   #19
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
the 02-05 wrx's have a 16 bit ecu.
04-07 Sti's have a 32 bit ecu....
08+ cars are Canbus.
so no, your AP for a 2003 WRX wont work on any of those other cars.
your best bet is to go to a shop and let them diagnose it. you simply dont have the tools to convey the information necessary to diagnose the problem over the internet.
Old 04-04-2013, 10:04 AM   #20
Adremann
Member#: 351994
2003 Impreza WRX
Midnight Blue
Oh but I will soon my accessport shall be here by Friday and I will be able to log and show it soon.
