Welcome to the North American Subaru Impreza Owners Club Monday December 5, 2016
Old 04-06-2013, 07:59 PM   #351
TyConway
Member#: 193189
2002 wrx
The sti rear knuckles 08 up bolt on totally different...( different suspension arms) but have bolt in wheel bearings. Which is what i need so i could modify to hold the 350z hub/bearing unit. But its just gonna be better to buy the drive shaft shop axles rated for 1200 hp and call it a day...
But the engine is in the car now, fuel cell had to be notched like 2" on one corner for sway bar clearance but the fuel cell is all welded up and waiting for a few things to come in to finish hooking the fuel cell up to the factory fuel filler neck. So I can fill it up like a normal car.
Going to pull the rear cradle tomorrow and weld a couple of more supports on it and media blast it and get some paint on it this week.
TyConway is offline   Reply With Quote
Old 04-06-2013, 10:37 PM   #352
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
No. The rear knuckles bolt on the same as wrx ones. I've done swap myself, the axle splines are different between r160 and r180. You would see if you had a set. Doesnt matter now since your using custom axles.
scby rex is offline   Reply With Quote
Old 04-07-2013, 02:40 PM   #353
TyConway
Member#: 193189
2002 wrx
What year rear Knuckles are you running?
05 thru 07 are not bolt on wheel bearings which is what I need so i can modify... Those sti Knuckles will bolt on.
08-10 sti have bolt on wheel bearings which is what i was looking for, but do not bolt onto my wrx, knuckle bolts on totally different.
Old 04-07-2013, 09:37 PM   #354
scby rex
Member#: 104878
02 wrxbastardchild
Gd chassis. Gr chassis bolts on then in the rear. Gd only bolts on up front , 05-07 .
Old 04-09-2013, 02:27 PM   #355
TyConway
Member#: 193189
2002 wrx
Think I may of came up with a solution for my axles... gotta order a bearing a 05-07 sti rear knuckle.
Old 04-09-2013, 02:41 PM   #356
05subysti
Member#: 268190
2005 STi
How'd you come up with a solution?
05subysti is offline   Reply With Quote
Old 04-09-2013, 05:21 PM   #357
TyConway
Member#: 193189
2002 wrx
05-07 sti rear wheel bearing ID is 1mm smaller than the OD of my 350z hub... So it will require less than 1mm to be turned down off of the 350z hub. press it in, run the 05-07 sti rear knuckle,calipers, ebrakes and rotor. The 350z is the same lug pattern as the 05-07 sti, so I can just swap the front knuckles and everything will be matching lug pattern... Also have upgraded brakes , which i wanted to do brembos anywyays.
So having the 350z hub, just will require me to buy 1 more short side 350z axle. Bolt them in and go.
I wish the sti rear was 29 spline like the 350z but they are 27spline. Be nice to just have 350z axle bolt into the sti rear knuckle.
Old 04-09-2013, 06:03 PM   #358
05subysti
Member#: 268190
2005 STi
Okay sounds good. Post pictures of the bearing process and pressing!
Old 04-10-2013, 12:08 AM   #359
TyConway
Member#: 193189
2002 wrx
Will do.
Old 04-10-2013, 02:07 AM   #360
TyConway
Member#: 193189
2002 wrx
Bead rolled the ends of the intercooler pipes
Fuel cell corner modded for sway bar clearance
Old 04-10-2013, 02:11 AM   #361
TyConway
Member#: 193189
2002 wrx
Intercooler openings cleaned up and ported for better flow.
Old 04-10-2013, 02:41 AM   #362
05subysti
Member#: 268190
2005 STi
Amazing work. Parts look awesome!
Ugh why can't you be in Texas
Old 04-10-2013, 04:01 AM   #363
TyConway
Member#: 193189
2002 wrx
also waiting on a clutch slave cylinder shim... before the transmission can go back in.
Old 04-11-2013, 04:40 PM   #364
acheung
Member#: 118389
you should post this build as a kickstarter.com campaign.
would definitely help with your funding!
acheung is offline   Reply With Quote
Old 04-11-2013, 08:12 PM   #365
TyConway
Member#: 193189
2002 wrx
Never heard of it... gonna look into it.
Old 04-16-2013, 11:39 PM   #366
TyConway
Member#: 193189
2002 wrx
Got some more parts ordered Monday...$600 dollar order... Stainless brake hard line, brake fittings and some bulkheads. Also a new wilwood 7/8" clutch master cylinder and a few more An fittings.... When buying AN fittings it adds up fast.
But took care of a few small things this week on the car....
Finished all the fuel cell mods. ( Connected to the factory fuel door)
Built and installed a transmission tunnel boot to seal up the hole where the shifter comes into the cabin. Built a new shifter to my likings. Also did some trimming on the front bumper.
Old 04-16-2013, 11:53 PM   #367
TyConway
Member#: 193189
2002 wrx
LOL not so fancy shifter
Old 04-16-2013, 11:54 PM   #368
TyConway
Member#: 193189
2002 wrx
Old 04-17-2013, 02:20 AM   #369
Sti_LGT
Member#: 275937
02 bugeye
silver(soon to be white)
Massive props to you man...epic and I mean epic build
Sti_LGT is offline   Reply With Quote
Old 04-17-2013, 02:36 AM   #370
TyConway
Member#: 193189
2002 wrx
Wink
As everyone knows a lot of the pictures got messed up when I tried to correct the album name ( Subura ) instead of subaru... lol but anways since there are a ton of pics still not fixed, heres the link to 400 plus pics in the build thread... Some may be random crap, cars, bikes, girls ... but don't mind it HAHA.
http://s13.photobucket.com/user/TyCo...20subura%20wrx
Old 04-17-2013, 05:34 PM   #371
Half Crazed
Member#: 321842
2008 STi
ITT: full of win.. looks like a sick build. subscribe
Half Crazed is offline   Reply With Quote
Old 04-18-2013, 03:20 PM   #372
piratemosh666
Member#: 250902
Looks just like it ****ing belongs there. Excellent job, my friend. Excellent job.
piratemosh666 is offline   Reply With Quote
Old 04-20-2013, 03:54 AM   #373
TyConway
Member#: 193189
2002 wrx
Just need the coupler for the connection.
Old 04-20-2013, 03:57 AM   #374
TyConway
Member#: 193189
2002 wrx
Brake line tuck, stainless line, An Bulkheads. Heres the start.
Old 04-20-2013, 05:25 PM   #375
207STi
Member#: 197062
1998 Swapped Impreza
black
One day I hope to have the skills to do such an immaculate build. Honestly man, can't give you enough props for all the custom work that has gone into this.
207STi is offline   Reply With Quote
