North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 04-17-2013, 03:51 AM   #1
MAK0511
Member#: 315366
2004 Impreza WRX
Rally Stuff new build ideas
IM building my first subie and i was looking for some input on some stuff i want to do the following mods to my 2004 wrx i already have an access port invidia turbo back exhaust and cobb cold air intake cobb short throw shifter and drop springs that were on it when i bought it. heres my list so far.
raceland coilovers
full perrin swaybar kit f&r 25 mm bars f&r xd endlinks with stout mounts and perrins positive steering response system.
a new clutch ( disc and plate ) havent decided what yet
cosworth cold air intake
perrin fmic
bigger rotated turbo kit havent decided what yet
5050 turbo xs bov
either brembo or willwood brakes as big as i can go on 18s
1000cc bosch injectors and new fuel lines
deschwerks fp
eventually i wanna do an 06 2.5 sti swap and an 06 6 speed tranny swap as well. any thoughts or suggestions?
MAK0511 is offline   Reply With Quote
Old 04-17-2013, 07:12 AM   #2
SuperScubi
Member#: 233407
2004 Aspen White STi
PIA Tune 347whp 327tq
what are your goals? what are you trying to build your WRX to do?
the raceland coilovers are crap. get some bc racing coilovers.
do you realize what it actually takes to run a rotated turbo? you need to go read threads on builds in the proven power section
FYI... im pulling my perrin fmic off my STi in Aug if you're interested in buying it then. there's nothing wrong with it. i was just able to pick up an APS fmic instead, so im swapping them out.
SuperScubi is offline   Reply With Quote
Old 04-17-2013, 02:08 PM   #3
JRach
Member#: 78075
98' SF5 STI
93' GF8 (rally)
Some basic things to consider before a few other items on your list...
TGV delete
additional fuel needs (fpr, fuel rails)
intake/turbo inlet will change if you go rotated.
don't get hung up on certain brand names.
JRach is offline   Reply With Quote
Old 04-17-2013, 03:52 PM   #4
stevejones19
Member#: 275250
2006 WRX
Isn't BC just a step above raceland? I've always HEARD they were good enough for going real low, but not a real awesome coilover. And why the massive brakes? Have you really maxed the potential stopping power of what you have? There is a great stickie in that part of the forum that is a great read before spending thousands on new brakes.
stevejones19 is online now   Reply With Quote
Old 04-17-2013, 04:42 PM   #5
kuneefay
Member#: 266477
1996 F-250 7.3L
Save money and do your swap first. People wont like to buy an over worked engine with low compression numbers and a bad tranny. The cosworth intake is a bit much if you already have a Cobb. And handling should come before anything else no sense in having a stupid amount of power for a car that isn't capable of holding its composure.
kuneefay is offline   Reply With Quote
Old 04-17-2013, 07:03 PM   #6
Chesh
Member#: 284935
2004 STi Stage __
I couldn't agree more. Don't skimp on coilovers. If you're paying $1000 for something that's ok quality paying $1500 for something that's high quality will save you money long term and you'll get better performance. I have the 25mm swaybars, end links, and stout mounts (not exactly needed for our year, but not a bad idea). That was the best use of my money on my car so far. Biggest improvement by far.
Chesh is offline   Reply With Quote
Old 04-17-2013, 09:31 PM   #7
larrycox3
Member#: 301016
04 Impreza WRX STi
black
Aluminum Radiator, tgv deletes, lightweight pulleys, accessport, AOS, BCS
larrycox3 is offline   Reply With Quote
Old 04-17-2013, 09:36 PM   #8
kuneefay
Member#: 266477
1996 F-250 7.3L
Apexi is a good option for a $1100 dollar set that have great adjustability and great performance for the price. Obviously ohlins and bilstein are fantastic but unless you can find a good used set you'll be paying a good amount over that $1k mark.
Old 04-18-2013, 12:45 AM   #9
Chesh
Member#: 284935
2004 STi Stage __
Double that.
*sigh* Worth it... Worth it... Worth it...?
Old 04-18-2013, 01:20 AM   #10
wrX-MEN
Member#: 330488
03 WRX
I'm not hijacking the thread but, I'm interested on your FMIC when you take it out on August
wrX-MEN is offline   Reply With Quote
Old 04-18-2013, 01:26 AM   #11
wrX-MEN
Member#: 330488
03 WRX
raceland coilovers
perrin fmic
5050 turbo xs bov
deschwerks fp
Goals and background of the car would be helpful. Giving us those info will be a good start so we an give you some tips.
first suggestion is talk to a tuner so he can give you a path to a goal you want for the car.
Old 04-18-2013, 09:38 PM   #12
hillsboro
Member#: 84823
14 Evo
00 Outback
Do some research on modding suspension. Putting on the biggest sway bars you can get is not necessarily a good thing. What coil overs you have/get should affect sway bar choice.
That's also a lot of engine mods for an 8 year old car. I imagine it has quite a few miles.
hillsboro is offline   Reply With Quote
