Old 04-17-2013, 09:05 AM   #1
Bak3rSkat3r
Member#: 328769
2005 WRB WRX
2007 UGM 2.5i
Default Kenwood ddx-419 stupid bluetooth question
Hey guys I have a Kenwood ddx-419 in my WRX and so far its been pretty good. I've had it for about 5 months, no issues. But all the sudden yesterday the bluetooth didn't work. It reads on the screen "No bt dongle" which from what I read online means "Bluetooth adapter (KS-UBT1) is removed". I've tried unplugging the little adapter multiple times, no luck. It looks like this:
Do you guys think its the adapter itself that is the problem or something with my headunit? Can I just buy one of those cheap bt adapters and will it work the same? Thanks =)
Bak3rSkat3r is offline   Reply With Quote
Old 04-17-2013, 09:12 AM   #2
sultan81
Member#: 309943
2012 STi
I'd suggest throwing it in a laptop and see if it works. Update the firmware on the player also.
sultan81 is offline   Reply With Quote
Old 04-17-2013, 09:28 AM   #3
Bak3rSkat3r
Member#: 328769
2005 WRB WRX
2007 UGM 2.5i
Thanks for the reply, yeah I tried putting it on my laptop and another computer, didn't work. It is updated to the latest version. So I guess my question is now is will any adapter work or do I have to get another "KS-UBT1" ?
Old 04-17-2013, 01:47 PM   #4
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
It's a crapshoot.. you could try..
You might want to call JVC and talk to them about it... 5 months means it's still under warr..
Old 04-17-2013, 03:27 PM   #5
evilspoons
Member#: 321311
2012 STi 5-door
It's unlikely any old bluetooth adapter will work. If they designed it to use a bluetooth adapter design that already existed (as opposed to creating a new adapter from scratch) you might be able to use a generic one that features the same chipset, but it's more likely that it will only recognize exactly the right device.
For the same reason the device from your head unit may not function at all on a laptop - it may not present an interface to the PC that it recognizes and has drivers for.
evilspoons is offline   Reply With Quote
Old 04-17-2013, 04:28 PM   #6
Bak3rSkat3r
Member#: 328769
2005 WRB WRX
2007 UGM 2.5i
^that makes sense. I went to best buy today and picked up another bluetooth adapter, and this one doesn't work on the head unit either
Thanks for the responses, I'll keep researching and hopefully I'll figure it out
Another thing to note that I forgot to put in my original post, about a month and half ago I had the same issue where my head unit would read "No bt dongle" but after messing around with it for a minute and restarting the HU the problem was resolved, until now
Old 08-20-2013, 03:26 PM   #7
aoria01
Member#: 366000
Default I have the same problem with bluetooth
I am not good in english.
i have the same problem, When I installed the JVC JK-AV70BT i didn't have this problem but after when I started to used The device and display show me the follow message "please wait" and this is permanent.
I tried removing the adapter and nothing
can you help?
aoria01 is offline   Reply With Quote
Old 08-21-2013, 01:08 PM   #8
Bak3rSkat3r
Member#: 328769
2005 WRB WRX
2007 UGM 2.5i
I wish I could help, but I'm not sure what to do either. I never ended up solving this issue and I can't justify buying a new usb as they are pretty expensive online. I really wasn't impressed with this head unit, and I've been looking into some different Pioneer decks online and will be switching sometime soon.. sorry
Old 10-12-2013, 06:30 PM   #9
Bak3rSkat3r
Member#: 328769
2005 WRB WRX
2007 UGM 2.5i
Just figured I'd give an update on this in case anyone has this issue in the future. All it turned out to be was a bad usb adapter like I thought it was. At the time I couldn't find anywhere online to buy just the adapter (and I searched EVERYWHERE) except on JVC's website for like $60 or $70. But the other day I searched again and found a seller on ebay selling a ton of them:
http://www.ebay.com/itm/151104964771
Bought the adapter, plugged it in and boom. Worked perfect.
And also, any old bluetooth adapter will not work. You need the correct "KS-UBT1" bt adapter
