Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 03-22-2013, 11:21 AM   #101
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
I thought he was talking about reprogramming the CVT.
You might be able to wring out a few more horses with a premium fuel tune, but I doubt there's much more power to be had without turning a wrench.
The variable valve timing in our cars means we can have that race cam without giving up fuel economy.
Old 04-10-2013, 10:39 PM   #102
PA452
Member#: 346220
2013 Impreza Premium
MT Dark Gray Metallic
Picked up my MT Impreza about a week and a half ago. Sometimes I'm able to shift smooth, other times not so much. I think I'm still applying some habits I developed over 6 years of driving the Tacoma.
I have found as many here said, it seems like it likes to shift between at least 3-3.5k. The shift between 1st and 2nd is frequently my most awkward. Not really a problem, just not real smooth. I'm also still getting used to the clutch engagement point. Sometimes I'm able to start out very smoothly, other times not so much. I didn't realize how the hill start assist worked for a while until I got to that part of the manual. Now I'm leveraging that. I like it on the steep hills, but it's kind of a hindrance on light grades. I've noticed it occasionally still holding on for just a moment while I'm trying to move forward.
I just passed 1000 miles this morning or maybe yesterday. As others have said, I feel like I'm abusing the engine if I wind it out too much, but I realize it's designed for that. Dropping to third at high speeds feels like I'd be asking for trouble, but fourth has very little torque.
I'm doing pretty good in terms of fuel efficiency. I filled up on Sunday which was the first tank I was able to do a true hand calc on. It came out at 32.4 mpg, with the computer reading 33.9. So far if the computer is any indication, I'm headed toward a similar or higher number on the current tank.
PA452 is offline   Reply With Quote
Old 04-10-2013, 11:06 PM   #103
Zeeper
Member#: 299286
2015 WRX CVT
Consider swapping out the front differential/transmission fluid (same case) to synthetic (I used Amsoil Severe Gear), and a short shifter or the Perrin adapter (that I have).
Both of these mods are fairly inexpensive and make a big difference in the feel and smoothness of the transmission. The synthetic fluid change seemed to make it both shift better and also reduce the occasional trouble engaging reverse gear (all my opinion, one person here did the Amsoil change and noticed zilch, I think it made a big difference). Now that you have 1,000 miles or so it will shift better anyway, it takes a while to break in the clutch.
Old 04-10-2013, 11:32 PM   #104
PA452
Member#: 346220
Yeah, a lot of those miles are highway miles cruising in 5th. I have a 32 mile one way commute to work, with about 20 of those miles being major highway and about 10 being city.
I've noticed a lot of posts mentioning the difficulty of shifting into R, but I'm not having that problem with mine.
I'll eventually change out the gear oil in the front and the rear, but I figure I'll let them break in a little more before doing that.
Old 04-10-2013, 11:50 PM   #105
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I did amsoil too. Reverse is still difficult, maybe not all the time, but still at least 1/2 the time.
Old 04-11-2013, 01:06 AM   #106
soobie doo
Member#: 324017
2012 Impreza 2.0i
Ice Silver Metallic
PA452, glad to hear you went with the manual. Where you from? There's a PA rt 452 not too far from me, I'm around 15 miles west of Philly.
Re. Reverse:
I've gotten into the habit of shifting to reverse while rolling reeeeally slowly. Usually lets me shift with no trouble. Haven't changed the trans/diff fluid, but I want to get to that at some point.
soobie doo is offline   Reply With Quote
Old 04-11-2013, 07:42 AM   #107
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Re. Reverse:
But I can't roll slightly in my garage, or a parking space. I don't really use reverse anywhere else. It probably happens 1 in 4 times now
Old 04-11-2013, 09:16 AM   #108
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
I'm the Impreza owner who didn't see a change in shifting feel after changing the tranny/diff fluids to Amsoil Severe Gear. It feels no better or worse to me after making the change. However, I don't have the problem of shifting into reverse nearly as frequently as Flyboy describes. I'd say my shifts into reverse are perfect at least 90% of the time, and probably even more than that.
I also recently installed a short shift kit. I installed a Cobb shifter, but did not replace any of the bushings. This significantly shortened the throw, and made the shifter feel much more "notchy" and less vague as you engage each gear. The Cobb is nice because it allows you to adjust both the length of the throw as well as the height of your shift knob. Be advised that the shorter the throw and the lower your knob, the more effort required move the shifter (due to loss of mechanical advantage/leverage).
Hope this helps.
Old 04-11-2013, 10:32 AM   #109
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I have noticed that if the rpm is over 1000 it shifts into reverse silky smooth
Old 04-11-2013, 10:45 AM   #110
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
So with that knowledge, can you avoid all problems engaging reverse?
Old 04-11-2013, 12:45 PM   #111
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I suppose, but if the engine isn't idling that high ie after start, it will give me issues once and a while. I don't usually give it gas to shift into reverse, I suppose I could
Old 04-12-2013, 08:35 PM   #112
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
For some reason my car tried to grind when engaging reverse 3 times today. No idea why. When I got home I tried putting it in reverse and had no issues at all, tried maybe 20 times and it was only difficult 3 times. I tried giving it some gas and if it is above 1000rpm it ground, but less than 1000 no issues. Kinda shoots my other theory out of the water, only difference it that is when the car is just started and it is idling between 1500-2000rpm.
I just don't get it
Old 04-12-2013, 08:47 PM   #113
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
^^ Did it behave this way before installing the short shifter?
Old 04-12-2013, 08:52 PM   #114
Commander Keen
Member#: 319157
N->R will grind if you don't hold in the clutch long enough or far enough.
The clutch has to go from idle speed (at least) to a dead stop before reverse can engage without grinding.
Old 04-12-2013, 09:01 PM   #115
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
yes, just hasn't happened since last summer and the shifter was around Thanksgiving
i was wondering about this, thanks
if i drive it on sunday I will do more testing, calling for another 7-14" of snow sunday, Spring? I guess to have averages you have to have years like this too
Old 04-13-2013, 03:38 AM   #116
Unknown77
Member#: 332289
2012 Impreza Premium
Dark Gray Metallic
Just want to put this out there.
But since I've installed my KB SS and bushings I've noticed a whole lot more noise and vibration in the cabin when I step off the gas to decelerate while in 2nd or 3rd at around 2k-4k rpm but goes away if I shift to neutral. Almost like its engine braking every time I step off the gas when I'm in those gears and rpm's. Really noticeable when I have all windows up and radio off. Sounds like its coming from the gearbox or tranny. Anyone else experience this?
Unknown77 is offline   Reply With Quote
Old 04-13-2013, 04:37 AM   #117
Commander Keen
Member#: 319157
The higher the RPMs and the lower the gear, the more engine braking you'll have. If you want less braking, go to a higher gear. The car uses zero fuel while decelerating in gear.
Old 04-13-2013, 04:41 AM   #118
Unknown77
Member#: 332289
Dark Gray Metallic
Makes absolute sense and that's what I was thinking of too. But I wonder why it became so noticable after I installed the KB SS? Driving habits are the same before and after the install. Maybe due to the stiffer bushings?
Old 04-13-2013, 06:47 AM   #119
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Yes, my guess is that stiffer bushings transfer more vibration/noise through the shift linkages and shift lever, and therefore into the passenger compartment. I installed a Cobb short shifter, but left my original bushings, and I don't have any new noise/vibration.
It would not surprise me if this is the reason manufacturers use softer bushings in the first place--noise reduction.
Old 04-13-2013, 11:41 AM   #120
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Exactly, There is absolutely no reverse grinding when im going very slow in 1st (parking lot) and back into a parking spot. Shifting into reverse is almost instant in this situation.
Old 04-13-2013, 01:41 PM   #121
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I wasn't moving, I started the car. Sat for a minute, and then tried to put it in gear, and it ground
Old 04-13-2013, 02:20 PM   #122
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
did you let the clutch out in neutral when let the car sit? Thats where the disk was moving too fast to engage R
Old 04-13-2013, 03:44 PM   #123
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Yes, at least we figured out why it was grinding now and now I know what not to do in the future
Old 04-13-2013, 05:35 PM   #124
Commander Keen
Member#: 319157
Your car wasn't moving, but your clutch was. Any time the clutch is out, clutch speed is equal to engine speed. When you press the clutch, it begins its spin-down. If you shift into reverse before the clutch stops, there will be grinding.
If you are going from a forward gear to reverse, you can shift as quickly as you want as long as the car is stopped.
From neutral, you want to press the clutch, wait, then engage reverse.
If you are in a hurry, you can quickly flick the stick up halfway into fifth then down into reverse. The fifth gear synchro will stop the clutch.
Old 04-13-2013, 08:20 PM   #125
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I didn't know that the synchro stops the clutch, I will need to do some reading on this to better educate myself.
