Old 05-25-2003, 12:42 PM   #1
vinster02
Member#: 7888
02 wrx
WR Blue
Default Gutless '96L needs help.
Okay so I have a '96L that is starting to be down on power pretty bad. What straight swap can I do. or what is the swap with the least harness changes?This car is a nice RS replica with carbon hood 17" tarmacs lowering springs. Looks the part & then fails when it counts.
vinster02 is offline   Reply With Quote
Old 05-25-2003, 08:40 PM   #2
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I've heard that a DOHC EJ25 would be a direct swap including ecu and engine wiring. Remove engine, put in new engine, remove old ecu, put in new ecu... done. However, I have not personally verified this. Here is the thread.
-Jon
stimpy is offline   Reply With Quote
Old 05-26-2003, 06:20 PM   #3
HomerJay
Member#: 1135
2005 WRX WAGON
Hey Vince,
You can buy my EJ25 after I do the JDM STI Ver 6 swap on my car. I'll let you have it for cheap. I'll probably throw in the rear diff. and entire front clip since I'll be replacing all of it. The car has less than 40K miles on it.
-JOE
HomerJay is offline   Reply With Quote
Old 05-26-2003, 09:10 PM   #4
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Hey you (homerjay), ive been waiting for an engine longer than just about anyone How much? (I only care cause im local, LOL)
Need Help, Need Help nicholas112481 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 11-10-2010 01:24 PM
Need help!! Need to find a +12v switched wire NOW! Please help! nxwrxfx Electrical & Lighting 16 04-25-2006 05:29 PM
Hard Drive Recover Help much needed... ATA RAID 0 knowledge needed HELP PLEASE!!! 2k2 Off-Topic 63 12-24-2003 10:35 PM
Need help! Perrin Fuel rails installed but I need help with Fuel Evap Line STR8OUT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-18-2003 12:11 PM
Need help!Need flywheel bulletin from SOA.Please help. RallyeX General Forum Archive 3 06-01-2000 07:57 AM
