Old 10-21-2012, 06:27 PM   #276
PlanB
Member#: 175608
2006 Impreza
1998 Honda VFR 800FI
Old thread I know, but just wanted to say thanks to OP. I switched out my old head unit for a replacement OEM unit. Started when half-time in the Jets game started and finished the swap before half-time was over thanks to the info in this thread.
Gotta love this site for the useful threads like this and others.
PlanB is offline   Reply With Quote
Old 01-26-2013, 06:13 PM   #277
esw116
Member#: 344730
2007 Impreza 2.5i
Okay, question. I'm about to dive into this. I have my head unit and the Subaru harness. I just want to know if it's okay that one or two wires on the two connected harnesses aren't being used? I lined up everything on the Subie harness that has a matching color on the HU (Pioneer) harness. A few aren't being used. The two not being used I believe are the power antenna wire and the illumination one. There are questions concerning this elsewhere in this thread and they weren't answered by anyone.
Also, the two black wires, one on the Subie harness, and other on the HU harness. Are they both grounds? What do I do with the ground on the Subie harness?
esw116 is offline   Reply With Quote
Old 02-03-2013, 06:55 PM   #278
sovereign
Member#: 105309
2006 WRX TR Sedan
Great info! Swapped my stereo this morning. Stripped a couple screws but luckily the alpine unit shipped with replacements.
sovereign is offline   Reply With Quote
Old 04-17-2013, 11:51 AM   #279
jcardisco
Member#: 353744
Last night I installed the HU receiver above but this morning when I turned my headlights on the screen goes blue and the radio volumes goes to near zero. I then cannot increase the volume nor control the receiver in any way (just a blue screen). I wonder if you can help out. I used the appropriate harness, but if I leave off the orange wire (backup camera) would that solve the issue? I don't have a backup camera but the blue screen that comes on when the headlights show says something about the AV input or the backup camera.
Also I connected the pink (parking brake) wire to ground so the DVD player would work. Is this a grounding issue because the unit works great until the headlights come on?
How do I get the headlights not to turn the stereo off?
Please assist.
Here is what I installed:
HarnessHarness
Stereo Stereo
jcardisco is offline   Reply With Quote
Old 04-17-2013, 10:02 PM   #280
jcardisco
Member#: 353744
The BOSS Tech dept got back to me in less than 8 hours! Here is there response.
If you do not have a back up camera connect to the unit then just disconnect the orange wire and that will fix your problem. Its seems that you have it connected to an illumination and that why it trigger only when the lights come on.
Thank You for Your Time,
Phillip D. Samuel
Technical Support Department Supervisor
Old 04-30-2013, 05:24 PM   #281
Shred_the_2.5i
Member#: 313598
Where does one attach the grounding wire? I see no viable options. Right now I have it wrapped around a bolt/nut which goes through a plastic piece and then to a metal frame.
Is this enough?
Shred_the_2.5i is offline   Reply With Quote
Old 05-01-2013, 08:14 PM   #282
tronyony
Member#: 349527
2006 STi
Is this enough?
You should only have to attatch the ground from the Subie pigtail harness to the ground on the aftermarket radio pigtail harness. Black wire to black wire. That's it.
tronyony is offline   Reply With Quote
Old 05-04-2013, 12:02 PM   #283
rubrduk
Member#: 126587
06 wagback...now
with more child seat!
i had to ground my HU chassis because of noise...i found a dash brace and bolted it to the firewall, solved it
rubrduk is offline   Reply With Quote
Old 12-25-2013, 07:47 PM   #284
jtwpg
Member#: 376964
thanjks for the guide!
jtwpg is offline   Reply With Quote
Old 01-01-2014, 06:46 PM   #285
bubbarowley
Member#: 377494
I learned at ton from this thread
bubbarowley is offline   Reply With Quote
Old 10-08-2015, 10:02 AM   #286
Wintah Warrior
Member#: 431714
2007 Impreza
Newport Blue Pearl
My apologies for bumping an old thread, does anyone have the pictures? They broken #bummer
Wintah Warrior is offline   Reply With Quote
Old 12-03-2015, 12:35 PM   #287
Wintah Warrior
Member#: 431714
2007 Impreza
Newport Blue Pearl
No one? My radio sounds like crap when I turn the car on. I'd love to change it.
How to install 2007 AUX Input on 2006 WRX? GooseMan Car Audio, Video & Security 5 08-15-2011 05:27 PM
How-to install a stereo in a 1993 Impreza L rizwan Car Audio, Video & Security 5 12-05-2009 02:26 PM
How to install A system in your 06 Impreza Harley Sporty Car Audio, Video & Security 57 02-12-2009 09:47 PM
How to install new pedals on a 2006 STI Jag32 Interior & Exterior Modification 4 06-30-2006 01:24 PM
How to install aftermarket stereo in '02 WRX joeroket Car Audio, Video & Security 4 04-28-2005 07:28 PM
