Old 01-07-2012, 10:08 AM   #26
CosmoTheCat
Member#: 3409
1996 OBS
Green.
Off the top of my head I'd suggest checking all of your wheel speed sensors and make sure none of them are damaged - obviously check the wiring too.
CosmoTheCat is offline   Reply With Quote
Old 01-07-2012, 11:30 AM   #27
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
This is going to sound stupid, but did you check to be sure that the button on the lower part of the dash (disables the traction control) isn't pushed in?
Ogden is offline   Reply With Quote
Old 01-07-2012, 03:05 PM   #28
QCMP
Member#: 289036
I did check the wiring while apart. There were a couple wires that needed taped but not soldered. They were in the big wiring bunch inside the left fender. Ogden yes I did try to push it in to get it to go out and didn't work..tried push release and push hold then release but no luck.
QCMP is offline   Reply With Quote
Old 01-07-2012, 06:02 PM   #29
CosmoTheCat
Member#: 3409
1996 OBS
Green.
What are the codes?
I'll look them up in the FSM and see if there is anything obvious to check.
Old 01-07-2012, 06:09 PM   #30
QCMP
Member#: 289036
The code reader didn't tell me about the lights on the dash. It's a cheap matco reader..our mechanic has the verus and it'll be able to tell me, I hope lol.
Old 01-07-2012, 06:15 PM   #31
CosmoTheCat
Member#: 3409
1996 OBS
Green.
Even a cheap generic one should be able to get the DTC numbers.
Old 01-08-2012, 01:19 AM   #32
DirknJirkn13
Member#: 249696
2010 Outback Sport
That looks great! Good job with the rebuild it came out looking very nice. Do you have a direct link to the front lip? I am thinking about getting one in the spring. Thanks!
DirknJirkn13 is offline   Reply With Quote
Old 01-08-2012, 02:26 AM   #33
QCMP
Member#: 289036
Thanks dirkin! Right now the website is under construction? Anywho, go to http://www.subarupartswarehouse.com/ and its listed under "accessories". Put your car make model and year and under exterior and you'll find the lip in there. The best part about it is that it comes prepainted! Also, make sure to check the website for coupon codes. I saved 20% and got my lip for $203 shipped to my door!
Side view shows the satin black moldings and handles better. I'm getting the wheels powdercoated satin black Monday or Tuesday. I REALLY want to lower it now, but I know I better just wait it out till spring. Anyone have experience with coilovers? I'll be going TEIN or Eibach basic's, but not sure which brand yet. I really don't want to feel every little crack in the road.
41 by QCMP, on Flickr
Old 01-08-2012, 11:09 AM   #34
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
If you've got a snowy climate and it's not a track car, skip the coils and go with something like an 09 WRX strut and a good spring. The only reason to get coils on a non-track car is to slam it. Chances are very slim that you can drive your car hard enough on the street to have a real need for coils in a performance sense. Most of the people who have them have them to make their car low, and that's about it. Personally (if you couldn't guess) I think that they are a waste a money for anyone who is not going to tack their car. Your money is much better spent elsewhere.
You've already done the rear sway, do a short shifter and shifter bushings, if you have a 5-speed.
Old 01-08-2012, 11:59 AM   #35
DirknJirkn13
Member#: 249696
2010 Outback Sport
Thanks! Can't wait to see the black wheels. Tint would look good too on the car imo.
Old 01-08-2012, 04:37 PM   #36
QCMP
Member#: 289036
The only reason I want coilovers is to have height adjustment. If we buy another wrecked 2009+wrx then I'll probably just swap shocks and put some Eibachs on it. Right now we only have the LF shock off a 09 wrx..sold the other 3 a couple weeks before I bought my car.
I will be tinting my windows, but nothing too extreme. I just tried breaking down my tires off my wheels and since they only have 2000 miles on them they aren't coming easily. I'm using our old tire machine since its in the building with the car, but I'm going to have to use the new one next door come tomorrow. Hopefully our glass blasting cabinet will take off the clear and paint.
Old 01-09-2012, 09:40 AM   #37
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
Make sure it's an 09-10 WRX. The 09+ WRXs got better valving in the struts than the 08s and they stand up to aftermarket springs.
Not sure about how the '11 struts fit the 09-10 Imprezas. STI fronts don't fit, so I'm guessing that the widebody WRX fronts struts won't work either. Rears fit though, IIRC.
Old 01-10-2012, 02:09 AM   #38
QCMP
Member#: 289036
Couple pictures I took today. I've been trying to find a decent place to get my wheels blasted..lowest price I can find here in NE Ohio is $95. Thankfully, my buddy is powdercoating them for free..
42 by QCMP, on Flickr
43 by QCMP, on Flickr
44 by QCMP, on Flickr
Old 01-12-2012, 04:17 PM   #39
QCMP
Member#: 289036
Well we have 3 wrecked OBS's so I took the catback off one of them and cut the resonator off and replaced it with a straight 2.5" stainless piece. Yes I know its a half inch bigger than the pipe, but I was able to make it work pretty nice. I plan on deleting the cat as well. The resonator weighed 12lbs, so atleast I shaved some weight.
resonator by QCMP, on Flickr
Old 01-20-2012, 08:03 PM   #40
QCMP
Member#: 289036
Got my wheels powdercoated Satin black finally. Painted the center caps to match the car. I'm happy with the results!
aj by QCMP, on Flickr
aj1 by QCMP, on Flickr
aj2 by QCMP, on Flickr
Old 01-25-2012, 07:05 PM   #41
QCMP
Member#: 289036
Ordered fortune 500 coil overs today. Should be here in 3 weeks. Happy bday to me!
Old 04-12-2012, 05:08 PM   #42
bidaci
Member#: 291519
2011 OBS
You haven't checked in lately. How was the exhaust sound after removing the resonator?
bidaci is offline   Reply With Quote
Old 03-23-2013, 05:01 PM   #43
austriker
Member#: 315079
2011 Impreza Outback
Silver Bullet
Nice, thread. Im new to the sub world and have an 11 obs, where and how did you get that hood with the scoop? I assume it was like a wrx or sti hood and you swapped it in? How much did it run? id love to do the same
austriker is offline   Reply With Quote
Old 04-17-2013, 04:34 PM   #44
bccr20
Member#: 353736
2001 Impreza OBsport
Wow your car looks GREAT! Im assumimg you have your own garage. How can someone who doesn't have access to a full garage restore their car? Any ideas?
bccr20 is offline   Reply With Quote
Could I swap an Outback Sport front end for an RS front end? Malasubidude Interior & Exterior Modification 6 07-20-2008 05:33 AM
AEM is looking for an 02-04 2.5L Impreza TS and an Outback Sport AEM_Tech Normally Aspirated Powertrain 10 08-07-2004 04:10 AM
('93-'01) The life and times of an Outback Sport Kevin Thomas Impreza Forum 12 06-16-2001 01:47 AM
RS exhaust on an Outback Sport Arnie Normally Aspirated Powertrain 1 01-25-2001 09:38 AM
What can you do with an Outback Sport? cvalle-sd Technical Forum Archive 13 07-24-2000 09:06 PM
