Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 04-17-2013, 03:28 PM   #2801
dsn112
Member#: 332561
2015 Legacy LTD
Twilight Blue
Originally Posted by Dirt Bringer View Post
Does the front strut tower do much for the steering feel and turn in? Right now the car is understeering a little on entry and neutral to oversteer on exist of corners, and I'd like to cure the understeer on entry. Can't decide of the 22mm sway bar or strut tower brace are a better idea... I have the 19mm rear sway bar on there right now.
Front Strut bars are mostly for show. Do the sway for a real upgrade
dsn112 is offline   Reply With Quote
Old 04-17-2013, 03:36 PM   #2802
Reverend_
Member#: 315019
2012 Impreza 5-Door
Ice Silver Metallic
That's what I've heard. And I've heard it from folks who AutoCross or RallyCross, too.
Reverend_ is offline   Reply With Quote
Old 04-17-2013, 03:44 PM   #2803
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
Would the handling be relatively safe in that configuration, seeing as it's biased towards oversteer, or is the effect not so pronounced so as to actually become a hazard?
Dirt Bringer is offline   Reply With Quote
Old 04-18-2013, 07:57 PM   #2804
LuckyNYC
Member#: 72812
2013 Impreza Sport
Ventian Red Pearl
When people are talking about the rear sway bay inducing oversteer they are talking about at the limit. Not from everyday driving.
LuckyNYC is offline   Reply With Quote
Old 04-18-2013, 09:03 PM   #2805
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
In my opinion, better tires thoroughly helped the overall personality and handling of the car a ton..
averagewhiteboy is offline   Reply With Quote
Old 04-18-2013, 09:18 PM   #2806
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
I haven't upgraded my tires yet, I will wait till they're worn out. BUT, I agree with what you said. I think for me, I will keep my 19mm RSB, add a perrin strut tower brace, and GOOD tires when they're ready for new ones, and it should be just about perfect....for me at least.
jsteg is offline   Reply With Quote
Old 04-18-2013, 09:25 PM   #2807
Hopscotchkid42
Member#: 337001
2013 Impreza 2.0i
Ice Silver Metallic
I can also verify that good tires and slightly wider wheels drastically changed the way the car handles. I'm running the 17x8 WRX wheels with Falken Azenis, and it handles SO beautifully. It will only get better with a sway bar upgrade, and potential lowering springs.
Hopscotchkid42 is offline   Reply With Quote
Old 04-18-2013, 10:00 PM   #2808
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
The 17x 8 fits fine with no rubbing?
gregorz4 is offline   Reply With Quote
Old 04-18-2013, 11:27 PM   #2809
solistik
Member#: 345948
MjSub2.0 is running 18 x 8.5 and he said he has no rubbing issues.
solistik is offline   Reply With Quote
Old 04-19-2013, 02:44 AM   #2810
Dirt Bringer
Member#: 340297
Ice Silver
I was going to do the perrin strut bar just because it's cheaper and easier, but I heard it does comparatively little relative to a thicker sway bar. I noticed some body roll shift before the sway bar does it's work on winding roads and some push from the front wheels upon entering a turn heavily (mild understeer). I'm hoping a thicker sway fixes that. On the other hand I heard a strut tower brace improves steering feel and turn in...so I'm not really sure anymore. Have you heard much to sway you one way or the other in that decision?
Old 04-19-2013, 05:58 AM   #2811
jsteg
Member#: 329271
Ice Silver Metallic
Well I've already got the 19mm RSB so there's really no decision for me to make. And where are you getting the front strut tower brace cheaper than the RSB? The OEM 19mm STI RSB can be had for $114 including shipping and new bushings!!
Old 04-19-2013, 07:00 AM   #2812
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Are you still running stock yokos? I say put your money in better tires, then think about further suspension mods.
Old 04-19-2013, 07:43 AM   #2813
jsteg
Member#: 329271
Ice Silver Metallic
I disagree...unless you NEED new tires, the 19mm RSB is the best bang for the buck. Better tires will enhance what the RSB improves on.
Old 04-19-2013, 08:30 AM   #2814
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
He is trying to further improve what the larger bar improves. Instead of suspension mods with relatively crappy tires, get better tires...
I still have the stock tires, And will for another 6 months, but I am happy enough with just the 19mm bar and know it well be better when I get new tires
Old 04-19-2013, 08:36 AM   #2815
jsteg
Member#: 329271
Ice Silver Metallic
Ah yeah my bad. I forgot he already had the RSB.
Old 04-19-2013, 09:30 AM   #2816
Dirt Bringer
Member#: 340297
Ice Silver
I can't really afford better tires at this point, and I don't want to invest a huge amount in the car as I don't know how long I'll keep it. I'm just trying to balance out the handling as economically as I can at this point.
Old 04-19-2013, 09:37 AM   #2817
jsteg
Member#: 329271
Ice Silver Metallic
Well in that case since you already have the 19mm RSB I would just say leave well enough alone.
Old 04-19-2013, 10:36 AM   #2818
Dirt Bringer
Member#: 340297
Ice Silver
I can't stand understeer. The 22mm sway I found costs 220, and the strut tower brace 180. I can afford either one but not both.
Old 04-19-2013, 03:59 PM   #2819
solistik
Member#: 345948
Snapped another iPhone flick today while she was getting all wet:
Hopefully I'll get some actual photos when the weather turns around.
Old 04-19-2013, 04:10 PM   #2820
dsn112
Member#: 332561
2015 Legacy LTD
Twilight Blue
Front strut tower bar or rear?
Old 04-19-2013, 04:17 PM   #2821
nubsub
Member#: 313575
2012 Impreza 2.0i HB
nice! as much as i like my DGM, i sometimes wonder if i should have gotten the marine blue. (my wife had the tie breaking vote!)
nubsub is offline   Reply With Quote
Old 04-19-2013, 05:28 PM   #2822
Reverend_
Member#: 315019
2012 Impreza 5-Door
Ice Silver Metallic
Looks great, man. Those body-colored fog light covers just change SO MUCH. And it's such a clean look too with the lower end all kitted out. I always love seeing cars that look so clean and "stock", but that really aren't.
Old 04-19-2013, 09:09 PM   #2823
Dirt Bringer
Member#: 340297
Ice Silver
Front strut tower brace or rear 22mm sway bar.
Old 04-19-2013, 09:12 PM   #2824
dsn112
Member#: 332561
2015 Legacy LTD
Twilight Blue
Sway, do you want to pay for for a suspension improvement, or do you want a piece of engine bling that barely does anything? Your call
Old 04-19-2013, 09:39 PM   #2825
Chris223
Member#: 308299
2012 Impreza Premium
Dark Grey Metallic
My next upgrade is going to be this. I am just really torn between the 19mm rsb or the 22mm and I'm also curious how much the different mounting holes for the Perrin bar really effect its performance. My car sees just regular daily driving with frequent spirited cornering but nothing more. I'm still looking for more opinion I dont see to many people who seem to have the 22mm. Either way I will most likely go with the Perrin bar. Then figure out what to do about endlinks
Chris223 is offline   Reply With Quote
07 Impreza 2.5i Special Edition Speakers *BRAND NEW* Jonny07subie Interior/Dressup/Audio & Security 0 08-10-2007 03:13 PM
FS: LAMCO Boost Gauge (you know the stock one) meridock MAIC Private Classifieds 7 04-30-2007 06:50 PM
What happened to Member #100,000 (You know... the guy from Sri Lanka.) snvin Off-Topic 4 12-23-2005 01:02 PM
Hey Kosai, I saw you! (you know the drill, "not subie!") RandyF North West Impreza Club Forum -- NWIC 16 04-26-2000 12:54 AM
