Go Back   NASIOC > NASIOC Classifieds > Vendor Announcements
Old 01-21-2013, 04:56 PM   #1
ISC Suspension
NASIOC Manufacturer
Vendor Sales Rating: (0)
Member#: 252676
Hello NASIOC,
For 2013 we are introducing many new products, we will be offering much more than just coilovers and brake kits!
Our site is also getting a refresh, but you can view the online store which is getting rebuilt here:
http://iscsuspension-na.com/store/
Featured Product Jan 2013
Take a peak at our Subaru shift knobs which were launched last month and in stock!
http://iscsuspension-na.com/store/#!...=0&sort=normal
****NEW NEW NEW****
F
eatured Products Feb 2013:
The first product I would like to cover here is our new 5x100 to 5x114 Subaru wheel adapters:
These will be available in the next couple of weeks (accepting pre orders now as well).
We have 2 versions available, a 15mm and a 25mm.
ISC 5x100 to 5x114 Wheel Adapters- 15mm Black
450.00 for competitors adapters any longer. This set ( 4) of bolt pattern adapters will allow you to bolt STI fitment wheels (5x114) to your WRX (Legacy, Forester, BRZ or any 5x100 Subaru)! Unlike most bolt pattern adapters, these are only 15mm.[/font]
The ISC Subaru wheel adapters fit all 5x100 Subarus. Precision-CNC-machined billet aluminum bolt pattern adapters, and twenty special low-profile lug nuts. The adapters are hub-centric for both the car and wheels. Offered in both a anodized ISC gold, or a stealth black finish. ISC Logo is engraved on spacer as well.
Materials Used:
Adapter: CNC 7075 light weight high grade aluminum
Included Hardware: M12*1.25, Grade 10.9
Please Note*** Since these high quality CNC machined adapters are so thin, the factory studs will most likely stick out beyond the spacer. That means the 5x114 wheels you are bolting on MUST have pockets in back for the studs to poke into or modifications will need to be made to the studs. Make sure to check your wheels for clearance before you order these. Most STI wheels DO have pockets on the back side, so it is usually fine. You can also modify a wheel to have pockets, do some research on this and see if it right for you.
ISC 5x100 to 5x114 Wheel Adapters- 25mm Black
Finally, A name brand Subaru wheel adapter that works well and is affordable! No sense in paying 450.00 for competitors adapters any longer. This set ( 4) of bolt pattern adapters will allow you to bolt STI fitment wheels (5x114) to your WRX (Legacy, Forester, BRZ or any 5x100 Subaru)! These are 25mm wide.
Materials Used:
We have shifter bushings, intake spacers, more adjustable rear camber options, and many other goodies coming in 2013 as well! Thanks for looking.
Featured Products March 2013
As promised, this month's product release; ISC Subaru Shifter Bushings.
Made in USA- Lifetime Warranty- ISC Colors- Quality 90A Durometer Urethane
Featured Product June 2013
08+ WRX ISC Rear Adjustable Control Arms
Our new rear adjustable control arms are now available for the 08+ Subaru WRX/STi. A product that surpasses its competition by having better quality, availability, and price! This product is ideal for anyone with a 08+ who is lowering their vehicle on coilovers or even lowering springs. Using these adjustable arms will allow you to obtain correct camber settings, and in return a functional alignment and stance.
Our adjustable control arm is stronger and stiffer than OEM, allowing for better performance when you are pushing your vehicle to the limit. The highest grade hardware is included, and the control arm itself is constructed of CNC machined 6061 aluminum with an anodized ISC gold finish. Our logo is engraved into the arm as well for a sharp cosmetic appearance. These rear adjustable control arms are designed to be easily adjustable and durable for a lifetime of hard cornering and suspension abuse.
Whether you use your WRX as a daily driven street car with a nice stance or a track monster, these adjustable control arms will make your suspension work better, hands down.
Specs:
• 6061 Aluminum
• Top Grade Hardware, Pillowball Bearings
• StreetSeal (TM) corrosion protectant technology
• Anodized Finish
• Light weight
• Large Adjustment Range
• Fitment: 2008+ WRX/STi Sedan/Hatch
ISC Suspension is offline   Reply With Quote
Old 01-22-2013, 05:55 PM   #2
black11wrx
Member Sales Rating: (1)
Member#: 296339
Are the adapters sold in sets of 2 or 4? Also I have a 2011 wrx and going to put 06 bbs sti rims on mine 17x8 would a 15mm or 25mm fit better in this application?
black11wrx is offline   Reply With Quote
Old 01-22-2013, 08:06 PM   #3
ISC Suspension
NASIOC Manufacturer
Member#: 252676
Sold as a complete set of 4.
I would say 15mm would be best for you blackwrx.
Here are some quick images to show fitment:
06 WRX Hub (5x100)
ISC Wheel adapter 5x100 to 5x114 conversion
5x114 Enkei RPF1 (STI fitment)
No modifications needed for fitment on this application
__________________
Business Hours:
9am-5pm EST
603-715-9078
Join us on our Social Media!
Contact Info:
All service, rebuilds, and customer support done in USA.
Old 01-22-2013, 08:12 PM   #4
black11wrx
Member#: 296339
thats awesome and not a bad price for what you are getting. i hope to purchase these soon so i can get the bbs on this spring. thanks for the info
Old 03-05-2013, 12:40 AM   #5
CGM_WRX
Member Sales Rating: (14)
Member#: 66280
2005 WRX Sedan
Crystal Gray Metalic
When are backorders on the wheel adapters expected to start shipping? And why the sudden $100 price increase? You might want to reword your product description as the affordability part really doesn't apply anymore.
CGM_WRX is offline   Reply With Quote
Old 03-05-2013, 12:42 AM   #6
black11wrx
Member#: 296339
i noticed the price jump as well
Old 03-05-2013, 10:59 AM   #7
ISC Suspension
NASIOC Manufacturer
Member#: 252676
Hey guys,
This was a presale run for these, and it has taken a bit longer for them to arrive than we expected. It should have been made clear by your vendors that is was a presale, and they were not in stock by any means.
We changed the materials used to 7075 (as apposed to 6061) and our pricing structure got reworked for 2013 for all products. If you do not like the pricing you do not have to purchase them CGM_WRX, that is solely retail, MAP is 250.00. For 4x wheel adapters that are constructed like these it really is a good deal to be able to run 5x114 wheels, but to each his own
Thanks everyone!
__________________
Business Hours:
9am-5pm EST
603-715-9078
Contact Info:
Old 03-05-2013, 11:39 AM   #8
CGM_WRX
Member#: 66280
2005 WRX Sedan
Not really sure how you expect anyone to assume that when an item has been listed as in stock on your website for the last 5-6 weeks that it is a presale but anyway.........
Old 03-05-2013, 05:35 PM   #9
ISC Suspension
NASIOC Manufacturer
Member#: 252676
Thank you for your input and all the support on our new products folks!
__________________
Business Hours:
9am-5pm EST
603-715-9078
Contact Info:
Old 03-05-2013, 06:35 PM   #10
CGM_WRX
Member#: 66280
2005 WRX Sedan
So you're just going to ignore a an ETA request from a paying customer who has been waiting 5 weeks for his merchandise?
Time to go the rout of getting a refund I guess.
Old 03-06-2013, 10:29 AM   #11
ISC Suspension
NASIOC Manufacturer
Member#: 252676
I would suggest getting a refund from your vendor since this was a presale and not a in stock offering (if you needed them right away).
Sorry for any confusion!
This is a new product we are introducing and running a presale on, but they have not arrived yet.
__________________
Business Hours:
9am-5pm EST
603-715-9078
Contact Info:
Old 03-27-2013, 01:41 PM   #12
ISC Suspension
NASIOC Manufacturer
Member#: 252676
__________________
Business Hours:
9am-5pm EST
603-715-9078
Contact Info:
Old 04-04-2013, 04:16 PM   #13
ISC Suspension
NASIOC Manufacturer
Member#: 252676
__________________
Business Hours:
9am-5pm EST
603-715-9078
Contact Info:
Old 04-04-2013, 04:34 PM   #14
black11wrx
Member#: 296339
Just got my hub adapters yesterday, can't wait to get them and my rims on today!
Old 06-11-2013, 10:18 PM   #15
ISC Suspension
NASIOC Manufacturer
Member#: 252676
Introducing:
Our 2013 Rear Adjustable Control Arms!
Specs:
6061 Aluminum
Anodized Finish
Light weight
__________________
Business Hours:
9am-5pm EST
603-715-9078
Contact Info:
