Welcome to the North American Subaru Impreza Owners Club Wednesday June 3, 2015
Old 04-13-2013, 05:20 PM   #1
gfv355
Member#: 330335
02 wrx, stage 2
Default Please analyze my data log stock 02 wrx
https://docs.google.com/spreadsheet/...TRFFLdVE#gid=0
Logs were taken after filling up with 93 octane at shell
gfv355 is offline   Reply With Quote
Old 04-13-2013, 05:35 PM   #2
nmlittlebigman
Member#: 321409
2015 WRX LTD
Make them public for anyone with the link.
Old 04-13-2013, 05:46 PM   #3
gfv355
Member#: 330335
02 wrx, stage 2
Sry about that, just made public
Old 04-13-2013, 06:04 PM   #4
nmlittlebigman
Member#: 321409
2015 WRX LTD
Wow those are busy logs with lots of shifts and knocking. Some of your selected parameters are redundant. Simplify everything and log just these for starters: http://forums.nasioc.com/forums/show...3&postcount=52
Can you do just a 3rd gear pull only? Start a wot run in third just above 2,000 rpm and hold until just below redline.
What mods do you have and who tuned your car?
Old 04-13-2013, 06:06 PM   #5
gfv355
Member#: 330335
02 wrx, stage 2
This car is not modded at all, on stock rom. Ill go do a log with those parameters right now
Old 04-13-2013, 06:38 PM   #6
gfv355
Member#: 330335
02 wrx, stage 2
Here is my updated data log with the parameters you asked for thanks in advance
Old 04-13-2013, 06:50 PM   #7
nmlittlebigman
Member#: 321409
2015 WRX LTD
I suspect that you have an intake tract leak somewhere. You IAM is reduced to 13 and should be 16 and your still getting knock. If you have romraider can you use the Learning View utility and get a screenshot of the stored fuel trims and FLKC?
If you don't have the tool let me know and I'll find you the download link.
http://www.romraider.com/forum/topic2772.html
download at the bottom of first post.
Old 04-13-2013, 07:03 PM   #8
nmlittlebigman
Member#: 321409
2015 WRX LTD
Originally Posted by gfv355 View Post
[url]https://docs.google.com/spreadsheet/ccc?key=0Ar5oWBSKpdvUdEk1dWRFbnVwWVNickl2ejBodXNmT 1E#gid=0[/ur
The link doesn't work now.
Old 04-13-2013, 07:09 PM   #9
gfv355
Member#: 330335
02 wrx, stage 2
https://drive.google.com/#my-drive
There you are sir, i made a mistake and deleted the data log. I just re-uploaded it so here's the new link https://docs.google.com/spreadsheet/...TRFFLdVE#gid=0
Old 04-13-2013, 07:17 PM   #10
nmlittlebigman
Member#: 321409
2015 WRX LTD
[quote=gfv355;39582678]https://drive.google.com/#my-drive
OK your link is fixed now.
Are you able to get a Learning View?
Old 04-13-2013, 07:20 PM   #11
gfv355
Member#: 330335
02 wrx, stage 2
Did the https://drive.google.com/#my-drive link not yeild you a learning view screenshot?
How do i add the attachment directly to the post?
Old 04-13-2013, 07:21 PM   #12
nmlittlebigman
Member#: 321409
2015 WRX LTD
You have to save it to your google drive as a jpeg and then link just like your data files
Old 04-13-2013, 07:23 PM   #13
gfv355
Member#: 330335
02 wrx, stage 2
Old 04-13-2013, 07:28 PM   #14
nmlittlebigman
Member#: 321409
2015 WRX LTD
Got it. Your fuel trims don't look too bad. You've got and assortment of fine knock learning though with some cells pulling timing and you can see where it's adding back. DAM is still reduced too ....Somethings going on triggering knock or even noise that you car thinks is knock.
Old 04-13-2013, 07:33 PM   #15
gfv355
Member#: 330335
02 wrx, stage 2
So should i keep looking for an air leak post MAF? I had it on a lift and noticed a possible rattling heat shield on the downpipe and noticed a crack in a particular spot. I then removed the craked bracket which i believe was rattling due to engine vibration. Would i benefit from an ecu reset?
Old 04-13-2013, 07:44 PM   #16
gfv355
Member#: 330335
02 wrx, stage 2
The car honestly feels like its running slightly lean. Also after pulling the spark plugs they were indicative of a lean condition. i changed the fuel filter already and noticed a problem with the car smelling of un-burned fuel on cold days generally a few minutes after startup.
Old 04-13-2013, 07:52 PM   #17
nmlittlebigman
Member#: 321409
2015 WRX LTD
I wouldn't reset ecu just yet. You car reducing IAM (I said DAM in previous post) is there to protect your motor along with the Fine Knock Learning Corrections. Your car will increase IAM on it's own along with adding timing back through FLKC when it gets the all clear from your knock sensor. If you suspect it is leaning out then do a boost leak test:
http://forums.nasioc.com/forums/show....php?t=2205161
I use the quick and dirty method but I make sure that I keep my pressure down to less than 10 psi.
EDIT: or find a friend with a tester. The other option is to take it to a shop and have them do it.
Old 04-13-2013, 07:57 PM   #18
nmlittlebigman
Member#: 321409
2015 WRX LTD
Wild Guess...but your cat may be breaking up. That would explain leaning out along with triggering knock sensor.
Old 04-13-2013, 07:57 PM   #19
gfv355
Member#: 330335
02 wrx, stage 2
Alright thanks very much for the advice!
Old 04-13-2013, 08:02 PM   #20
gfv355
Member#: 330335
02 wrx, stage 2
i have an exhaust system coming in... I wanted to do some logs before i flash a stage 2 map. i hear these 02s are able to get an exhaust on them and drive without needing an ecu tune. Anyway having the catted uppipe makes me weary seeing as the car has a little over 140k on it. I may run the stock rom on it with the exhaust system to see if it will get rid of the noise.
Old 04-13-2013, 08:10 PM   #21
nmlittlebigman
Member#: 321409
2015 WRX LTD
I'd get rid of the upipe cat too. They can do very bad things to your turbo if they ever break up.
http://forums.nasioc.com/forums/show....php?t=1019991
