Old 04-07-2013, 06:47 PM   #1
dIrTy-StI
Member#: 322280
2002 Subaru WRX
Default 2002 wrx hitting only 6psi
Ok yesterday i installed a mbc into my car and decided it wasnt worth the risk since the car hit almost 20psi. I took the controller out of the car and reverted everything back to stock and now the car will only hit 6 psi. When i did instal the controller i had forgot to unplug the factory boost control solinoid when i had the mbc installed. Is the reason i am hitting low boost have to do with a possible burnt out factory solinoid? Any input would be amazing since i love driving my car and this is depressing haha.
dIrTy-StI is offline   Reply With Quote
Old 04-08-2013, 02:01 AM   #2
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
You left the pill out or you installed it wrong.
Old 04-08-2013, 06:50 AM   #3
dIrTy-StI
Member#: 322280
2002 Subaru WRX
I think i did leave the pill out, is it hard to get the pill back in?
Old 04-08-2013, 09:19 AM   #4
SheaREX
Member#: 348373
2004 Impreza WRX
World Rally Blue
No. Just take the hose off the turbo compressor nipple, slide the pill in there. Make sure the pill is located in the hose off the "T" to the turbo, not the wastegate hose off the "T". Good luck!
SheaREX is offline   Reply With Quote
Old 04-08-2013, 08:32 PM   #5
dIrTy-StI
Member#: 322280
2002 Subaru WRX
Got it, put the pill back in and everything is working fine
Old 04-09-2013, 01:07 AM   #6
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Surprise
Old 04-09-2013, 10:44 AM   #7
Member#: 301037
2004 Forester XT
Good choice on taking off the MBC. MBC without a tune = KABOOM!
art@grimmspeed is offline   Reply With Quote
Old 04-09-2013, 12:10 PM   #8
wrxlaunch
Member#: 181298
Re install the mbc if u wanna use it... dial down to its min setting and adjust in single increments til u reach max stock boost level in 4th gear.
wrxlaunch is offline   Reply With Quote
