Old 03-30-2013, 01:30 AM   #1
myk
Member#: 223143
2001 2.5rs Sedan
Brack
Default innovate wO2 what cable for serial to usb?
Have a mtx-l wideband setup and the new laptop has no serial port. The gauge had a db9 serial plug on it and I want to convert that to usb but I'm not certain what cable to use. I know I need a db9 to usb but which kind? Heard it needs to be "null modem" type, not sure if that's correct or not.
I know innovate carries a cable but it's kind of pricey, eBay has quite a few db9 to usb cables for a fraction of the price.
myk is offline   Reply With Quote
Old 03-30-2013, 07:01 AM   #2
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
All I did was go to the local computer store and buy a serial to USB converter. There were not multiple types, just multiple brands. It has worked for me for years now.
jebjkey is offline   Reply With Quote
Old 03-30-2013, 10:54 AM   #3
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
Buy a Keyspan High-Speed USB/Serial Adapter, USA-19HS (just copy and search online)
It may be a little more expensive but they work.
Some of the prolific based adapters have driver issues.
Old 03-30-2013, 11:55 AM   #4
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Busted finger motorsports sells cheap ones. Best buy sell them for a lot
wrxsubiemod is offline   Reply With Quote
Old 03-30-2013, 07:33 PM   #5
Illicit1
Member#: 68372
Don't bother with the bustedfinger motorsports cable, I struggled with it for months with no success. Bought a different one from an electronics shop and it worked first time.
Illicit1 is offline   Reply With Quote
Old 03-30-2013, 09:20 PM   #6
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Which one so you can help the guy
Old 03-30-2013, 09:38 PM   #7
myk
Member#: 223143
2001 2.5rs Sedan
Brack
Lol yeah, I just want to make sure the one I get will work. There is db9 to usb adapters for 5 dollars to 50 dollars and I heard the cheap ones don't always work. If someone wants to post/pm me a link to one they know that works that would be awesome.
Old 03-30-2013, 09:48 PM   #8
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Mine worked from best buy but it cost me $50
I also had to download a prolific file for the cable
Old 03-31-2013, 01:46 AM   #9
JonnyV2889
Member#: 197384
2006 WRX Ltd
Ordered up the PLX board and wired it up but haven't got it working yet since I borrowed a staples one. Either way the staples one is still finicky. Make sure you set the bod rate in the hardware (pc) correct or you'll never get the thing to work right.
JonnyV2889 is offline   Reply With Quote
Old 03-31-2013, 03:18 AM   #10
Illicit1
Member#: 68372
Yeah sorry mate.
The bustedfinger cable uses the prolific drivers which can apparently be a bit iffy. I tried every version of the drivers on the net and couldn't get it to work so I bought a cable with a FTDI chip, worked first time.
This is it, australian website though:
http://australia.rs-online.com/web/p...633D4E4F4E4526
Old 04-01-2013, 04:45 AM   #11
aberg12012
Member#: 127614
2008 WRX
Obsidian Black
This is what i use. It did take some fiddling at first due to romraider being a bit flaky with com ports but has been working ever since.
http://www.Newegg.com/Product/Produc...tem=12-156-039
aberg12012 is offline   Reply With Quote
Old 04-01-2013, 01:40 PM   #12
myk
Member#: 223143
2001 2.5rs Sedan
Brack
Went ahead and ordered one with a ftdi chip, sabrent, along with a obd2 cable extension. Had to resolder my usb port on my tactrix cable, bastard just popped off the board.
Old 04-02-2013, 02:33 AM   #13
aberg12012
Member#: 127614
2008 WRX
Obsidian Black
Good call on the OBDII extension. Best few bucks I ever spent.
Old 04-07-2013, 07:06 PM   #14
myk
Member#: 223143
2001 2.5rs Sedan
Brack
This is what I picked up in case anyone has the same issue. Worked fantastic. Thanks for the input everyone.
