Old 03-21-2013, 04:51 PM   #1
Jtello1636
Member#: 349311
Default Manuel boost controller for 2011 wrx
I was curious if a Manuel boost controller is necessary on my 2011 wrx sedan... Should the ecu be able to control it if I want more or less?
Jtello1636 is offline   Reply With Quote
Old 03-21-2013, 04:53 PM   #2
Jtello1636
Member#: 349311
I'm getting ready to do a few things to it and just not sure if I need it.
Old 03-21-2013, 05:44 PM   #3
jchafee
Member#: 238453
05 05 WRX
No and No. Please do some research before you buy anything. And it's manual.
jchafee is offline   Reply With Quote
Old 03-21-2013, 07:15 PM   #4
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
I'm going to hell... I thought of a guy in a sombrero under your hood with a valve when I read the title....
Whoever tunes your car can use the ECU to control boost (to a point, the stock restrictor pill puts an upper limit on what boost is possible) but an MBC does work very well as a boost controller for these cars.
Old 03-21-2013, 08:35 PM   #5
Jtello1636
Member#: 349311
Haha was driving so wasn't paying attention to the spelling haha I'm a tard!!
Old 03-21-2013, 08:37 PM   #6
Jtello1636
Member#: 349311
Ok great!! I read up a good amount I'm going with Perrin turbo back exhaust cosworth cold air intake dyno tune prob blow off valve and front mount intercooler. I just haven't read much bout controllers
Old 03-25-2013, 10:05 PM   #7
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
Was driving and posting... Where in NESIC are you, so I can stay away from that area?
Loyale93 is offline   Reply With Quote
Old 03-30-2013, 09:04 PM   #8
jeremy1122
Member#: 351645
I put my turbo xs on my 03 wrx and it didn't mind it. Just had to cap off a hose from the intake. Is that okay?
jeremy1122 is offline   Reply With Quote
Old 03-31-2013, 11:23 AM   #9
findurpath
Member#: 277487
2006 CGM WRX Limited
6sp, 18G, Phatron tuned
I didn't know Manuel made boost controllers.
findurpath is offline   Reply With Quote
Old 04-03-2013, 12:56 PM   #10
mikeydrives1
Member#: 262117
No need for a manual controller on these cars. Subaru didnt spend all that research and development into their EBCS system for nothing, expecially on these newer models. The turbo dynamics system, stock for stock, will work to always achieve your target boost whether your doing WOT pulls on cold winter mornings or on hot summer dog days. You would have to make adjustments to the manaul for changes in seasonal weather (cold=boost spikes, hot = undershooting target boost)
mikeydrives1 is online now   Reply With Quote
Old 04-03-2013, 01:48 PM   #11
jthatch12
Member#: 321715
03 Big 16G WRX
You sir have never considered a hybrid boost control setup!
Old 04-03-2013, 05:54 PM   #12
mikeydrives1
Member#: 262117
^^ I have not yet, i may be a little behind the times these days.
Only experience i have with a manual controller was with an old turbo'd Singlecam Civic of mine way back in the day. It was a bit of a pain to make adjustments, constantly stopping, popping the hood, and redialing it. The moment i sat down in a subaru and found out it was done all by the click of a mouse, i was hooked.
Old 04-03-2013, 09:07 PM   #13
Franko
Member#: 193628
2010 STI
SSM
Manual boost controller is not necessary. I had one on my 08 wrx just trying out stuff and there was no real benefit to having it.
Manual boost controller:
-Easy to set desired boost level
-Pretty cheap
-Easy to install
Benefits of using oem boost solenoid
-Better control for boost levels when weather changes
-If detonation is present from a bad tank of gas the ecu can reduce boost level and save the engine
-Can run different boost levels in different areas of map.
-Tuned properly can reduce lag.
My suggestion? Go with a 3 port boost solenoid. The gm boost solenoid works very well or even better is the grimmspeed boost solenoid. Very nice product and installs nicely.
The 3 port has way better control over boost than the restrictor pill bleed setup that subaru has stock and with proper tuning makes the turbo spool a lot sooner and will hold boost better into higher rpms.
A worthwhile upgrade in my opinion.
Franko is offline   Reply With Quote
Old 04-04-2013, 01:30 AM   #14
aberg12012
Member#: 127614
2008 WRX
Obsidian Black
I really wish no one would respond to this thread. OP admits to posting while driving in a public forum. Do we really want to give a guy like that advice on how to make his car go faster?
aberg12012 is offline   Reply With Quote
Old 04-04-2013, 03:49 AM   #15
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
blow off valve
dont do that either.
releasing metered air on a maf based car is just not a good thing. there is NO benefit to a bov
Old 04-04-2013, 07:36 PM   #16
jthatch12
Member#: 321715
03 Big 16G WRX
Hybrid setup is awesome, you get the benefits of both worlds. Rock solid (constant) peak boost with taper to redline. Plus the manual boost controller stops over boosting. Win-win in my eyes
Old 04-05-2013, 01:46 PM   #17
M///Scooby
Member#: 28117
2012 WRX
Really...GTFO
M///Scooby is offline   Reply With Quote
