Old 04-06-2013, 05:10 AM   #1
Jacobpockros
Member#: 346610
2001 Legacy GT 5-spd
Default What are my Final Drive options?
Just bought a 2001 Legacy GT Limited Sedan 5-Speed. I love the car but need a lower final drive for gas mileage.
From searching the forum, I found that it uses a 4:11.
The base model 5-Speed of the same year uses a 3:9. Is this the lowest ratio rear diff that can be swapped in or is there anything else with a lower ratio than 3:9 that's bolt in?
Also, would I need only a Rear Diff or both Rear and Front?
Lastly, does lowering the Final Drive cause ANY incorrect Speedometer or odometer readings?
Please get back to me guys.
Thanks,
- Jake
Jacobpockros is offline   Reply With Quote
Old 04-06-2013, 09:21 AM   #2
Duvanator
Member#: 217257
2008 2.5i hatch
Satin White Wrap
You would need both front and rear. And the front diff per say is in the transmission, so it would involve opening and swapping the required cogs/parts.
If you were to do just the rear say goodbye to the center diff lol
Duvanator is offline   Reply With Quote
Old 04-06-2013, 09:24 AM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
1-You need to do both diffs, front & rear, if you want to last more than a few miles on pavement.
2-Yes, you will have a speedo/odometer error unless you change parts.
Cheaper/easier would be to run a taller tire than stock. What kind of mileage do you get now?
Old 04-06-2013, 02:53 PM   #4
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Unfortunately your car won't ever get "good" mileage. However if you want to keep the car then yes you might want to switch to the 3.9 final drive. As mentioned above, you will need both the front and rear diff.
I like the taller tire option except you are going to be limited in how tall you can go while raising your profile will cause greater wind resistance.
geronimo81 is offline   Reply With Quote
Old 04-06-2013, 06:58 PM   #5
silverton
Member#: 331131
2001 2.5RS
STM
honestly, I'm impressed my '01RS gets 23-24mpg, being a 2.5L 4 cylinder with a 4.11 and all wheel drive.
silverton is offline   Reply With Quote
Old 04-06-2013, 11:00 PM   #6
Jacobpockros
Member#: 346610
Okay. Thanks guys
Old 04-07-2013, 01:46 AM   #7
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
That's highway mileage? I used to get 28-29 on the highway with 17's on my RS
Old 04-07-2013, 02:16 AM   #8
Jacobpockros
Member#: 346610
Sounds predictable.
Old 04-07-2013, 03:38 PM   #9
Grindbeard
Member#: 323512
2002 Outback Sport
Shame you live in CA, I'd be more than happy to swap my 3.90 for your 4.11!
Grindbeard is offline   Reply With Quote
Old 04-07-2013, 04:48 PM   #10
silverton
Member#: 331131
2001 2.5RS
STM
Mixed. it gets 29.5'ish when it's all freeway.
Old 04-09-2013, 08:57 AM   #11
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Originally Posted by Jacobpockros View Post
Okay. Thanks guys
What are you getting for mileage??
I have a 98 GT wagon and usually get 22MPG mixed driving. Highway driving is almost always ~80MPH.
I had ~27MPG when all highway and back down the speed a bit.
Old 04-09-2013, 01:38 PM   #12
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
From searching the forum, I found that it uses a 4:11 4.11:1.
The base model 5-Speed of the same year uses a 3:9 3.90:1. Is this the lowest ratio rear diff that can be swapped in or is there anything else with a lower ratio than 3:9 3.90:1 that's bolt in?
The '06/07 WRX used a 3.70:1 final drive. The 5MT was changed a bit somewhere in the 2004/05 range, so I don't know if the newer 3.70 gears would fit in your older 5MT. I think they would, but I imagine you'd get better answers in the Transmission & Drivetrain forum.
As others have said, you would need to change both front and rear diff ratios. The easiest way to do this would be to just swap out the complete units (transmission and rear diff). That should mean there wouldn't be any speedo/odo issues. The gear ratios for the non-2.5GT transmission are exactly the same, just the final drive is different. According to cars101.com, the '01 2.5GT had a rear LSD and the L did not, so swapping to the L rear diff would mean that you lose the LSD. Not the end of the world. If you really cared about keeping the rear LSD, then you would need to swap just the ring and pinion onto your existing LSD rather than swapping out the entire rear end.
Another option, rather than changing the final drive ratio, would be to swap out just the 5th gear. The WRX 5MTs have a 0.738:1 5th (compared to your 0.780). That would give you the same drop in highway RPMs (with 10 or 20rpm) as going from 4.11s to 3.90s, yet wouldn't saddle you with the more sluggish performance in 1st thru 4th. I'm pretty sure the WRX 5th gear from the same generation would fit into your tranny, but again there are more knowledgeable folks in the correct forums that would be better to ask.
