Old 09-17-2012, 05:14 PM   #101
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Can you keep the muffler unbolted like that 1st video? It doesnt hurt mpg or add vibration to car or anything?
I wanna try it!
Old 09-17-2012, 08:21 PM   #102
MjSub2.0
Member#: 314973
2012 Impreza Sport
Satin White
I wanna try it!
You can just to try it. What I did on mine, I installed magnaflow muffler, and deleted the resonator. It's sounds good and not too loud.
MjSub2.0 is offline   Reply With Quote
Old 09-18-2012, 10:38 AM   #103
myrt1987
Member#: 323103
2012 Limited 2.0i
Well i unbolted one of the bolts on the flange so the connection was cracked open a bit. added some rumble, liked what i heard, and drove to work.
...well... i forgot to take into account the fact i have a cvt and therefore the rpms hardly fluctuate.
Needless to say i will be securing the muffler back.
Old 11-05-2012, 11:51 PM   #104
kinger37
Member#: 324423
2012 Impreza Sport
ISM
what is the exhaust diameter on the 2012 impreza?
kinger37 is offline   Reply With Quote
Old 11-06-2012, 01:04 AM   #105
BrDb
Member#: 333203
2012 Sport Premium
MBP 5 SPD
Is the 2 bolt 2" flange the correct size for the 2012 sport premium?
BrDb is offline   Reply With Quote
Old 04-12-2013, 02:16 AM   #106
macatack
Member#: 353207
can you post vid. of your exhaust? Would be great if i could hear it!
macatack is offline   Reply With Quote
Old 04-12-2013, 11:55 AM   #107
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
youtube for magnaflow in 2.0i also check the exhaust thread in the naturally aspirated section
Old 04-12-2013, 11:58 AM   #108
greenplates
Member#: 239162
This is what you will sound like with axle back
I like it
greenplates is offline   Reply With Quote
Old 04-12-2013, 12:46 PM   #109
Beau M
Member#: 345079
13 Wrx sedan
Hmm. Maybe have a shop put in an electric exhaust cutout right before the muffler?
Beau M is offline   Reply With Quote
Old 04-19-2013, 01:58 AM   #110
apexracer
Member#: 257754
2012 Impreza Sport P
Camilla Red Pearl
Lots of people doing exhaust now. Not that it's a race or anything, but he'll ya I've still got the most views on YouTube for the new impreza exhaust sounds. I feel like there isn't much of a difference in sounds from all the different ones I've heard. So, I'm glad I just took the stock muffler off and had the turn-down made for only $50, plus it saves weight.
apexracer is offline   Reply With Quote
Old 08-11-2013, 05:16 AM   #111
WolfPackImpreza55
Member#: 363103
2012 Impreza
Dark Grey
I have a 2012 stock Impreza N/a sedan and I pulled the muffler off added a removable flange with a down pipe and did it for about a month sounded ok but I did notice my mpgs go from 29-32 down to 22-27 also a considerable diffrence in low end torque your better off getting an actual weld on muffler
WolfPackImpreza55 is offline   Reply With Quote
Old 08-11-2013, 10:39 AM   #112
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
Probably because you've been driving it harder to hear the sound. I recently did the same thing Andy msgs went down, but that's because I would shift at 4000rpm instead of 2-2500. Sounds good though!
gregorz4 is offline   Reply With Quote
Old 08-11-2013, 11:09 AM   #113
forester06x
Member#: 327942
'77 Super Beetle
'06 supercharged Forester
My mpg also went down with a muffler delete and I wasn't driving it any harder. Also a noticeable loss of low end torque. Get a muffler welded on.
forester06x is offline   Reply With Quote
Old 08-11-2013, 11:43 AM   #114
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
Weird, I've been getting same mileage as before exhaust delete, not sure about loss or gain of any torque or power
Old 08-11-2013, 12:05 PM   #115
o0Spoony0o
Member#: 276079
2011 WRX Sedan
I wanna try it!
I've had the mufflers from my 2011 wrx unbolted from the flange for the majority of the time I've owned it. The exhaust is fine, flanges are fine the area underneath the car is fine and I can see no argument outside of "do it because I said so" to not just leave it unbolted.I have never even been looked at funny by cops. It's really not that loud unless you're on it hard - the average Honda with exhaust is louder.
Cat back provides the same result for a lot more money. Imo just unbolt them until it's time to go tbe.
Edit: to clarify the mufflers etc are still present. The flange has just been unbolted and I've removed the gasket/inserted spacers.
o0Spoony0o is offline   Reply With Quote
Old 08-11-2013, 12:24 PM   #116
o0Spoony0o
Member#: 276079
2011 WRX Sedan
N/A could potentially see some torque/low end power loss due to backpressure loss / exhaust scavenging. But u wouldn't expect it to be overly much.
Turbo cars want as little back pressure downstream of the turbo as possible.
Old 08-11-2013, 01:03 PM   #117
apexracer
Member#: 257754
Camilla Red Pearl
Back pressure is not applicable to this. In theory it's the same setup as a full pass through muffler with no baffles/restrictors, sound chambers....etc, just nothing nothing to muffle it. It's got 2 cats and the resonator on the system before it exits the rear. If you've noticed an mpg loss, it's because you're driving more spirited. I also doubt we're losing any low end torque. For the same reason a muffler design for an axle-back application has anything to do with power.
Old 08-11-2013, 02:12 PM   #118
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
It's not backpressure loss. It's more exhaust velocity.
For N/A cars, you're talking a different between a few RPMs of a shift in your torque curve. Very insignificant in the real world to me.
Smoke is offline   Reply With Quote
Old 08-11-2013, 05:39 PM   #119
WolfPackImpreza55
Member#: 363103
2012 Impreza
Dark Grey
At first I would shift later to hear it but I got over it fast and was driving Econo style with shifts around 2500 rpm. When I autocrossed my car last weekend I had trouble getting off the line and powering out of corners so if your around town yes you probably won't notice the torque loss but if you actually try and push your car it won't actually move as fast as it should
Old 08-11-2013, 05:48 PM   #120
apexracer
Member#: 257754
Camilla Red Pearl
could it possibly be the vdc or the throttle control?
Old 08-11-2013, 06:01 PM   #121
sc00by4life
Member#: 97135
Except back pressure is critical to NA performance. It ain't like a turbo where you want the exhaust to exit as quickly as possible.
Originally Posted by Smoke View Post
It's not backpressure loss. It's more exhaust velocity. For N/A cars, you're talking a different between a few RPMs of a shift in your torque curve. Very insignificant in the real world to me.
No. The exhaust isnt traveling any faster, it's just a bigger pipe for it to exit through. It IS a lack of back pressure.
Old 08-11-2013, 06:26 PM   #122
apexracer
Member#: 257754
Camilla Red Pearl
Old 08-30-2013, 03:06 AM   #123
RNFNR
Member#: 366956
2013 Impreza Sport
Crystal Black
I've really been debating doing the flange/downpipe, but came across this while checking out sound clips:
If the price is right, This is definitely the direction I will go. Though as far as I know, Borla stuff can be pretty pricey. Can't wait 'til October!
RNFNR is offline   Reply With Quote
Old 08-30-2013, 05:35 PM   #124
imcausinmadrukis
Member#: 318978
Borla R&D - 2013 Subaru Impreza HB 2.0L NA - 11843 Rear Section Exhaust - YouTube
Do you know if there are any additional cuts and welding that need to be done or is it just a simple plug and play?
imcausinmadrukis is offline   Reply With Quote
Old 08-30-2013, 06:06 PM   #125
Nikko
Member#: 54795
'05 WRX Sedan
Obsidian Black Pearl
Originally Posted by Byzantium View Post
No, a muffler delete is definitely rice, and they sound very bad as the muffler adds refinement to the sound.
The Dude: "That's like... your opinion, man."
Nikko is offline   Reply With Quote
[Mini Review] Traded 2011 Impreza Outback Sport for 2012 Impreza Sport Premium tornado542 General Community 22 01-11-2015 02:28 PM
sourcing parts for 2012 Impreza 2.0? (heated side mirrors) dorkbert Interior & Exterior Modification 10 03-10-2013 03:29 AM
Straight Standard Muffler VS Angled Cylinder Muffler Sound... Red Rexx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-31-2004 12:56 PM
Unbolted Muffler at the Track delipinoy Southern California Impreza Club Forum -- SCIC 7 03-07-2002 02:23 AM
Muffler sound clips Impreza22B North West Impreza Club Forum -- NWIC 4 03-02-2001 09:14 PM
