Old 04-07-2013, 06:09 PM   #1
atyourfuneral
Member#: 264167
2005 Impreza STi
Default High pitch noise almost like belts but not belts??
Friday my car started to make this really high pitch noise after I drive for about about 2 minutes. It is very similar to belt noise but is not the belts. It is very faint on idle and then off idle is when you really hear it. I took off belts also replaced the alternator and idle pulley for ac today and noise is still there. Will not make the noise until you drive maybe a mile down the road. Then every time you give it has its there.
I have read a few things about uppipe leaks making a noise but I figured that would be mainly when I'm under boost or really giving it gas. It has gt spec headers and up pipe, downpipe, intake, turbo inlet. This is on my 2002 wrx. Sound similar to anyone's experience? Thanks in advance.
atyourfuneral is offline   Reply With Quote
Old 04-07-2013, 10:12 PM   #2
a gasket leak can sound like a whistle or a 'kazoo'
Old 04-07-2013, 11:17 PM   #3
philly15
Member#: 223137
14' super ultimate
race car project
take the belts off all together and start it quick see if it makes noise if it doesnt its something run by the belts, also is it a constant noise or does it get louder/faster with acceleration
philly15 is offline   Reply With Quote
Old 04-08-2013, 04:12 PM   #4
atyourfuneral
Member#: 264167
2005 Impreza STi
Took both belts off and still have noise. Believe its coming from the timing belt. I had an oil change done and see where some oil must have spilled on the timing cover. Do you think that oil on the timing belt could cause noise. When I get the car put back together ill make a recording of the noise.
Old 04-09-2013, 02:59 PM   #5
wrxpotter
Member#: 344825
I have been experiencing a similar issue. I'm getting a "squeak" noise randomly at idle that is indiscriminate of RPM and also very randomly while driving. My belts are all in excellent shape. Interested to see what you find out. I will be investigating further tomorrow.
wrxpotter is offline   Reply With Quote
