Welcome to the North American Subaru Impreza Owners Club Monday March 2, 2015
Old 03-23-2013, 01:09 PM   #6051
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
Originally Posted by gregroot198521 View Post
Lol, aight you were one of the originals then, didn't remember seeing any others with them in here before me. Those are D-series if I'm seeing right, right? How much were they when you got them back then?
baja designs, i think high 300s for each light.
PARANOID56 is offline   Reply With Quote
Old 03-23-2013, 03:55 PM   #6052
Mike Costin
Member#: 131787
06 STI,OB,OME XJs
Merkur Junkyard
Originally Posted by PARANOID56 View Post
pfff. puff chest.
had these back in 2008. before your time son
hell, i just noticed i was the 4th poster in this thread god damn i am old
Haha, you are old. I still got your grounding kit in my track car. I still read this thread in my daily email digest
Mike Costin is offline   Reply With Quote
Old 03-24-2013, 02:04 AM   #6053
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
So I'm kinda torn on what to do (again).
I changed my light bar so the lights are mounted about 4" lower than before.....but I'm not sure if I want to keep them how they are now, or go back to how it was.
Previous:
-Limited adjustment
.....but.....
-Completely solid, no shake
-Wires are tucked much cleaner
-Light bar itself is cleaner, and more simple
Current:
-Slight shake on harsh bumps
-Slightly more structure to the bar (doesn't look as nice)
.....but.....
-Better position (lower to the ground)
-Better adjustment / aiming
Here are some (bad quality) comparison pics:
Current is on the top, previous on the bottom.
ManualOverAuto is offline   Reply With Quote
Old 03-24-2013, 02:31 PM   #6054
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
^^ Fogs or Driving lamps?
Superorb is offline   Reply With Quote
Old 03-24-2013, 02:48 PM   #6055
ManualOverAuto
Member#: 304662
Sedona red Pearl
Fogs.
Old 03-24-2013, 05:27 PM   #6056
gregroot198521
Member#: 280844
2006 STi
Originally Posted by ManualOverAuto View Post
Fogs.
Then lower is better.
gregroot198521 is offline   Reply With Quote
Old 03-24-2013, 10:25 PM   #6057
ManualOverAuto
Member#: 304662
Sedona red Pearl
Yea, I remember you saying that before.
It's just that before the bar was so simple and the lights were 100% solid. Now the slight shake just bugs me, especially on gravel / dirt roads.
This started as me wanted more lighting than stock headlights give, at a down low and wide angle, which the 500 fogs accomplished....but now I just want the wide angle lighting to see around me while driving at night.
He's a question though:
If I used 500 driving instead of fogs, and had them where they were mounted before (higher), could that (with proper aiming) get me the lighting I want??
I like the longer distance lighting the driving ones give, but are they a wide enough angle beam? I want a wide angle like the fogs give, but at a longer distance.
Really just want a better chance at seeing deer than the stock lighting gives me.
Old 03-24-2013, 10:47 PM   #6058
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
Ever thought about rigid industries? I just got a chance to see the flood pattern on a dually and sr-10 and they're both pretty wide. Maybe you could get a set of dually's, one being a spot and the other being a flood, or even a combo on either side though I've never seen any of they're combo configurations in person.
My sr-10 spot has a very long distance it can reach but does only at it's furthest cover about two lanes wide
alt14 is offline   Reply With Quote
Old 03-24-2013, 11:48 PM   #6059
ManualOverAuto
Member#: 304662
Sedona red Pearl
Actually a led bar from rigid is in the future plan, eventually.
I do like the dually flood or spot lights you pointed out though. From the video I just saw, 2 spots might be just what I need. I'll have to look into them more.
Old 03-25-2013, 01:31 PM   #6060
reddoak
Member#: 147628
2013 Beep beep
it's a Jeep.
My roof lights learned a new trick this weekend!
I swapped out the single throw switch for a double throw, so it matched the other two. Since I had another circuit to play with... I figured out how to tie the roof lights to go on when the ignition is off, and the turn signal is on.
So...
When the switch is flipped one way, roof lights are on. Normal everyday stuff.
When the switch is flipped the other way, the roof lights flash whenever I lock/unlock the car. And they flash on and off with the hazard lights if the ignition is off. They will not come on if the ignition is on. Don't need them blinking away when I change lanes and such...
When it's in the middle position... lights are off and stay that way.
This ought to make it easier to find in the mall parking lot at night. Because a jacked up wagon with a lift, giant brush bar on front, and roof basket full of lights just sort of blends in everywhere.
reddoak is offline   Reply With Quote
Old 03-25-2013, 04:19 PM   #6061
PARANOID56
Member#: 22035
2003 Brocoma DCab
thats kind of awesome
Old 03-25-2013, 05:46 PM   #6062
reddoak
Member#: 147628
2013 Beep beep
it's a Jeep.
Might tag it to the dome light... unlock car, roof lights on for while... lock car, roof lights off... But that might be overkill. Great for parking in dark places, though.
Old 04-03-2013, 12:15 AM   #6063
joeyo518
Member#: 347947
2013 WRX
Dark Gray
Originally Posted by zmi View Post
I picked these up awhile ago for a great deal from a fellow member. They where pretty beat up and a hacked harness. After plastic welding, painting and a rewire I'm happy with them. A exelent addition to the 1000ff's.
What bar is that?
joeyo518 is offline   Reply With Quote
Old 04-07-2013, 11:31 PM   #6064
Uncle Scotty
OK Houston
we have an Uncle
well...still havnt got the damned rigid led lightbar i wanted....but i REALLY am gonna get it this next payday
had a moment the other nite on the road.....hit a coyote......just a lil...just enough to break his neck and kill him(yeah was a him dog ) dead.
didnt see him until it was too late
saw all sorta dead animals on the road here after than last full moon...everywhere
Uncle Scotty is online now   Reply With Quote
Old 04-10-2013, 02:39 AM   #6065
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
Oh dear me... So tempting to buy some of these and update my lighting rack...
http://tools.woot.com/plus/lazer-star-led-lights
Ok, i'm going back into my cave now.
Psydotek is offline   Reply With Quote
Old 04-10-2013, 07:37 AM   #6066
Uncle Scotty
OK Houston
we have an Uncle
i was gonna do the rigid 10" bar for $255 shipped
Old 04-10-2013, 09:23 AM   #6067
Fourvalve96
Member#: 280655
2004 STi
Default Hella Micro DE Fog/Driving
On my '04 STi, with the OEM fog light "grills," Hella's Micro DE lights
http://www.rallylights.com/detail.aspx?ID=4643
will bolt up (with the light's support bracket downwards), with the lens coming through the hole perfectly. Drill a hole down through the plastic to mount them & you're there. These are really good fogs - better than Hella 500s! Haven't tried the driving lights, but they'd mount the same..
Also, Hella's 4 3/4" worklamp
will bolt up just to either side of the license plate, hanging down in a "pendant" mounting. Put a 100w bulb in there and it's a phenomenal backup light, with the relay keyed to come on with the OEM backup lights! And it's dirt cheap.
I haven't a clue how to post pics, but I'd be glad to send anyone shots of these to your email.
Mike
Fourvalve96 is offline   Reply With Quote
Old 04-10-2013, 12:25 PM   #6068
Clavo
Member#: 22303
2002 WRX Wagon WRB
2006 W211 e55 AMG White
Holy crap
At least you can see into your dark cave...
Now if Mahvin comes back in, the cycle will be complete. I mean, it IS an 8 year old thread that has been quite helpful to some, me included.
Clavo is offline   Reply With Quote
Old 04-10-2013, 05:58 PM   #6069
reddoak
Member#: 147628
2013 Beep beep
it's a Jeep.
I did one better... I got a DEI timer relay module. I tied it to the horn.
Now, if the horn beeps, and the ignition is off, the lights on the roof come on. After a minute, they turn off.
So... If I hit my lock button on the remote twice in a row, I get a horn beep (standard subie behavior) and the roof lights on for a minute. Remote control work lights.
Old 04-10-2013, 07:10 PM   #6070
PARANOID56
Member#: 22035
2003 Brocoma DCab
keep looking, there are better priced ones out there.
Old 04-10-2013, 07:35 PM   #6071
evilspoons
Member#: 321311
2012 STi 5-door
World Rally Blue
Genius! I like your thinking.
evilspoons is offline   Reply With Quote
Old 04-14-2013, 12:36 PM   #6072
XsoberX
Member#: 289656
2011 Impreza WRX
Ok, So I ended up buying some Hella 500 driving lights instead of an LED Light bar, partially because of price, partially because of what I intend on using them for.. but here's my concern.
I want to have the 500's slaved to the high beam's, so that they turn off/on with the high beams (that way I can't forget to turn them off when I turn off the high beams on the highway if someone happens to be around).
My intention is to splice into the high beam wiring for the relay trigger, however from what I've read it seems like I need to splice into both positive and negative wires because of the way Subaru wires their high beams? It seems like there is constant power to the high beams, and that when you switch on the high beams you are completing the ground circuit. Is this correct? If so, should I just splice into the power AND ground from one of the high beams for the relay trigger?
Thoughts or advice?
XsoberX is offline   Reply With Quote
Old 04-15-2013, 01:51 AM   #6073
satrya
Member#: 5887
2002 GDAA
797
Subaru uses switched ground. So, as you described, the "positive" is always available when the key is in the ignition. The "ground" is switched depending on the particular wiring (like the high beam). So, on the signal side, your relay connects power from the battery to the switched ground pin normally going to one of the high beam headlights. The power side connects any ground (e.g chassis) and battery positive.
satrya is offline   Reply With Quote
Old 04-15-2013, 01:53 AM   #6074
Uncle Scotty
OK Houston
we have an Uncle
Thoughts or advice?
no.....one POS trigger wire to your hella relay and its neg to ground and done
Old 04-15-2013, 08:18 PM   #6075
paperdukie
Member#: 214796
2004 OBS
So after months of waiting I finally installed my SR10 Spot bar today. Night pics to come but let me just say that even in the afternoon sun, the lights were able to illuminate highway signs about a quarter mile away.
The ebay grill actually looks good, just better in person. I like it regardless because it fit the light and my very solid mounting bracket behind it perfectly.
paperdukie is offline   Reply With Quote
The Ultimate Bulb Lighting Thread: All You Ever Need to Know About Bulbs Yesitsdrew5310 Electrical & Lighting 585 02-20-2015 02:16 AM
The Ultimate DIY Water/Alc Injection Thread hippy Water/Methanol Injection, Nitrous & Intercooler Cooling 33 03-08-2008 04:11 AM
My new Hella FF200 Driving Lights and mounts wrxinfx Electrical & Lighting 14 04-17-2005 01:24 PM
WTB: WRX or Impreza RS (old school) fog lights and mounting brackets. Yamaha600Biker Private 'Wanted' Classifieds 2 06-08-2004 04:37 PM
