Old 04-11-2013, 07:51 PM   #1
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Default Problems with 07+ ecu's only
So it seems I'm running into a problem with reading or flashing newer 07+ can bus ecu's. No issue with anything older...
Using a 2.0 all the newest updates, newest ecuflash, all the newest definitions. Checked the rom files and it has the one for the specific car that I'm not experiencing issues with. I've uninstalled the whole 9 yards and reinstalled.
Romraider logger and learning view have no problems.
Wondering if anyone else has run into this? I'm kinda banging my head into the wall wondering what the hell is the problems.
Log file....
[15:59:05.849] EcuFlash Version 1.44.3721
[15:59:05.849] OS Version Windows 7
[15:59:05.849] Qt Version 4.8.0
[15:59:05.869] 63 memory models read.
[15:59:05.869] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[15:59:08.469] 612 ROM metadata models scanned.
[15:59:08.469] checksum module "subarudbw" loaded.
[15:59:08.469] checksum module "mitsucan" loaded.
[15:59:08.469] checksum module "mitsuh8" loaded.
[15:59:08.469] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[15:59:08.470] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[15:59:08.471] flashing tool "wrx02" loaded.
[15:59:08.472] flashing tool "wrx04" loaded.
[15:59:08.473] flashing tool "sti04" loaded.
[15:59:08.474] flashing tool "sti05" loaded.
[15:59:08.474] flashing tool "mitsukernel" loaded.
[15:59:08.474] flashing tool "mitsukernelocp" loaded.
[15:59:08.474] flashing tool "mitsubootloader" loaded.
[15:59:08.474] flashing tool "shbootmode" loaded.
[15:59:08.475] flashing tool "shaudmode" loaded.
[15:59:08.476] flashing tool "subarucan" loaded.
[15:59:08.477] flashing tool "subarucand" loaded.
[15:59:08.479] flashing tool "mitsucan" loaded.
[15:59:08.495] J2534 API Version: 04.04
[15:59:08.495] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[15:59:08.495] Device Firmware Version: 1.12.3688
[15:59:08.495] Device Serial Number: TA7T3Bji
[15:59:08.496] interface close
[15:59:08.701] J2534 API Version: 04.04
[15:59:08.701] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[15:59:08.701] Device Firmware Version: 1.12.3688
[15:59:08.701] Device Serial Number: TA7T3Bji
[15:59:08.702] interface close
[15:59:08.727] J2534 API Version: 04.04
[15:59:08.727] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[15:59:08.727] Device Firmware Version: 1.12.3688
[15:59:08.727] Device Serial Number: TA7T3Bji
[15:59:08.728] interface close
[15:59:25.423] using metadata XML ID read_subarush7058can from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_subarush7058can.xml
[15:59:25.440] J2534 API Version: 04.04
[15:59:25.440] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[15:59:25.440] Device Firmware Version: 1.12.3688
[15:59:25.440] Device Serial Number: TA7T3Bji
[15:59:28.127] kernel get version
[15:59:28.347] VIN : JF1GH76639G815119
[15:59:28.359] CVN : 2648425E
[15:59:28.359] SSM2 init
[15:59:28.392] SSM2 ECU ID is 6612784007
[15:59:28.402] Requesting Seed...
[15:59:28.411] Sending Key...
[15:59:28.412] interface close
[15:59:28.414] interface close
project_skyline is offline   Reply With Quote
Old 04-12-2013, 07:02 AM   #2
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
Have you tried more then just this car?
Bamofo is offline   Reply With Quote
Old 04-12-2013, 08:07 AM   #3
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
I had this issue with the latest version of ECU flash. I downgraded to my previous version and it worked just fine. There is something wrong with the new version and possibly windows 7
endrswrd is offline   Reply With Quote
Old 04-12-2013, 11:49 AM   #4
Bamofo
Member#: 159743
07 STI Limited
I know I had an issue and went to properties to always run it as the administrator and it fixed my problem on the new version. Even if I had uac off.
Old 04-12-2013, 05:13 PM   #5
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
The issue was with two cars. An 09 wrx which that error is from and a 09 STI.
It seems odd that both cars would have locked ecu's which im not convinced on. Thanks for the heads up on versions I will try and older one and see!
