Welcome to the North American Subaru Impreza Owners Club Thursday December 8, 2016
Old 04-07-2013, 06:53 AM   #1
bugeyesubie117
Member#: 293656
Default only making 7psi??
I just bought an 03 wrx and it came with a stock boost gauge. It shows the turbo only making about 7psi, just under the .5 on the gauge. What can I do to be sure I run at full boost? What could be making it run like this? it has 117xxx miles.
bugeyesubie117 is offline   Reply With Quote
Old 04-07-2013, 08:42 AM   #2
HonduHunter
Member#: 28408
2002 vf48ed WRX
That's waste gate pressure. You've got a boost control issue.
I believe there should be a pill inside one of the vacuum lines near the turbo. Check and make sure that's there.
Maybe someone else can confirm.
HonduHunter is offline   Reply With Quote
Old 04-07-2013, 04:41 PM   #3
bugeyesubie117
Member#: 293656
It looks like the pill is in the vacuum line. I can post a pic a bit later
Old 04-07-2013, 05:43 PM   #4
sevier2
Member#: 295516
2004 WRX
Are you doing your WOT pulls in 3rd/4th gear? A lot of times the lower gears won't spool to full boost. If you ARE in fact doing pulls in 3rd/4th then yeah you've probably got a boost issue. Possible leak
sevier2 is offline   Reply With Quote
Old 04-07-2013, 06:07 PM   #5
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Boost issue. Running wastegate pressure.
The stock gauge reads in Mpa as a reference.
Check for leaks.
Old 04-07-2013, 10:13 PM   #6
bugeyesubie117
Member#: 293656
I dont hear any vacuum leaks
Old 04-07-2013, 10:18 PM   #7
XLR8T
Member#: 266684
if your IAM is under... 6 i believe?
The ECU discontinues all boost control. period.
Just something to keep in mind.... lol
XLR8T is offline   Reply With Quote
Old 04-07-2013, 11:40 PM   #8
bugeyesubie117
Member#: 293656
Ok so the car was in limp mode, i disconnected and reconnected the battery and now its running on full boost. Will the car go back into limp mode and if it will how do i prevent it?
Old 04-08-2013, 07:36 AM   #9
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
Did you ever check for CEL's?
Old 04-08-2013, 02:55 PM   #10
bugeyesubie117
Member#: 293656
I have a code reader, ill check today when im free
Old 04-08-2013, 03:58 PM   #11
shano
Member#: 223839
2004 WRX
Java black
check all vaccum lines around near the turbo. So many of those darn things.
shano is offline   Reply With Quote
Old 04-08-2013, 06:33 PM   #12
bugeyesubie117
Member#: 293656
All the lines are good and not leaking
Old 04-08-2013, 11:06 PM   #13
bugeyesubie117
Member#: 293656
everything looks connected
Old 04-09-2013, 07:46 AM   #14
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
FYI you won't really hear a leak if there is one. Try replacing the hoses and see what that does. Most of the time the crack is beyond tiny enough to see.
Old 04-09-2013, 11:47 AM   #15
Member#: 301037
2004 Forester XT
Check this article out. It may help you fix the problem
http://www.cobbtuning.com/Technical-...es-s/70674.htm
art@grimmspeed is offline   Reply With Quote
Old 04-09-2013, 02:04 PM   #16
bugeyesubie117
Member#: 293656
Thank you!!
