Welcome to the North American Subaru Impreza Owners Club Saturday December 20, 2014
Old 03-31-2013, 06:15 PM   #1
WISKO
Member#: 346124
2002 ej20
suby blue
Default wrx 02 420 injectors to sti 05 side feed 560 injectors Remapping help
ok so i installed a set of yellow side feed sti injectors off a 05 sti into my 2002 wrx.
-results...... sputtering at 5k rpms and coulding proceed after 5k.
Today my friend brought over his gear to help me remap my ecu...
-what we did..... took stock map and modified the fuel injectors from 420cc to 519.99cc
results........ really smooth, no sputtering at 5k rpms, followed threw almost 7krpms nice and strong before i ran out of road.....
my question to you guys is how does these numbers look im currently researching them right now but thought about uploading it here to see
if anyone had any exp. or advice on the topic
thanks in advance for you help
420cc
520cc
WISKO is offline   Reply With Quote
Old 04-01-2013, 10:46 AM   #2
dux10
Member#: 235338
2002 Faggin Wagon
srp
did you change the latency values?
Steve @ Pullz-On Tuning
dux10 is offline   Reply With Quote
Old 04-01-2013, 02:24 PM   #3
obi10
Member#: 303092
2002 Impreza WRX
would the voltage matter if I copied the 05 sti injector scaling and latency to the stock 02 wrx rom? They both are using similar and different voltages.
obi10 is offline   Reply With Quote
Old 04-01-2013, 03:26 PM   #4
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
Copy the latencies from the 05 rom. Modify the voltage range and latency values.
endrswrd is offline   Reply With Quote
Old 04-01-2013, 03:51 PM   #5
obi10
Member#: 303092
2002 Impreza WRX
trying to modify the voltage range but it won't let me, but I did modify the latency values.
Old 04-01-2013, 04:42 PM   #6
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
I can modify the voltage headers just fine. Do you have user level turned up to advanced(or w.e the highest level is?)
Old 04-01-2013, 04:52 PM   #7
obi10
Member#: 303092
2002 Impreza WRX
ttttttttttttt
Old 04-06-2013, 12:07 AM   #8
WISKO
Member#: 346124
2002 ej20
suby blue
finally got back from work
we left the latency alone stock latency from 02
so i should change voltage and latency to 05 settings?
and make sure im on advance user?
because we did have trouble changing the voltage so we left it stock set.
again thanks for the help
