Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Old 02-15-2013, 10:58 PM   #4951
Shawn S
Member#: 130665
2013 Veloster Turbo
2006 Z51 Corvette
Just so everyone knows, the engine replacement DOES show up on a CARFAX report.
Something to keep in mind when you go to sell your car.
I recently traded my 2009 WRX and the dealer where itís for sale now has the CARFAX posted for the car.
Note the report at 47,775.
Shawn S
Shawn S is offline   Reply With Quote
Old 03-31-2013, 06:55 PM   #4952
cmattfletcher
Member#: 337068
2009 Impreza WRX
Exclamation
I purchased a stock 2009 WRX on 10/22/12 and I experienced a second (2nd) engine failure on 02/25/13.
Problem: Extremely excessive oil consumption.
Mileage: 58,025
VIN: 9G809474
Build Date: 10/08
Official cause: Leak down test: CYL 1 is 65% CYL 2 is 28% and CYL 4 is 28% only CYL 3 is 5% - removed motor and cylinder head to inspect pistons, found cracked.
Fix: Replaced cylinder 1/2/4 pistons
Time out of service: 24 days... 02/25/13 - 03/21/13
cmattfletcher is offline   Reply With Quote
Old 04-09-2013, 02:38 PM   #4953
melm78
Member#: 290919
Default Again???
Had my bearing spin at 50,051 miles, SOA provided a remaned engine and a year and a half later (27,516 miles) spun again. WTF
melm78 is offline   Reply With Quote
Old 04-09-2013, 02:49 PM   #4954
SWP n Gold
Member#: 110783
2010 WRX
When did you get the first engine replaced? Also, what oil and fuel are you using? Two engine failures due to spun bearings over the course of 75K miles seems out of the ordinary.
SWP n Gold is offline   Reply With Quote
Old 04-17-2013, 10:05 PM   #4955
TuningIsLife
Member#: 191380
2014 Jeep Wrangler
Hydro Blue
I am amazed that this thread is still going.
So my second 09 WRX. Just had the timing belt shredded at 61K mi. No warning, just died on the highway. Guys over at Mach V took a look at it for me.
Never seen a car with a reputation for not breaking have so many issues.
TuningIsLife is offline   Reply With Quote
Old 04-21-2013, 02:44 AM   #4956
Chaconer
Member#: 354064
2009 Wrx sti
Pearl white
Default 09 STI engine failure...new 2 subie land....
I just purchased my car 3wks ago. This last wednesday on my way to wrk
Noticed lose of power and a few miles later tons of white smoke out of the exhaust.
Turns out my #4cyl has 0 compresion and #2cyl has only 60%.
they still havnt pulled engine out to see the damage inside. Dealer thinks this is the en of my motor.
what should I request from the dealer a brand new engine/or rebuilt one.
And is there anything else I should be worried about? I.e the turbo or or transmission?
Thanks for any advice....
2009 wrx sti
49k miles
Apparently had previous engine wrk done @subaru dealer (not on carfax)
Chaconer is offline   Reply With Quote
Old 04-22-2013, 10:35 AM   #4957
Chaconer
Member#: 354064
2009 Wrx sti
Pearl white
Default 09 wrx sti engine or 2010
Hi everyone,
I just had my engine blow about a week ago. I need help trying to figure out whether I should let the dealer rebuild my 09 motor or demad that I get a brand new engine. Ive seen other people get their motor replaced by SOA with a 2010 engine, maybe thats an option
What would ypu guys reccoment? Need some advice please.
Old 04-22-2013, 07:53 PM   #4958
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
2009 wrx sti
49k miles
You can request all you want. The dealer can only do what SOA approves/authorizes.
blackfang is offline   Reply With Quote
Old 04-22-2013, 11:47 PM   #4959
Chaconer
Member#: 354064
2009 Wrx sti
Pearl white
Default What would you be comfortable with?
Yea thats true, but if this happen to you and this was your car what would you accept as a repair? I mean I traded my can and gave 2k as a down payment. I just want to make sure surw that im getting what due.
Thanks again for for any advive.
Old 04-23-2013, 07:49 PM   #4960
blackfang
Member#: 131347
2007 Legacy 2.5i SE
I am the wrong person to ask this question to but so be it
If this was to happen to me, yes I would and here is why. The manufacturer is required to do one thing, fix your vehicle to where it conforms to standards prior to it breaking at no cost to the owner. If that requires a short block, then so be it. If it requires a long block, then so be it. They will also be inspecting the turbo and other components as well to make sure there are no further issues.
There is no need to worry about the transmission as it is a separate component and isn't affected.
Now there is nothing wrong with asking for them to extend the powertrain coverage to 100k being this is a known problem they have had.
Old 04-29-2013, 10:42 AM   #4961
gmancari
Member#: 324631
2015 WRX Premium
Just got my oil sample back from blackstone, they found 5 parts per million of silver in the sample. I realize that engines should have zero, but does anyone know relatively how much that is in relation to wearing of the bearings?
09 WRX with 51750 miles.
gmancari is offline   Reply With Quote
Old 04-29-2013, 08:44 PM   #4962
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
Good question.
5ppm silver is the most my oil has ever shown. Which was back at 25K miles. Last change (50K miles) showed 2ppm.
It seems to have been slowly dropping since that peak.
Breezio is offline   Reply With Quote
Old 05-05-2013, 11:39 AM   #4963
sleeplessinsandiego
Member#: 355519
New here...but just wanted to a quick post together to share my Subaru Experience.
Info:
2006 Impreza Wagon WRX Ltd
Vin: JF1GG79656H813182
- At 55k Checking Engine Light - Secondary Air Valves Replaced
- Check Engine light came back on and off for the next 40,000 miles with no Subaru service center ever able to fix - Secondary Air Valve issue
- They replaced the valve each time (charging me) because each time it was out of warranty.
- Eventually they replaced the Air Pump after a rattling noise started coming from it.
- Finally the death spiral came after my 90k service (where they said "Engine is running great", then 6k miles later there was low compression in the cylander.
I've had every oil change and service. The majority of miles were freeway.
I spent over 4,000 dollars trying to fix the Check Engine Light issue, ultimately ending with low compression and another 2500 dollar bill.
I called Subaru of America, and they said they would not offer any finally assistance due to high mileage. Spoke to Linda and Rich.
Instead of fixing repairing the engine, I traded in my lemon and got Toyota truck.
Sad part is I loved the car and bought it because I heard it has great reliability...but I will never go back to Subaru again. Crappy customer service from both ends. All of the issues may have been unrelated, but in the end I felt like I got ripped off.
sleeplessinsandiego is offline   Reply With Quote
Old 05-05-2013, 07:22 PM   #4964
blackfang
Member#: 131347
2007 Legacy 2.5i SE
By the looks of your post you were around 100-101k on the odometer. Did you really expect Subaru to pay for repairs that are way out of warranty? It does suck, and very unfortunate.
I hope you did not get a 2007-2010 Tundra because those have Air pump issues as well.
Old 05-05-2013, 08:24 PM   #4965
peglegsteve
Member#: 209987
2009 WRB WRX
slowass Prius
Info:
This thread is ONLY for 2009 WRX models.
In the future, put up more of a fight when the dealer can't fix a problem.
peglegsteve is offline   Reply With Quote
Old 05-05-2013, 11:49 PM   #4966
sleeplessinsandiego
Member#: 355519
Sorry...I should have started a new thread my bad. It had 95k when the engine went. Just was upset that multiple Subaru dealers couldn't fix my check engine light and then when the engine goes Subaru of America wouldn't help. Area manager said he'd never seen anything like it.
I'll stop now, because I don't want to derail thread on 09 vehicles.
I got a Tacoma..thx for the heads up tho...and bumper to bumper warranty :-)
Old 05-06-2013, 08:11 AM   #4967
blackfang
Member#: 131347
2007 Legacy 2.5i SE
Good deal. Unless it is new, you do NOT have a bumper to bumper warranty
Old 05-07-2013, 01:10 AM   #4968
Economatic
Member#: 220091
2009 WRX Sedan
Mine was running about the same amount of silver just before it failed at 12k.
Economatic is offline   Reply With Quote
Old 05-07-2013, 08:38 AM   #4969
Wrx_FoSho
Member#: 277108
09 Wrx Hatch
Grey
2009 wrx 58,000 miles.
lose of power and engine rattle/shut off.
Metal Shaving on dipstick.
Stage 3
Wrx_FoSho is offline   Reply With Quote
Old 05-08-2013, 01:05 PM   #4970
gmancari
Member#: 324631
2015 WRX Premium
Stage 3
Keep us updating on whether or not SOA covers the engine failure at stage 3
Old 05-08-2013, 01:08 PM   #4971
Lord Quas
Member#: 352972
02 Bugeye
Rally Blue
Whenever i see SOA i think of Sons of Anarchy lol
Lord Quas is offline   Reply With Quote
Old 05-08-2013, 06:44 PM   #4972
Knotsure
Member#: 41730
0910 Leggy3.0/Impr
BLU Leg/BLK Imp
LOL - me too - kind of! Whenever I see a reference to that show I think of Subaru!
Knotsure is offline   Reply With Quote
Old 05-11-2013, 08:38 PM   #4973
appjoe2004
Member#: 287455
2010 wrx m7960 tomei
obp
i figured id throw my two cents in also. my 2010 wrx with 37,271 miles is at my tuners getting fully rebuilt, forged pistons/rods, the full bit because it actually cost the same to have them rebuild it forged, rather than have the dealership put oem crap back in it. Im probably writing soa , for what it will accomplish, which is nothing im sure. but just to get this off my chest. this is crazy. between my tuner, and two local dealerships, over 46 rebuilds of the 08+ wrx/sti, and 75% of them were completely bone stock. I love my sub, but I just dont get it.
appjoe2004 is offline   Reply With Quote
Old 05-29-2013, 10:25 PM   #4974
Breezio
Member#: 234357
2009 WRX
Latest oil test. Still running strong at 54K miles...
Old 05-29-2013, 11:03 PM   #4975
gmancari
Member#: 324631
2015 WRX Premium
Looks good....I think?
2009 Impreza WRX Short Take Road Test: Faster to 60 than the STI CARandDRIVER NASIOC Official News, Articles and Polls 143 09-25-2010 05:14 AM
Official 2009 Impreza WRX - 265HP (Info & Pics) SOA Blog News & Rumors 3274 01-08-2009 08:20 PM
FS: 2009 Impreza WRX - wrecked/donor car - Perfect for swap - $8000 obo ProdriveRex Private Vehicle 'For Sale' Classifieds 51 01-05-2009 01:53 PM
2002 wrx motor issue??? AWD0425 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 39 11-13-2008 04:46 PM
2009 Impreza WRX PBB (Unofficial Pandog Bluebook/Buyer's Guide) Pandog24 News & Rumors 95 11-02-2008 04:48 PM
