Old 03-28-2013, 12:27 PM   #26
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
Also, I havent forgotten about this thread guys, I am out of town on vacation for another week, then I wilk be back at trying to figure this stuff out
olsen726 is offline   Reply With Quote
Old 04-08-2013, 11:05 PM   #27
CarverHouseRally
Member#: 315692
2005 WRX STi
I wouldn't be too concerned about the MAP sensor, if it is the same as the turbo cars, it is only used if the MAF fails. As you can see in the log, the MAP sensor maxes out when you hit 2700 rpm, but the mass airflow continues to rise. The ecu is calculating the mass flow rate, and in turn load, from the MAF. As long as your MAF is not pegged, you are ok. Since you switched to a blow through MAF, you will need to re-scale it. This is why your actual AFR doesn't match your target. Your best bet is to find a tutorial on how to scale a MAF.
Perhaps this one:
http://forums.nasioc.com/forums/show....php?t=1427448
Make sure you log engine load in g/rev, not relative, to verify it still increases after the MAP pegs.
CarverHouseRally is offline   Reply With Quote
Old 04-08-2013, 11:07 PM   #28
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Perhaps this one:
The maf can't measure pressure.
ProfessWRX is offline   Reply With Quote
Old 04-08-2013, 11:34 PM   #29
CarverHouseRally
Member#: 315692
2005 WRX STi
It doesn't have to. Manifold pressure is only used when the ecu goes into limp mode from a MAF sensor malfunction.
Assuming the MAF is working properly:
Load (g/rev) = MAF (g/s) x 60 / RPM
Open loop fueling is based on Load and RPM, no manifold pressure required.
It has a manual boost controller, so no pressure required there either.
I would guess it will eventually throw a pressure sensor circuit high code, so you will probably have to disable that.
Old 04-08-2013, 11:44 PM   #30
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
I'm more concerned with the boost tuning. Hard to do on a mechanical gauge.
Old 04-09-2013, 09:13 AM   #31
Airboy
Member#: 72829
2006 WRX
2015 WRX
There won't be much boost tuning via the ecu if he is using the 2.5i ECU, which i think he is.
Airboy is offline   Reply With Quote
Old 04-09-2013, 09:20 AM   #32
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
Yep, I am using the 2.5i ecu... I just got back from vacation, and they sent me out of town for work, so I havent made much progress on this yet
Old 04-15-2013, 05:54 PM   #33
XSV Klutch
Member#: 259013
2007 Impreza 2.5i
Greyish- Boosted
hopefully this works out, so their is no need to get a new map sensor to go over 5psi on 2.5i ecu?
XSV Klutch is offline   Reply With Quote
