Old 07-20-2010, 05:11 PM   #26
sti05subie
Member#: 240483
2005 wrx sti
white
k thanks ill keep trying to figure it out.
sti05subie is offline   Reply With Quote
Old 07-21-2010, 01:28 PM   #27
sti05subie
Member#: 240483
2005 wrx sti
white
i got it out. everything looks good. the problem is when its together the clutch will not disengage all the way. the slave cylinder seems to be working correctly. and the fork is in correctly. the clutch i bought is a cerametallic 3 pad exedy normal thickness clutch. it measures 5/16 '' thick. it was the whole kit everything was replaced. the only thing i can think of that could be the problem is: that the clutch disk is incorrect thickness, or that because the flywheel was resurfaced its causing a problem. Please help. does anyone know the distance from the surface that the disk rides on to the top of the bosses that the pressure plate bolts to? or the part number on the clutch disk? Thank you for any info you can help me with.
Old 07-21-2010, 06:50 PM   #28
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Exedy's website may offer some insight on how thick the disk is new and worn. My money is still on the slave or air in the system.
Old 07-27-2010, 06:06 PM   #29
jsudler
Member#: 78189
2005 Legacy GT Wagon
Any resolution to this?
jsudler is offline   Reply With Quote
Old 04-28-2011, 11:41 PM   #30
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
Bringing from the past and OLD thread, but I'm curious if this was solved and how, as I'm having the same problem...
wrxstijdm is offline   Reply With Quote
Old 04-29-2011, 01:36 AM   #31
03silverscooby
Member#: 99644
'03 PSM Rex
'07 UGM TR 'g-bye'!
Went through this sort of thing for a week.. Pulled tranny 5 times until I realized I had overtightened the pressure plate bolts..
Bleed. Bleed. And then when you think your good.. Bleed the slave again.
If That doesn't work, adjust your clutch pedal.
If you've done all of that, you prob didn't install the tob correctly.
While your down there re-check pressure plate bolts. 13lbs. That's all.. Very easy to overtighten, and a b*tch if you do as the pressure plate won't disengage the clutch disc fully(or at all)..
03silverscooby is offline   Reply With Quote
Old 04-09-2013, 03:05 PM   #32
zumnmr2
Member#: 91154
2005 WRX STi
crystal grey metallic
I'm going through this as we speak. SPEC stage 2, SPEC aluminum flywheel, new slave, new fork, new TOB (came with the SPEC clutch) New pilot bearing came with the flywheel. Bled a qt of brake fluid through system. No air was coming out. From lots of reading, it seems there still could be some air in the system. Pedal feels normal though. I'll keep bleeding it!
zumnmr2 is offline   Reply With Quote
Old 02-25-2015, 01:55 PM   #33
RJBurkley
Member#: 414462
Default I am having the same clutch disengagment issues
Originally Posted by dibblejr View Post
If this happened last week I was in NY for a couple weeks and drove through PA and would have dropped by to get this fixed, for a lunch or dinner. Bad timing.
As I stated above almost 95% sure it is the slave cylinder and the bleeding.
Should not be any PP alignment issues since you needed an alignment tool to get everything back together.
Hope to hear you get it resolved, let us know.
I have all of the same symptoms stated above, I have gone through the list and double checked or fixed any potential problems I could find. the only thing I haven't replaced is the clutch slave because I cant find any signs it needs to be... During replacement the slave was detached and was just free hanging and someone depressed the clutch to the floor with out my knowledge (I am doing all my work in my schools auto shop.) assuming that over extended my piston I bled the whole system and even replaced my clutch master cylinder because I couldn't get it to hold pressure. long story short I am wondering if my problem could still be the slave even though It looks like it has full travel and isn't leaking... it is the only thing I have left to replace before I disassemble the entire thing again.
RJBurkley is offline   Reply With Quote
Old 02-25-2015, 06:39 PM   #34
dibblejr
Member#: 94070
05 LGT
Hopefully you are using a friend and not a speed bleeder.
Read all of my posts they are pretty thorough and thought out from my experience with working on well over 100 WRX's and STI's.
Bleed, bleed and bleed some more. If it doesn't work change slave and problem will most likely be resolved. Sometimes you have to bleed by hand until you have enough pressure for it to push the pedal up. You do that from the engine bay.
Feel free to PM me if needed.
Best of luck.
dibblejr is offline   Reply With Quote
clutch not disengaging, normal pedal jeffdg Transmission (AT/MT) & Driveline 3 08-12-2009 01:54 PM
Clutch not disengaging Douginss Transmission (AT/MT) & Driveline 0 05-23-2007 03:24 PM
Clutch not disengaging? ezoq Transmission (AT/MT) & Driveline 3 07-02-2006 03:14 AM
Help, clutch will not disengage BADWRX Transmission (AT/MT) & Driveline 4 08-20-2002 02:56 AM
Clutch will not disengage?! dead-eye Transmission (AT/MT) & Driveline 10 09-22-2001 01:27 PM
