Welcome to the North American Subaru Impreza Owners Club Monday May 30, 2016
Old 04-09-2013, 06:02 PM   #1
93V
Member#: 249092
2007 STI Limited
UGM #507/800
Default Help removing rear diff protector/skid plate
My car came with the OEM rear diff skid plate and I see bolts holding it onto the diff but I don't want to go pulling things apart randomly due to a lack of time.
Anyone know how to remove this? Is it involved? A guide would be spectacular. Searched for the last 15 minutes but can't find anything.
The bolts don't look like they have much clearance. I can count at least 4 or 6.
Thanks in advance,
Chris
93V is offline   Reply With Quote
Old 04-09-2013, 07:51 PM   #2
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
seem to remember 2 each side, one side has spacers between diff and protector. And then 2 top rear. The top rear need to be loosened only as the diff protector is slotted.
you might check under rally amor's web site for install directions for their rear diff protector, may give a clue or 2.
Old 04-09-2013, 07:59 PM   #3
93V
Member#: 249092
2007 STI Limited
UGM #507/800
Ok so nothing crazy like removing the entire diff or something similar? Just unbolt?
Will probably have to unbolt my cat back temporarily
Old 04-09-2013, 08:53 PM   #4
mhoerath
Member#: 131379
justablue hatch
diff stays in place. Remove bolts...loosen 2 top and it slides off. you might need to remove cat back.
Old 04-10-2013, 01:49 AM   #5
get a torch...burn metal
