Old 04-09-2013, 05:45 PM   #1
overb00st
Member#: 297501
04 WRX
Default Misfires, low compression
Hey guys, got a few questions for ya.
I've got a 04 WRX that I've been getting misfire codes on for almost a year. The car has never driven differently when the CEL comes on so for a while I didn't think much of it. The code would come on and off occasionally but yesterday I decided to finally do a compression test to see if anything serious was going on. Cylinders 2/4 were at 155 but 1/3 were at ~110.
Now, I'm hoping that its a headgasket issue and not something with the pistons/rings since the 2.0's aren't particularly known for those issues.
If it is only the headgasket, I'd plan on machining the heads, getting ARP head studs and gasket set and throwing it all back on, although if there is piston/ring damage I'm prepared to have to fix that as well.
Wondering if there is anything further you'd recommend doing or any other advice you have.
One question though, a buddy of mine said it could be timing related, but I thought if timing was off that the valves would be messed up and the car would be dead. Mine runs and drives smooth no problem. Any insight on the timing issue?
-Ian
overb00st is offline   Reply With Quote
Old 04-09-2013, 05:59 PM   #2
super_usdm
Member#: 286211
1993 Legacy SS
It's worth a look and will only take a few minutes. Remove your timing belt covers and put the crank pully at tdc, then check the marks on your cam gears to see if they line up. I was getting misfires randomly and a potential cause was my timing belt being strecthed. But, my compression numbers were between 115 to 130 across the board. It's also possible that your timing belt skipped a tooth on one of the pullys.
super_usdm is offline   Reply With Quote
Old 04-09-2013, 06:16 PM   #3
overb00st
Member#: 297501
04 WRX
^ right. I thought our motors would be entirely shot if timing was off though? Or am I wrong on that?
Old 04-09-2013, 07:37 PM   #4
neurosis05
Member#: 230265
2005 WRX stage II
I was having misfire issues on cylinder 1 & 3. Turned out timing was off. Idled a little rough but other than that ran fine. So didn't think it was timing either. Apparently the valves are fine.
neurosis05 is offline   Reply With Quote
Old 04-09-2013, 08:13 PM   #5
overb00st
Member#: 297501
04 WRX
thats good to hear. I'm taking it to a shop Friday for their full diagnosis (comp/leakdown/timing check). I will be extremely relieved if its just timing.
