Welcome to the North American Subaru Impreza Owners Club Sunday December 4, 2016
Old 01-06-2012, 12:07 PM   #1
Bizarre11
Member#: 196910
Default 2011 wrx shifter bushing install
hey everyone, im in the process of installing kartboy front and rear shifter bushings on my 2011 wrx but cant seem to get the stock front bushings off. i have searched and have not come across any tips on how to get this done. just wondering if anybody has any suggestions on how i can get the 2 circular rubber bushings out?
Bizarre11 is offline   Reply With Quote
Old 01-06-2012, 12:10 PM   #2
MyNameIsSouthpaw
Member#: 267250
2002 Subaru WRX
Grease, pliers and lots of pulling/twisting. Took me about 30 minutes to get mine free. Wedge a flathead screwdriver between them to create space too.
MyNameIsSouthpaw is offline   Reply With Quote
Old 01-06-2012, 12:48 PM   #3
Member#: 67
1999 Outlasting
the competition.
pull the large washer off. hand tighten the nut back on. then pull the shifter stay. the bushing should pull right out.
Tom
tom@kartboy is offline   Reply With Quote
Old 01-06-2012, 01:02 PM   #4
Bizarre11
Member#: 196910
Tom
Doesn't seem to work
Old 01-06-2012, 01:07 PM   #5
Member#: 67
1999 Outlasting
the competition.
eat your Wheaties beforehand.
Old 01-06-2012, 01:11 PM   #6
JordenP
Member#: 305041
2013 STOCK WRXSDN
It is not 2 seperate bushings, it's one big one. I found it easy to gab one side with wide grip pliers, an wedge a flathead in the other side to get the rubber flange bent and under the collar. Then pull and slides out.
JordenP is offline   Reply With Quote
Old 01-06-2012, 01:42 PM   #7
Bizarre11
Member#: 196910
got it off, thanks guys
Old 02-04-2012, 12:30 PM   #8
awdboxer
Member#: 38425
2015 WRX
Lightning Red
Now how about that rear bushing? I'm having a super hard time getting it on. I have the shifter out, downpipe off (was replacing it anyways), and I still can't get both screws in there. I started the passenger side screw but whatever I do, it just doesn't seem like the other one will start to thread.
Any tips?
awdboxer is offline   Reply With Quote
Old 02-04-2012, 02:27 PM   #9
Member#: 67
1999 Outlasting
the competition.
the screws are not parallel to the ground. rather to the mount itself. its at a slight angle. Rather perpendicular to the mounting surface.
It'll go in. just be patient.
Tom
Old 02-04-2012, 03:24 PM   #10
rhino6303
Member#: 181314
2005 Impreza OBS SRR
05 Legacy GT RBP
I had the same issue on my lgt. The bolts for the rear bushing just wouldn't start. One stripped the threads. Luckily I was able to fit my tap in there with a flexible extension and my drill. Like Tom said, be patient and it will eventually get started.
rhino6303 is offline   Reply With Quote
Old 02-05-2012, 01:54 AM   #11
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
you guys getting that ringing noise around 3000 rpm in 2nd too, right?
tried different tightening torques and it's all the same. outside of this, lovin' the bushings.
Nimbus09 is offline   Reply With Quote
Old 02-05-2012, 12:01 PM   #12
awdboxer
Member#: 38425
2015 WRX
Lightning Red
Tom
I messed with that rear bushing for a frustrating 2 hours, my friend comes over and gets it mounted in 20 mins It feels awesome and no noises!
Old 03-11-2012, 12:35 PM   #13
A Fatal Ode
Member#: 243616
2010 WRX 336/384
2006 STI 627/484 2015 BRZ
how have to take the DP off for the rear bushings?
A Fatal Ode is offline   Reply With Quote
Old 03-11-2012, 09:13 PM   #14
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
for the front i just pushed the bushing against the stud it mounts to. came off in about 15 seconds.
bluemax189 is offline   Reply With Quote
Old 05-20-2012, 05:45 PM   #15
Kirby11WRX
Member#: 316753
2011 WRX Stage 2
Was it really necessary to take off the DP for the rear?
Kirby11WRX is offline   Reply With Quote
Old 05-21-2012, 09:36 AM   #16
fastsubie
Member#: 21999
2017 Wrx
No you do not need to remove the DP. I've done front/rear bushings in a 11 and 12. The rear can be difficult to get started. Like Tom said you have to get the angle of the bolt correct. Having good lighting under the car is a must.
fastsubie is offline   Reply With Quote
Old 12-12-2012, 10:13 PM   #17
Giibo
Member#: 227637
2014 Minivan Driver
Broke a bolt trying to install the rear bushing...its gonna be a royal PITA getting it out. The problem was with the bolts angle. The left bolt seemed rather easy but the right was super difficult because of the other side semi bolted. I torqued a bit harder than I should and snap! The bolt head came right off.
The fronts were rather easy compared to the rear.
Giibo is offline   Reply With Quote
Old 01-04-2013, 03:45 PM   #18
luan87us
Member#: 335013
2013 Premium WRX 5dr
I want to get a set of Kartboy Front and Rear shifter bushing for my 2013 WRX but all this problem installing it kinda scares me off.
Old 01-04-2013, 06:36 PM   #19
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Don't be a such a little weenie. If you're scared, get a hold of some peeps in your local sub forum to help you out. Or, if you want to bee even more of a weenie, you can take it to a shop and pay to have them installed. Either way, don't weenie out and not buy them, they are a great upgrade and will really improve the feel of your shift lever.
RoadKillDMD is offline   Reply With Quote
Old 01-08-2013, 03:06 AM   #20
MaddMax
Member#: 9264
2016 BMW M235i 6MT
Get the $18 STI rear bushing and you'll have absolutely no issues with threading the bolts. The STI bushing is light years stiffer than the stock one.
Old 01-08-2013, 09:20 AM   #21
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Here are some photos that show the "issue" with the Kartboy bushing. The mounting surface isn't flat like the bottom of the bushing. The bushing has to flex a little to get the bolts properly lined up. Make sure you start the bolts by hand and don't cross thread them! Once you get it started it's easy, but if you go in crooked and force it, then you'll damage the threads and be in trouble...
Yes, the holes are basically in the right spots, they're just not quite the right angle. It's very close though. Once you get them in it's fine, it's just making sure you get them started properly. Here are some photos I took where you can see the very slight difference:
Overall the install for both the front and rear bushings is not hard. You don't have to remove the downpipe. For the front one you just have to use some muscle to get the soft OEM one out. If you know what you're doing you could probably install both the front and rear in 20 minutes.
Old 03-02-2013, 03:00 PM   #22
MtnXfreeride
Member#: 228010
2012 WRX Prem Hatch
Dark Gray Metalic
I have a few questions on this install before I try it (parts are on the way).
1. Are you guys popping the shifter down and removing it from the car to replace the front bushings? Is that necessary? As seen in this video:
2. From the pics above it looks like angling the screws inward towards the center of the bushing lines them up correctly - is that something anyone noticed in doing theirs?
3. I see varying tools between installs, what tools were needed for your install?
I have handy: Ramps, torque wrench, ratchet with 6" extension, white lithium grease, screw drivers in various sizes, a set of regular wrenches (non ratcheting), pliers. And Ill go buy some loctite beforehand.
MtnXfreeride is offline   Reply With Quote
Old 03-25-2013, 04:17 PM   #23
goleee33
Member#: 301701
2012 WRX 5-Door
I cannot get these bolts to thread for the life of me. This is as far as i got the other side in. It looks extremely off. Did not want to keep going? Anybody have some better tricks? Been at it for about 30 minutes and cannot figure this out.
goleee33 is offline   Reply With Quote
Old 04-09-2013, 12:35 AM   #24
furiouswrx
Member#: 283048
2011 WRX Ltd Hatch
Start with the passenger side bolt first and thread a little bit of it in. Then put in the driver side bolt and thread a little of it in. Repeat. The key is to start with the passenger side bolt and make sure the bolts are perpendicular to the mounting surface. Do not use the bushing or the ground as a reference, because the mounting surface is not perpendicular to either.
It took me a good hour to do the bushings..just be patient and make sure you have a reversible ratcheting 12mm wrench and a stubby driver with 12mm socket handy. A regular 12mm wrench or ratchet with extension helps too.
furiouswrx is offline   Reply With Quote
Kartboy Shifter Bushings install experience on 2010 WRX BargainBoy Transmission (AT/MT) & Driveline 11 01-01-2012 02:38 AM
Shifter Bushing Install Notes Ramsdale Transmission (AT/MT) & Driveline 7 10-22-2001 10:40 PM
Shifter Bushing Install Mantis69 Normally Aspirated Powertrain 0 09-23-2001 07:49 PM
('93-'01) New step in the shifter bushing install gaylemd Impreza Forum 1 04-22-2001 09:42 AM
