Old 04-03-2013, 03:02 AM   #1
bugeye212
Member#: 325411
Default 2002 impreza misfire codes
Engine misfiring with little to no power behind the engine with misfiring at idle and runs like garbage. I thought it was the fuel system and replaced the pump with a walbro, and fuel filter at the same time, next replaced the plugs which helped for a few days and replaced the coil pack with a new one from autozone but did not help and returned it. The problem remained intermittent and got worse with a few days of time. Then I replaced the map sensor, yet no luck. Just purchased a OBD-II system reader from harbor freight instead of wheeling her into the dealer hoping I can find and fix the problem cheaper after buying my own scanner, and if not I got a scanner for next time I need to clear some codes or read CEL lights.. Throwing code P0172 which reads fuel bank 1 running too rich. Fuel SYS1 is stuck in CL. short term fuel trim anywhere from -18.6% to -20.04% Long term fuel trim -14.1% to -25%. Also getting a steady 0.000 volts from O2B1S2 and steady over 2V from O2B1S1. O2 sensors giving false readings? Vacuum leak somewhere on intake? Leaky injectors? Any input would be helpful or what is common on these cars.
bugeye212 is offline   Reply With Quote
Old 04-03-2013, 11:05 AM   #2
bugeye212
Member#: 325411
Any ideas anyone?
Old 04-03-2013, 05:05 PM   #3
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
What are the mods? Is the stock uppipe still on with the cat? do you still have the stock exhaust with cats? How many miles are on the car?
Old 04-04-2013, 05:56 PM   #4
bugeye212
Member#: 325411
125K miles. No mods all stock with a K&N. Car is from California, emission standards stock exhaust I think there are two cats on the exhaust
Old 04-05-2013, 01:23 PM   #5
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
The uppipe has a cat and that needs to go first. If that isn't your problem I would check the rest of the cats.
(I have been corrected no turbo my mistake) thanks Charlie
Old 04-06-2013, 04:03 AM   #6
Bababou
Member#: 280689
2010 2.5i Impreza
Newport blue
Check for exhaust leaks. My buddys 02 was showing the same codes, after he finally got several exhaust leaks taken care of the codes cleared.
Bababou is offline   Reply With Quote
Old 04-06-2013, 08:29 AM   #7
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
1-Why the comments regarding an up-pipe?? This is a NA section, thus no turbo!!
2-When was the last tune-up (plugs, wires, etc)? What was used (brand/type) for the tune-up?
Old 04-09-2013, 10:25 AM   #8
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
It still sounds like cat problem.
