04-12-2013, 02:06 PM | #10101 |
Member#: 320464
Vehicle:2005 Legacy GT ABP |
Got pulled over for tint today... but i got let off with a warning. Might have been my blonde hair and blue eyes or the rain... Didnt mention my 12" Black vinyl strip on the windshield though.
04-12-2013, 02:07 PM | #10102 | |
Member#: 146287
BAIC
Vehicle:2011 Impreza WRX 5D Satin White Pearl |
But they're Star Specs. For some reason I feel like I might have some fitment problems with anything bigger. I also got them used so I should burn through them pretty quick. Then I can go bigger from there. I'll be shooting for 255 ZIIs. |
04-12-2013, 05:41 PM | #10103 |
Member#: 236305
Vehicle:2009 2.5i 4dr 5spd Newport Blue Pearl |
I have blond hair and blue eyes and it never got me out of anything. Now if I had "t&a", that's a different story. Course I don't.. only chicks get away with that stuff.
04-12-2013, 06:20 PM | #10104 | |
Member#: 288727
04-12-2013, 07:06 PM | #10105 |
Member#: 268328
BAIC
Vehicle:2011 2.5i prem pckg SSM |
04-12-2013, 07:22 PM | #10106 |
Member#: 283606
Vehicle:2008 Impreza 2.5i Silver |
I was in 17x8 +43 rocking 245/40 star specs and it would rub over dips in the road and when I would take turns hard and I'm only lowered on h&r springs with konis
04-12-2013, 08:00 PM | #10107 |
Member#: 268328
BAIC
04-12-2013, 08:27 PM | #10108 | ||
Member#: 146287
BAIC
ZIIs run wide too. Everything I consider runs wide. If it doesn't run wide, I'm probably not interested.
But the wheel width isn't as important as the tire width. The tire is going to rub. Not the wheel. All of my research tells me that a 255 should fit. My gut says it won't. |
04-12-2013, 08:42 PM | #10109 | |
Member#: 288727
04-12-2013, 08:55 PM | #10110 |
Member#: 283606
I had nothing rolled and running stock camber, I recently got the backs rolled so it's good now
04-12-2013, 09:07 PM | #10111 | |
Member#: 146287
BAIC
But looking now, there's a RE-11A... Much less expensive. But also a harder compound. Looking at the specs... ZIIs are still wider by 0.4". I know this much tire is probably overkill. But I want it. I've been scrolling through the Meaty Tire thread too much. Ah. All my fenders are rolled and the fronts are pulled a bit. My camber is at -1.4* (Max). 255 really shouldn't be a problem. |
04-12-2013, 09:59 PM | #10112 | |
Member#: 288727
04-13-2013, 02:26 AM | #10113 |
Member#: 320464
Would I be safe on stock studs with a 5mm spacer? If so can someone recommend some?
04-13-2013, 11:45 AM | #10114 |
Member#: 288190
Vehicle:2009 Impreza 2.5i Spark Silver |
Should be fine....I would recommend some wheel/hub centric spacers....you got new wheels already????
04-13-2013, 12:06 PM | #10115 | ||
Member#: 304055
Vehicle:2008 2.5i Rallisport UEL Headers Magnaflow CBE |
04-13-2013, 12:10 PM | #10116 |
Member#: 262503
Vehicle:2008 Impreza 2.5i |
Any of you guys interested in a custom license plate relocation kit? I picked up a Grimmspeed one and won't need my current one anymore. Does the exact same as the Grimmspeed I just want to support a local company.
04-13-2013, 01:15 PM | #10117 |
Member#: 249696
South East
Vehicle:2010 Outback Sport Black |
Bought this used and fixed it up. Can't put it on for a month though.
04-13-2013, 01:26 PM | #10118 |
Member#: 268328
BAIC
04-13-2013, 06:24 PM | #10119 |
Member#: 232585
Vehicle:07 Wrangler JK Rubicon - Red E30 325iS |
04-13-2013, 06:55 PM | #10120 |
Member#: 293006
SCIC
Vehicle:2015 Subaru WRX WR Blue |
Thinkin of trading in my 2.5i ...
04-13-2013, 07:13 PM | #10121 |
Member#: 262503
04-13-2013, 08:32 PM | #10122 | |
Member#: 304055
04-13-2013, 09:36 PM | #10123 |
Member#: 251060
Vehicle:2008 Impreza Outback Black |
04-13-2013, 10:17 PM | #10124 | |
Member#: 304055
04-13-2013, 10:27 PM | #10125 |
Member#: 293006
SCIC
Similar Threads | ||||
08 2.5i and 08 Sti Suspension | WRXbrother | Brakes, Steering & Suspension | 10 | 08-22-2017 12:30 AM |
Will an 08 WRX intake fit an 08 2.5i? | Racing101 | Normally Aspirated Powertrain | 26 | 01-19-2012 11:57 AM |
08 STI Wing on 08 2.5i impreza | juny102004 | Interior & Exterior Modification | 13 | 01-18-2012 09:46 AM |
Will 08+ WRX gauges swap into 08+ 2.5i? | Simeon Priest | Interior & Exterior Modification | 10 | 03-26-2010 02:17 PM |
08 2.5i mod question | deunique1 | Impreza Forum | 1 | 10-03-2007 02:35 PM |
