Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 04-04-2013, 08:40 AM   #1
littlesnides
Member#: 283007
Default UTEC firmware update fail
So generally I am a lurker. I bought a car that had some mods and a very poorly done stage 2 tune on the utec. I recently added a 16g and an uppipe. I followed directions to update my utec to 5.8 so I could limp around on a stage 3 until I got my injectors and wideband in the mail. Well When I tried uploading from the flash tool, it started then failed. I tried multiple techniques in updating. It updated for almost 5 minutes one time before failing. Now I can't communicate with my UTEC at all. I get an error about no devices on com port 1. The car ran before, but now the car won't start. I get no CEL blinks before startup now. I will probably try removing the UTEC later today. Any ideas? Going to try and call TXS later today. Thanks for any positive input.
littlesnides is offline   Reply With Quote
Old 04-05-2013, 01:36 PM   #2
dbudny_13
Member#: 231869
I had the same problem with mine not to long ago. Cant remember for sure but I think mine kept failing when I'd try to verify the flash, so I eventually just skipped that step, hit update and it worked. Thats what I remember doing off the top of my head... could be wrong, worth a shot though! lol Hopefully you get it working!
dbudny_13 is offline   Reply With Quote
Old 04-05-2013, 02:29 PM   #3
littlesnides
Member#: 283007
I tried that :-/
two different computers, going to get another serial cable and try
Old 04-05-2013, 02:37 PM   #4
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
you can try bench flashing it with the 9v adapter, that will rule out a bad power connection with the ecu wiring.
Old 04-05-2013, 02:38 PM   #5
littlesnides
Member#: 283007
yeah, i will probably try that next, it logged fine and connected before i tried the update
Old 04-05-2013, 03:52 PM   #6
dbudny_13
Member#: 231869
I use a serial to usb cable to hook up to my laptop and sometimes hyperterminal wont recognize what com port Im using so I'll have to switch ports. but if youre still using just the serial cable you probably only have one port you can use.
Old 04-05-2013, 06:32 PM   #7
littlesnides
Member#: 283007
yep, one serial port, assuming its com port 1 on both laptops, unfortunately my desktops are without the serials
Old 04-06-2013, 07:36 PM   #8
littlesnides
Member#: 283007
tried bench tuning with a 9 volt source, no luck, same error as before. It doesn't even respond anymore :-/ any other ideas other than sending it to turboxs... I shouldve known this crap always happens to me
Old 04-06-2013, 09:51 PM   #9
littlesnides
Member#: 283007
read another thread about this happening, ultimately got sent to turboxs... I may try a couple other things, change the handshake settings of the com port and maybe see if I can get my hands on windows me or 98
Old 04-07-2013, 09:52 PM   #10
littlesnides
Member#: 283007
no luck with xp, anyone know how to change com port settings for the "handshake" from auto to manual?
Old 04-19-2013, 07:58 PM   #11
littlesnides
Member#: 283007
Just to wrap up, processor went bad, assuming it was from my multiple tries to reflash...
