Old 02-09-2011, 11:36 PM   #51
J4Y5iN
Member#: 164717
Mostly stock
The link for DIY TGV delete doesn't work.
J4Y5iN is offline   Reply With Quote
Old 03-14-2011, 11:58 PM   #52
Turbo-Chargin
Member#: 276837
Default engine ?s
Im deciding to either rebuild my engine or just get a used one. If i rebuild i want to upgrade the turbo and all that. Any ideas on what to upgrade?
Turbo-Chargin is offline   Reply With Quote
Old 03-15-2011, 12:04 AM   #53
Turbo-Chargin
Member#: 276837
Default Need help
im rebuilding my engine and i wanna upgrade my parts, what should i upgrade to make it alot faster, its currently stock. plz help
Old 03-15-2011, 12:11 AM   #54
Prevent
Member#: 149114
Changing interior engine pieces doesn't make a car a lot faster. It goes hand-hand with other aftermarket parts, such as exhaust, turbo, injector, intercooler.
One could say, I didn't build my motor to make it faster, I built my motor because it broke and i want it support/withstand more abuse from other aftermarket parts.
Prevent is offline   Reply With Quote
Old 04-09-2011, 12:16 AM   #55
2slofouru
Member#: 90539
95 340whp impreza
05 Raven R6, 07 2.5i
Thumbs up 93 and up headgasket spec thread
Is there a way to sticky a thread of a compiled list of the specs for all head gaskets 93 and up? From the 1.8 to the current 2.5's of compressed thickness. I haven't found a thread that isn't a mish mosh of garbled information on this subject so far. Information varies from thread to thread. I could start one but don't know where to go for reliable specs.
Last edited by 2slofouru; 04-09-2011 at 12:17 AM. Reason: compressed thickness of all 93- subaru headgaskets
2slofouru is offline   Reply With Quote
Old 04-15-2011, 10:40 PM   #56
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
Just noticed this as well. It should probably go to http://forums.nasioc.com/forums/show....php?t=1165948
RP31 is offline   Reply With Quote
Old 08-11-2011, 10:20 PM   #57
SUBYGRL08
Member#: 291082
2005 IMPREZA RS
Silver for now...
Default awsome thread.
i have a ?........ i wanna slap a turbo kit on my 05 RS........ is there anything i should do 1st before i do that?
SUBYGRL08 is offline   Reply With Quote
Old 09-13-2011, 11:42 PM   #58
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
This made me .... Lots needed to do
Old 05-17-2012, 01:44 PM   #59
CTSparky
Member#: 282204
2011 5 Door STi
Plasma Blue Pearl
I was wondering if anyone could update this sticky with links to closed deck blocks?
I know S & R Performance makes one, what about other vendors?
CTSparky is offline   Reply With Quote
Old 07-26-2012, 11:20 AM   #60
Khalil1990
Member#: 327260
1997 Legacy GTB
Default Im new to this forum and im looking to build my 1997 Subaru Legacy GTB
Hi
I just purchased a Subaru Legacy GTB EJ20R 2 stage Rwin Turbo.
I would like to build it to get top end power and at the same time have excellent acceleration, and keep my twin turbo.
I am in the uk at the moment, and a garage over here told me that to get kind of power i need to have a 2.7 bore.
My question today is if ej25 parts will fit on my engine and if so if the
"AMS EJ25 Advanced Plus Engine Rebuild Kit W/Crankshaft" will be able to work.
Khalil1990 is offline   Reply With Quote
Old 09-06-2012, 04:02 PM   #61
subiegillis83
Member#: 104550
2005 LGT
obp ,1995 impreza coup
subcribe
subiegillis83 is offline   Reply With Quote
Old 11-20-2012, 07:06 AM   #62
Warney
Member#: 313794
This was a big help on my build!!
Warney is offline   Reply With Quote
Old 04-10-2013, 01:38 PM   #63
namrepusylf
Member#: 353015
2003 Impreza WRX
Question about tuning and spark plugs. I had 3 cylinders misfiring in my '09 ej257. It had been dyno tuned with iridium plugs. Switched out and put in double platinum plugs. Will this affect my tuning/do I need a retune due to the new/upgraded spark plugs?
namrepusylf is offline   Reply With Quote
Old 04-11-2013, 11:16 PM   #64
aguyinthesky
Member#: 267159
1997 2.5 GT
so....im trying to replace the bearings. (rod/main) im very mechanically inclined but does anyone know of any diy's? writeups? etc etc. I just need to know procedures and torque specs mostly...
any help steering me in the right direction would be greatly appreciated thanks
aguyinthesky is offline   Reply With Quote
Old 04-11-2013, 11:24 PM   #65
Red_Wrx
Member#: 158658
Search button.. Try it
http://forums.nasioc.com/forums/show....php?t=2286598
http://forums.nasioc.com/forums/showthread.php?t=934309
Red_Wrx is offline   Reply With Quote
Old 04-11-2013, 11:38 PM   #66
aguyinthesky
Member#: 267159
1997 2.5 GT
yah have beeeeen "searching" for a while without much luck or i wouldnt b askin. Those links arent very extensive. thanks for tryin the ol search button
Old 04-13-2013, 08:54 AM   #67
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Get a service manual. That way your not second guessing.
Old 04-13-2013, 11:15 AM   #68
2slofouru
Member#: 90539
95 340whp impreza
If you are going back with oem bearings with original clearance and don't plan on any machine shop doing the work, your main torque spec concern will be the case and head bolts. After that, you can get nit picky and try to torque all of the tiny bolts holding the accesories on but I do all of those by hand.("elbow pounds" ) The case and head bolts require specific procedures / sequences / torques. There is actually a tear down thread on RS25 that has the torque sequences /specs. I'm not sure where they are here, you usually get led to a dead or dying thread like the one just linked for you. So many threads here that end with "anyone?" or "bump for help".
Some RS25 threads, the first has links to the good stuff including teardown/reassembly:
http://www.rs25.com/forums/f105/t405...e-posting.html
http://www.rs25.com/forums/f105/t716...head-work.html
Oh yeah, and thanks again for the doors! Just recognized your username
Old 04-13-2013, 12:31 PM   #69
aguyinthesky
Member#: 267159
1997 2.5 GT
Awesome thanks! I e also been hunting down extensive repair manulas and have downloaded a few that were helpful also.
Yeah no prob for the doors! Ur lucky, the package i sent using greyhound right after u got lost for three weeks and only half of it showed up to the buyer and they wouldnt do anything about it!! >: (
Old 07-05-2013, 09:14 PM   #70
jzehren11
Member#: 357281
2004 WRX Wagon
Tried the search a few times. But still can't seem to find a how-to for an engine rebuild.
Found the one for the tear-down. Now just need the reversal with torque specs... pretty much dummy proof. Lol. First time ever doing an engine rebuild
jzehren11 is offline   Reply With Quote
Old 07-15-2013, 10:19 PM   #71
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Originally Posted by modaddict View Post
If you have a link bookmarked or know of one that you think should be added to the list...just post it up or PM me and I'll add it to the list!
How about the "Tricks of the Trade" thread. Lots of good / clever tips in there.
Old 09-03-2013, 10:59 PM   #72
pumpupthevolume
Member#: 278913
Great info! Thanks for posting this!
pumpupthevolume is offline   Reply With Quote
Old 01-27-2014, 02:27 PM   #73
subawoo77
Member#: 370658
07 Hawkeye STI
looking for info on h beams vs i beam rods???
subawoo77 is offline   Reply With Quote
Old 04-08-2014, 05:30 PM   #74
KBrownLGT
Member#: 386261
anybody have a sti motor for sale
KBrownLGT is offline   Reply With Quote
Old 05-02-2014, 10:52 PM   #75
vrusso
Member#: 207074
2015 STI
You know you're jealous
I ran across these videos on youtube and I don't recall seeing them before and they are pretty easy to follow.
Short Block Assembly:
http://youtu.be/-gmtEQ1GpmA
Head and Timing Install:
The only thing that I was a little uneasy about in this video was how fast he compressed the timing belt tensioner.
Cylinder Head Removal:
http://youtu.be/5PLdz-lXnQA
vrusso is offline   Reply With Quote
The "Post a Link to Your Favorite Thread YOU Started" thread DrDRum Off-Topic 59 09-11-2008 11:01 AM
Anyone have a link to the thread where... Digitalfiend General Community 1 01-20-2008 11:21 PM
How to create a LINK to a thread? savka Newbies & FAQs 10 12-14-2001 12:17 AM
Links to good... er Great vendor pages..... subenutt General Forum Archive 7 01-04-2001 11:24 PM
Please help - Link to technical thread. Subu WEX General Forum Archive 1 09-03-2000 08:06 AM
