Welcome to the North American Subaru Impreza Owners Club Friday March 27, 2015
Old 04-07-2013, 08:16 PM   #1
PlasticFoamMan
Member#: 197764
2002 Nissan Frontier
buh bye WRX :(
Default Strange noise under part throttle & vacuum
Perhaps someone else has run into this issue before I start tearing things out from under the hood to find the problem.
Over the past couple days, I've developed (or noticed) a strange rattle under part throttle and vaccum at about neg 10 lbs, primarily with the motor under load. If I hold vacuum here, the noise sounds sort of similar to an electronic gauge stepper motor cycling, only louder. I can cause this to happen in any gear and only when holding vacuum as noted above--if I'm actively going into boost, it only makes the noise for a moment, which is how I first noticed it.
No boost issues or leaks, motor pulls strong and sounds great otherwise. I assume my waste gate doesn't have any issues as I still hear the usual flutter as normal (thin dp). I tried bringing revs up in my parking garage and the noise is not audible at all with the hood open or outside the car, but with the windows closed and with the motor not under load it is only briefly notable when in the cabin. This made me think it could perhaps have something to do with my mechanical boost gauge (the sound is very much "in the cabin" or almost "on the dash" or so it would seem).
I'll try to shoot a video later, but I'm not sure I have any audio equip nice enough to pick up the sound. Has anyone ever heard something like this? Possibly the turbo? Mech gauge going bad?
I am completely since mechanically everything feels and otherwise sounds absolutely fine.
Thanks for any input!
Edit: and just to note a couple other bits, oil pressure, egt's, temps, all normal. Last maintenance was Rotella synthetic over the weekend...
PlasticFoamMan is online now   Reply With Quote
Old 04-07-2013, 09:10 PM   #2
Uncle Scotty
OK Houston
we have an Uncle
is the trans dipstick pushed in all the way???
Uncle Scotty is online now   Reply With Quote
Old 04-07-2013, 09:17 PM   #3
PlasticFoamMan
Member#: 197764
buh bye WRX :(
Hah, yup, everything is secure. I figured it was something stupid at first but nothing I can find that's obvious. I went over the damn engine bay for a solid 30 trying to find something but came up empty handed
Its only ever under vacuum at the exact same point so I figure it must be something mechanical somewhere, I've just never heard a noise like it before.
Old 04-07-2013, 10:23 PM   #4
Uncle Scotty
OK Houston
we have an Uncle
well..shizzle.....unbolt the boost solenoid and let it just hang free...use a zip tie to make sure it doesnt get bounced around too much
see if that is it
Old 04-08-2013, 05:42 AM   #5
sevier2
Member#: 295516
2004 WRX
I had a weird knocking sound coming from my car every day in 2nd gear for about a year. I FINALLY found it about a week ago. Turns out the down pipe had been rubbing up against the crossmember. Look for parts that may be touching other parts of the car that it's not supposed to...
sevier2 is online now   Reply With Quote
Old 04-08-2013, 01:15 PM   #6
PlasticFoamMan
Member#: 197764
buh bye WRX :(
^^ I'm guessing it may be something rubbing and is simply exhaust resonance related. It seems at second glance this may actually be happening at around 2k rpm in any gear when the engine is under load.
I broke the exhaust bolt that mounts the dp to the trans a long time ago and that bracket makes a really irritating noise all the time when driving (I'm very lazy and haven't fixed this for some reason). That distinctly sounds like its coming from under the car, however. This sound is more in the cabin or on the dash... as soon as I have time I'll keep testing this out.
Old 04-09-2013, 08:11 PM   #7
PlasticFoamMan
Member#: 197764
buh bye WRX :(
This proved to be pretty difficult sound to capture, mainly because of its volume and also that it is momentary, but here is a video. You can distinctly hear it come on at 4-5 seconds in and again at 28 seconds (and 2-3 seconds if you are listening carefully). It is very hard to replicate.
http://s79.photobucket.com/user/stev...0_594.mp4.html
This sound is audible in the video but do not mistake it for the loud tires, turbo, or my frustration with other drivers.
Any thoughts? Doesn't sound bearing or valve related to me. I've never heard it before.
Old 04-16-2013, 12:51 PM   #8
PlasticFoamMan
Member#: 197764
buh bye WRX :(
And to close the loop on this, now that I've had a second to not be the one driving, the sound is actually coming from the rear of the car
Now I'm at a complete loss
Old 08-15-2014, 10:24 AM   #9
misfitsfreak81
Member#: 346751
Ever figure this out? I've got a similar issue and this is the only thread I've seen that comes close to it? My noise is a light rattle noise heard in all gears only under ~10 inches of vac and at 3100-3300 rpm. If below or above those areas car sounds normal.
I've checked all the vac and boost leak problem areas and everything seems good. I do have a thin wall equal length header on the car if that makes any difference. Other than that just your basic stage 2/2+
Sent from my iPad using NASIOC
misfitsfreak81 is offline   Reply With Quote
Old 08-31-2014, 09:02 PM   #10
PlasticFoamMan
Member#: 197764
buh bye WRX :(
It turned out to be stereo wire plugs in the trunk left by the previous owner
It seems they were sitting in just the right location and way such that exhaust resonance/drivetrain vibrations caused them to rattle against the firewall. Very strange, but by process of elimination this was the source (for your issue, check for loose or partly loose things in the trunk!)
