Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Closed Thread
Old 04-11-2013, 12:32 AM   #1
StephenJin123
Member#: 277253
Default Cobb SF intake/ sf airbox without tunning?
http://www.cobbtuning.com/Subaru-SF-...t-p/715300.htm
Anyone know how good this is with a tune? Is it worth it? Will it damage the car without a tune and will I gain any power? Thanks all for the help
StephenJin123 is offline
Old 04-11-2013, 12:44 AM   #2
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
JSchell1309 is offline
Old 04-11-2013, 12:47 AM   #3
btc2112
Member#: 322981
2012 WRX 5 Door
More of a noise maker than anything. Not necessary unless you're after big-time power.
Yes it can and will damage your car without a tune. Negligible power gains at stage one, basically just getting of the crappy, lean stock tune.
Read the last paragraph in your link there... under Calibrations, and use the search feature. This topic has been discussed thousands of times.
btc2112 is offline
Old 04-11-2013, 12:53 AM   #4
GhostSenshi
Member#: 279449
2004 8.78 E/T WRX
Platinum Silver
This thread is pretty much taken care of. But let me add that you need to fill in your profile because we can't even tell what kind of car you even have.
So your question is pretty redundant without that info.
GhostSenshi is offline
Old 04-11-2013, 12:55 AM   #5
Turbo_powered
Member#: 343742
2011 Wrx sti
Dgm
I don't get it, instead of replying with links. Why not just answer the question real quick.
Anyways. Yes you need a a tune with that intake. With out a tune. The intake will cause your car to run lean, and that will damage it after a period of time.
If you want an intake. You must get a Cobb ap , or get a pro tune.
Turbo_powered is offline
Old 04-11-2013, 01:02 AM   #6
btc2112
Member#: 322981
2012 WRX 5 Door
He's responding with links because this question has literally been asked thousands of times already. A simple search would have turned up those threads and many more.
Read the stickies, read the manifesto, read everything again, research more, then ask your questions, then read some more, then mod.
btc2112 is offline
Old 04-11-2013, 01:03 AM   #7
042
Member#: 332955
2004 Acura TL 6MT.
Broken 95 Legacy - $250.
Probably because it's more valuable to teach someone how to use the vast online resources to find information instead of spoon feeding them forever.
042 is offline
Old 04-11-2013, 01:04 AM   #8
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
yer gunna die...die....DIE
well...the motor might
forget intakes.....just put them out of your kiddie lil mind and be far better off for it
Uncle Scotty is offline
Old 04-11-2013, 07:36 AM   #9
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Perfect example of why searching is a good thing.
HinshawWRX is offline
Closed Thread
