Old 04-08-2013, 02:05 PM   #1
aguyinthesky
Member#: 267159
1997 2.5 GT
Default shortblock sensors on a diff shortblock?
so im workin on a ej22t hybrid motor build. The ej22t is a shortblock with internals...but thats it. Could i use the crank,cam, knock sensor off my pre existent ej25d block? or would i have to track down ej22t sensors...and if i did, could i plug/splice them onto my pre existent harness without problems?
aguyinthesky is offline   Reply With Quote
Old 04-08-2013, 02:11 PM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
use everything you have from the D if you wish. if not, it won't matter. Some 22t's had an integrated crank sensor though, meaning it doesnt unclip from the wiring
Old 04-08-2013, 02:18 PM   #3
aguyinthesky
Member#: 267159
1997 2.5 GT
So would the D crank still fit on the 22t?
Old 04-10-2013, 01:43 PM   #4
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
the cam and crank sensors bolt to the engine the same way for all phase 1 engines. his point was about how the sensor is wired into the harness, is different on the EJ22T (and EJ20G) than it is for the EJ25D
elislider is offline   Reply With Quote
Old 04-10-2013, 02:02 PM   #5
aguyinthesky
Member#: 267159
1997 2.5 GT
So the crank sensor bolts up but has a diff harness plug. If i got the sensor w the plug could i hardwire it into my 25d harness all the same?
Old 04-10-2013, 02:12 PM   #6
eg33GC
Member#: 206851
56 Belair
Pro Street
i shouldnt have said anything sinceit appears to be confusing.
so long as your sensor has a connector, youre fine with whatever you use
oh just dont use eg33 sensors, they stick down more and will hit the triggers on the wheels :/
Old 04-10-2013, 02:27 PM   #7
aguyinthesky
Member#: 267159
1997 2.5 GT
So yes, every sensor switches over? Haha
Minus the 22t sensors harness which is irrelevant
