Welcome to the North American Subaru Impreza Owners Club Saturday August 29, 2015
Old 03-22-2008, 10:29 PM   #1
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
Default Synapse EWG install help
ok i just got a synapse ewg....now all i need to do is figure out where to run all the vac lines for the prodrive bcs.
This is what i was told first:
From top to bottom you have Ports A, B, C & D
Like any regular wastegate Ports A&B are the top port, and keep the wastegate closed
Like all other wastegates Ports C&D are the bottom port, and open the wastegate
1) Run a boost-only source (from the compressor) to either port C or D. You choose the port to setup your lowest, fail safe boost level.
2) Tee off that port and run it to the the boost control solenoid (BCS). You will connect it to the port on the BCS that you cannot blow through
3) On the BCS, there is a port that opens up to the closed port when it is energized.
4) Connect that port #3 on the BCS, to A&B tee'd off together
5) When you program the duty cycle percentages, the more duty cycle you give it, the higher the boost.
But i was looking around on how people did installs of their ewg...and everyone says to run a vac line from the turbo to the bottom of the ewg, and tee that off and run it to the silver port on the prodrive bcs, then run another line from the top port on the bcs to the top port of the ewg, and the other port to the intake.
these 2 ways are contradicting...anyone with a clear answer?
vanillajuice is offline   Reply With Quote
Old 03-22-2008, 11:40 PM   #2
testes1010
Member#: 47145
2012 Gas Saver
Good LUCK!!!! The Synapse is NOTHING like a Tial, Turbosmart, HKS, etc.
A buddy of mine runs one of these & we've been fighting it from day one. He spent countless hours on the phone with their tech support to finally their tech support saying 'we think we got it figured out'. We were trying to run it with a GM BCS using a single port, you would think it would be an easy hook up. Problem after problem, we'd get it to work properly if you went WOT, but if you 'rolled' into the boost the WG wouldn't open at all. Then his motor went out & he's been breaking the new one in for the last few weeks w/o boost.
The thing totally over engineered, I'm surprised it doesn't change your oil for you or spit shine your wheels too. For anyone looking into getting one, I'd recommend against it. Go with a the tried & true Tial. There is something said for a simple device doing a simple job.
testes1010 is offline   Reply With Quote
Old 03-22-2008, 11:50 PM   #3
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
greaaaaaaaaaaaaaaat....i read someone had that exact same problem on synapse's forum....250 dollars later......im hoping it will work better for me
Old 04-02-2008, 09:52 PM   #4
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
well its goin in on sunday...wish me luck....
Old 04-03-2008, 11:36 AM   #5
ToxicSlick
Member#: 73659
Bump for pics once it is installed!
*Stolen from honda-tech
Update for advanced boost control strategy
I recommend that you only use this configuration if you are an experienced tuner. Using port B has the potential, in all but one configuration, for the wastegate not to open under boost. This is why we don't supply a fitting for it or have it in the general instructions.
Hondata or AEM EMS or Motec or other ECU using a GM boost control solenoid -
1) Determine which of the six combinations of Port A, Port B and Port C you would like to use to produce your lowest desired boost pressure.
2) Connect a boost signal source to GM solenoid input, connect the output to Port B (unused port).
Ideally, 1 and 2 would have their own individual port on the intake manifold.
I have to credit Harvey at Holeshot Racing for nailing down and testing this configuration. You know your ***** Harv, he understood it in the first 5 minutes he played with the Synchronic Wastegate.
ToxicSlick is offline   Reply With Quote
Old 04-03-2008, 05:48 PM   #6
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
ya the first post i had is directions straight from synapse...so it should work.
oh and this site doesnt let me put up pics in posts. so there wont be any unless u go over to wrxtuners.com
Old 04-06-2008, 06:33 PM   #7
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
ok got it installed. with 0% wgdc its runnin about 10psi. Perfection!!!! lets see how increasing the wgdc works
Old 04-06-2008, 06:43 PM   #8
ToxicSlick
Member#: 73659
Nice, got any pictures of how it was welded up? Any issues with fitment? What combination of ports are you using to get 10 psi?
Sorry about all the questions but I have one of these in my shop waiting to be tig'd into place.
Bump for a better mousetrap!
Old 04-06-2008, 07:00 PM   #9
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
I used the grimmspeed ewg uppipe. welds are great, fitment is perfect! the dump pipe is about a finger distance from the axle and its heat coated so its great. From the compressor i ran a vac line to a tee, then from that tee went to the bcs and port D on the ewg. And the top port on the bcs i sent to Ports A&B teed together. Its pretty much exactly like it says in the tuning manual that came with the wastegate(there is a chart that shows how much boost u will bet when running from the compressor to each port). and holy $h!+ my car sounds HELLA MEAN!!!!!!!!!! and no i didnt get any pics. not that i could put them up here anyways haha.
Old 04-08-2013, 07:07 PM   #10
Amoehlau
Member#: 346085
2006 WRX
Sorry to pull this thread from the dead but I cant find the info I'm looking for anywhere. I also have a synapse ewg and I would like to adjust it but I cannot find the manual anywhere online. Do you still have access to the tuning manual vanillajuice? I found a chart online for a 50mm but mine is 40mm. Any help would be appreciated.
Amoehlau is offline   Reply With Quote
Synapse Synchronic installed successfuly on Sti TMIC Vlad Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 06-02-2012 05:42 PM
anyone use a synapse ewg 50mm gtasti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 11-04-2009 11:51 AM
Help with EWG install (Addison, IL) Shan Man Mid West Subaru Owners Club Forum -- MWSOC 13 12-25-2008 06:32 PM
Help with EWG install, BCS question!! litowrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-04-2008 04:25 AM
EWG install help needed deblas66 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 23 08-14-2006 02:58 PM
