Welcome to the North American Subaru Impreza Owners Club Saturday February 28, 2015
Go Back   NASIOC > NASIOC Technical > Normally Aspirated with bolt-on Forced Induction Powertrain
Old 01-11-2013, 12:15 AM   #76
commikazy subaru
Member#: 334024
just brought a stock legacy turbo set up and I was told it would be an easy swap in to 2000 impreza OBS. I can't find a DIY any where. any one have any suggestions? the kit came with the following: turbo exhaust manifold down pipe intake manifold fuel injectors fuel pump some other misc parts I was just going to run like 5-8 psi of boost to get a bit extra power for rallycross. open to suggestions if you know some one who has done some thing similar and have posted a DIY please share
commikazy subaru is offline   Reply With Quote
Old 01-11-2013, 09:45 PM   #77
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Look harder
http://www.rs25.com/forums/f7-turbo-superchargers
geronimo81 is online now   Reply With Quote
Old 01-12-2013, 03:51 PM   #78
f0rz4m0t0rsp0rtf4n
Member#: 342257
2013 impreza premium
Marine blue pearl
that sounds grreat
f0rz4m0t0rsp0rtf4n is offline   Reply With Quote
Old 02-09-2013, 12:16 AM   #79
monkeyposeur
Member#: 333468
93 SS
Black Pearl
I'm considering building a boosted 22E. Up until today I was going to build up a 22T block that I picked up for free. But now I might just sell it and use the proceeds towards a 22E. I already have a wrx ecu and complete dash/engine harness. I might be picking up some 205 heads and intake mani next week and I can get a phase 2 22E shortblock for $50. I can get a set of 257 rods and Wiseco .020 OS pistons for $200.
If I can get $800 or so for the 22T block halves that could help fund my build. I have a few sets of 22T heads, stock internals, pistons, and intake mani that I could also sell.
I was all about the closed deck 22T, but now I realize that the 22E is a sweet bottom end to use with 205 heads, especially with upgraded internals. And since my power goals are fairly modest 200-260 hp the 22T really isn't necessary to achieve that. If anyone knows of a good thread using a 22E, 205 heads please let me know. I've been doing a lot of searching, but no luck yet.
monkeyposeur is offline   Reply With Quote
Old 02-11-2013, 02:41 AM   #80
amoore131
Member#: 222708
Alex - 96 Impreza AWD | Stock Phase 1 EJ22e Heads & Block| TD04@7psi |Stock Injectors w/ RRFPR & 255lph fuel pump| 175-185whp est.
Soon to be 9-10 psi with meth injection system and eventually vf23 turbo.
amoore131 is offline   Reply With Quote
Old 02-13-2013, 11:09 PM   #81
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Did you try running it without the RRFPR or did you start with that setup? I am boosting my ej22e but 5psi and no management.
Old 02-13-2013, 11:10 PM   #82
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
$800
Old 02-13-2013, 11:17 PM   #83
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Exhaust manifold and intake manifold won't work with your heads. This might help
http://www.rs25.com/forums/f7/t10779...arts-list.html
Old 02-14-2013, 11:00 AM   #84
amoore131
Member#: 222708
No i did not. Went straight to a vortec rrfpr following a diy thread. You are going to want something for fuel. You can get the obx rrfpr on Ebay for pretty cheap.
Old 02-14-2013, 07:17 PM   #85
monkeyposeur
Member#: 333468
93 SS
Black Pearl
$800
Euros love em.
But I changed my mind anyway. I'm just gonna build the 22T.
Old 02-15-2013, 02:00 PM   #86
thorne
Member#: 130063
Silb
So for those talking about EJ22e vs EJ22t, The open vs closded deck isn't the real issue. It's the pistons. If you could get a set of pistons in a EJ22e I'd wager 375hp would hold.
thorne is offline   Reply With Quote
Old 02-16-2013, 12:05 AM   #87
monkeyposeur
Member#: 333468
93 SS
Black Pearl
Why don't you be the first?
Old 02-16-2013, 02:21 AM   #88
squarebush
Member#: 173656
I was looking at my svx pistons, they are so beefy. The bore is right I am just concerend with the length hitting the crank. The pin is in the same spot. the skirts are just larger
squarebush is offline   Reply With Quote
Old 02-17-2013, 09:14 PM   #89
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
I'm going to try running mine without any management initially. I am convinced that the stock system can keep up. It does help that I have a wrx fuel pump already installed.
Old 02-18-2013, 12:50 AM   #90
amoore131
Member#: 222708
Then i would seriously consider a wideband. I really don't think you could run it safely. I think you would run way to lean under boost. Is 60 or 70 bucks really worth risking a blown or underpowered motor?
Old 03-02-2013, 03:45 AM   #91
grizam303
Member#: 206177
I ran 15 psi in my ej22e open deck until I jacked up the transmission; E85 self tune. 14.8 @ 98 at high altitude, Denver. (also it was 92F out that day).
http://www.rs25.com/forums/f145/t109...ams-ej22e.html
grizam303 is offline   Reply With Quote
Old 03-06-2013, 06:24 PM   #92
thorne
Member#: 130063
Silb
beacuse when I cracked the ring land @370whp I got a ej257. and I'm going to push 400 this year and 500 next when i do turbo.
I ran 12.4 a ton of times on my ej22e before I dyno tuned it. I was having issues going into 5th preventing me from going faster
Old 03-08-2013, 10:23 PM   #93
blue wrench
Member#: 349542
Wow, after going through this thread, squeezing something like 300WHP out of a 22E seems like a viable possibility, hmm... Honestly I was ignorant and didn't think much of this motor, gets me thinking now
BTW, can you tell me what front bumper that is?
Originally Posted by squarebush View Post
blue wrench is offline   Reply With Quote
Old 03-09-2013, 06:42 AM   #94
Subiekid724
Member#: 348838
1998 Outback Sport
Noob coming through! Alright, i want to run around 10psi,i was thinking about doing sti rods and JE pistons. Would it be the best setup? Or could i run 10psi with stock ej22e internals?
Subiekid724 is offline   Reply With Quote
Old 03-10-2013, 11:09 PM   #95
SubieHondaGuy
Member#: 312223
1998 Outback
Green
GT sedan FTW
SubieHondaGuy is offline   Reply With Quote
Old 03-12-2013, 11:13 PM   #96
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Stock internals is fine
Old 04-03-2013, 01:37 PM   #97
mutydog
Member#: 319484
1998 OBS-T
black/grey
Hey guys, Im not sure if you would know whats going on, but ive been having some minor issues with my turbo setup. I had a vf11 on my 98 ej222, and it ran great at 7 psi and had plenty of power. i decided to intercool it, and it was easiest to just swap out my vf-11 with a td04 at 5psi. So, at sea level now i hit a fuel cut at 4000 rpm (only at wide open throttle.) i moved to idaho for college, and i live at 5000ft above sea level. when it is super cold outside(below 0) i have tons of power all the way to redline, but now that it is warming up outside, it feels like a parachute gets deployed at 4000 rpm at wot. I thought it had something to do with not getting enough fuel, but im pretty sure that isnt an issue. What do you guys think could be the problem, and why would it be so sensitive to warm air, which should be less dense? Your help/ideas would be greatly appreciated!
mutydog is offline   Reply With Quote
Old 04-03-2013, 04:14 PM   #98
eg33GC
Member#: 206851
99 V4
EJ20K RS
youre probably getting knock. 4000 is prime territory for detonation.
whats your em?
Old 04-03-2013, 04:32 PM   #99
amoore131
Member#: 222708
Sounds like a fuel issue. Lack of pressure or not enough. Possible cel causing it to cut? Is it map or maf?
Old 04-04-2013, 12:19 PM   #100
mutydog
Member#: 319484
1998 OBS-T
black/grey
I havent gotten a cel at all...and it it is a 98, so it has a maf. but im kind of confused about that too, cause when i had my vf-11 turbo on it, it spiked too high once, and threw a high intake manifold pressure code. so that makes me want to think there is something monitoring manifold pressure.... If it was detecting knock, wouldnt that throw a code as well? would changing spark plugs to one step colder get rid of a knock? im not using em, just stock ecu. thanks for your help, guys!
boosting on an ej22 shortblock not a ej22t sime Normally Aspirated with bolt-on Forced Induction Powertrain 10 09-11-2014 07:05 PM
Whose boosting an EJ22 NA? Turbo GC4 Normally Aspirated with bolt-on Forced Induction Powertrain 5 09-11-2014 05:07 PM
New EBCS Pro From PERRIN - Boost Control Solenoid PERRIN Vendor Announcements 19 09-16-2010 08:35 PM
FS : Defi Racer Boost and EGT gauges Faster_Gun Interior/Dressup/Audio & Security 7 06-09-2010 10:37 PM
Less boost. higher atmospheric temp? COBB AP2 joosky Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-07-2010 04:38 PM
