Vancouver Impreza Club
Old 04-04-2013, 03:16 AM   #1
Ctogo
Member#: 338399
2002 Impreza WRX
Default So this happened today =s
http://www.youtube.com/watch?v=CnWa8...ature=youtu.be
As i was accelerating, my throttle all of a sudden cut off for about 3 seconds and kicked back in?
Happened this afternoon and hasn't happened again.. not really sure what's going on. fuel pump? Injectors? I need a proper tune? Maybe fuel cut off because of a boost spike? I have no idea.
Currently have
Catless Turboback
Catless Uppipe
Cobb OTS stage 2 HWG map
Ctogo is offline   Reply With Quote
Old 04-04-2013, 12:44 PM   #2
Cranker625
Member#: 327676
2002 Stg 2 WRX Sedan
PSM "sold"
when it cut off, was your CEL flashing?
If not, is your CEL lightbulb even working?
Cranker625 is offline   Reply With Quote
Old 04-04-2013, 12:57 PM   #3
danny_d19
Member#: 180748
2013 Scion FRS
Whiteout
that's really strange
danny_d19 is offline   Reply With Quote
Old 04-04-2013, 01:22 PM   #4
ShiftGear
Member#: 130493
1999 v5 STi
Fuel pump?
ShiftGear is offline   Reply With Quote
Old 04-04-2013, 01:56 PM   #5
RE3Rotor
Member#: 162465
04 Forester XT
12 Outback 2.5i
Boost cutoff. It happens to me when I accelerate too fast (especially on cold days). Being catless will do that to you. You should also look into porting the turbo, tune and maybe other stuff that I can't remember.
RE3Rotor is offline   Reply With Quote
Old 04-04-2013, 02:01 PM   #6
tora
Member#: 5851
09 Forester XT
+ NA Miata
port wastegate.
tora is offline   Reply With Quote
Old 04-04-2013, 02:03 PM   #7
Ctogo
Member#: 338399
2002 Impreza WRX
No CEL. It is working
Old 04-04-2013, 02:05 PM   #8
RE3Rotor
Member#: 162465
04 Forester XT
12 Outback 2.5i
Originally Posted by tora View Post
port wastegate.
What he said.
Old 04-04-2013, 02:33 PM   #9
danny_d19
Member#: 180748
2013 Scion FRS
Whiteout
it didn't sound like the car was anywhere near hitting boost cutoff in the video, sounded quiet
Old 04-04-2013, 07:56 PM   #10
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
+1
Don't think it was anywhere near 20 pounds yet lol
Old 04-04-2013, 11:50 PM   #11
RE3Rotor
Member#: 162465
04 Forester XT
12 Outback 2.5i
I am sure my Foz is not pushing out that much boost either. But every once in a while I will step on it to get up to speed on Alex Fraser and I hit the cut off. Otherwise it is all normal.
Old 04-05-2013, 12:44 AM   #12
Drakar
Member#: 68402
2016 WRX
Originally Posted by alcoolaid View Post
+1
didn't you read the 5mph full booost wot problem from a few years back
seriousness, you took a corner how low was your fuel? could have sloshed from the pickup and you had fuel starvation.
it happens, I killed my fuel pump on my 02 bugeye rounding a corner with almost no fuel and it sloshed starved and dead.
Drakar is offline   Reply With Quote
Old 04-05-2013, 01:28 AM   #13
Ctogo
Member#: 338399
2002 Impreza WRX
had about half tank yesterday. maybe this was a fluke.?
Old 04-05-2013, 03:15 AM   #14
Drakar
Member#: 68402
2016 WRX
Half tank is possible. Ask the autocross guys they can starve under 3/4 tank especially wrx's. Plus your gauge isnt super accurate and the 2nd half is the less then the 1st half.
Old 04-05-2013, 07:52 AM   #15
KIMUTAKU
Member#: 19776
2012 GVF SWP
Ninja Lime Green
Off topic.. What dash cam is that?.. Pretty clear video there..
KIMUTAKU is offline   Reply With Quote
Old 04-05-2013, 11:56 AM   #16
Ctogo
Member#: 338399
2002 Impreza WRX
Blackvue 380
Old 04-05-2013, 12:35 PM   #17
bikergreen
Member#: 192157
04 BMW 325xi Wagon
Grey
I'm going to go fuel pump on this one - same thing started happening to a buddy of mine in his mini and he hooked a up a fuel pressure gauge and sure enough! Wait and see if it starts happening more frequently.
bikergreen is offline   Reply With Quote
Old 04-05-2013, 08:06 PM   #18
clsmooth
Member#: 86394
2000 RS Coupe
2006 Forester L.L. Bean
Ah! Happens to me sometimes. I'll go around a corner and suddenly no power. The gas sloshes to one side of the tank and when fuel's low there's actually nothing under the pump for a moment and it pumps nothing (til you straighten out and gas sloshes back down).
More so on right turns then left it seems; must be the shape of the tank or the pump's installed slightly off-centre. Were you below 1/4 tank when that happened?
clsmooth is offline   Reply With Quote
Old 04-05-2013, 10:06 PM   #19
[YeS.SiR]
Member#: 56602
2012 SWP STi
Common fuel pump placement issue on 2002 WRX, but should only happen on right turns with 1/2 tank or less. If it cut off while going straight, that'd be another issue.
[YeS.SiR] is offline   Reply With Quote
Old 04-05-2013, 11:19 PM   #20
Ctogo
Member#: 338399
2002 Impreza WRX
About 50%. So it is probably just the tank design.
Old 04-06-2013, 11:40 AM   #21
brute_4s
Member#: 223755
My o 02 bug eye has a fuel slosh problem once it's at half a tank. If I take a right turn at heavy boost it'll starve the fuel pump and nosedive for a couple seconds. Didn't watch the vid but I bet that's your problem.
brute_4s is offline   Reply With Quote
Old 04-07-2013, 12:53 AM   #22
adanacsman
Member#: 305592
2012 Impreza CVT
5-Door SWP
do i get bonus points if i know where you were?
adanacsman is offline   Reply With Quote
Old 04-07-2013, 01:00 AM   #23
Azn-Jap STI
Member#: 76796
03 ImprezWRX -WRB-
-IMAGE BUG!- 600RR
fuel pump. happened to me before.
Azn-Jap STI is offline   Reply With Quote
Old 04-07-2013, 01:24 AM   #24
Ctogo
Member#: 338399
2002 Impreza WRX
Ha ya!
