Old 06-30-2010, 03:30 AM   #1
wolfwayne
Member#: 167012
2008 Impreza 2.5 SPT
Dark Grey
Default noob question anyone had a success on raising 2.5i rev limit openecu ?
i'm still new to this ecu tuning and need some smart guys to give me some hint here.
Basically i have two problems now. First, I have a problem on adding additional blank on open loop maps. Whenever that i add a blank and set the rev to 6700 for example, the first blank which is 2800 the mixture will go crazy so, the 2800 mixture (g/rev) value wont stay even i tried to change it back again the newly added blank rev value will go back to 0 again.
So, i decided to change the whole rev row min value from 2800 to 3200 (i even know what im doing lol) and max 6700 still got fuel cut on 6300rpm. Yes, i did change the rev limit section ,but i didn't do anything on the throttler map should i do that too ?
Wayne
wolfwayne is offline   Reply With Quote
Old 06-30-2010, 10:39 AM   #2
the suicidal eggroll
Member#: 51961
2005 STi
What on earth are you talking about with adding blanks? What are blanks?
If you want to change the rev limit on the DBW cars you have to change both the fuel cut rev limit (it will say something like "on above" and "off below"), and the DBW throttle rev limit. If you look on the requested torque DBW table you'll see that at the highest RPM in the table the requested torque drops dramatically, this means that when you hit this RPM, even though the rev limit fuel cut hasn't kicked in, the ECU basically closes the throttle plate on you, sort of a "soft" rev limiter. You need to change the last two RPM rows to whatever you want your new rev limiter to be.
Here's my map (bottom) versus the stock map (top), look closely at the RPM axis on the DBW table
http://www.thesuicidaleggroll.com/hosting/rev-limit.png
This just moves the rev limiter up, you'll also need to scale your fueling and timing maps up to the higher RPM to tune it properly.
Old 06-30-2010, 12:22 PM   #3
wolfwayne
Member#: 167012
Dark Grey
this is where i go to "add a blank" lol on RPM AXIS
i can't change the value whenever i do that the 6700 value will go back to 0 again
Old 06-30-2010, 12:26 PM   #4
Member#: 51961
2005 STi
Unless the 08 2.5i ECU is DRAMATICALLY different than ALL of the other Subaru ECUs out there, you can't do that. The table is a fixed size, you can't make it larger. You can change the RPM/load axes, but the table has to remain the same size. If you were to make the table larger, it would use more memory and overlap into whatever the next table is.
Old 07-01-2010, 02:15 AM   #5
wolfwayne
Member#: 167012
Dark Grey
these are the places that i changed today plus 2 fuel maps still had no success : (
today i ran romraider while i'm test drive. my max rev is 6100RPM rather than 6300RPM ?
i'm getting very frustrated now
Thank for the help eggroll !
Old 07-01-2010, 11:13 AM   #6
Member#: 51961
2005 STi
Odd
It appears that your car doesn't have the same DBW cutoff at high RPM like mine does either.
Have you checked all of your requested torque tables and target throttle plate position tables?
Could you upload your ROM?
Old 07-01-2010, 01:50 PM   #7
wolfwayne
Member#: 167012
Dark Grey
http://www.3cshoppingtown.com/sample...ont02knock.hex
please have a look for me thanks eggroll !
Old 07-01-2010, 02:03 PM   #8
Member#: 51961
2005 STi
Hm, well I don't see anything out of the ordinary there. On most of the other DBW cars there are just two places you have to adjust to move the rev limiter up, the rev limiter itself and the DBW table. Yours appears to be fine.
I did notice you still have a speed limiter at 130 mph, but I assume that's not where you're hitting this wall? You should be able to go all the way to 6600 RPM, this isn't an auto is it?
There could be another table that hasn't been defined yet that's still holding you back at 6100. Where is the stock limiter?
Old 07-01-2010, 02:20 PM   #9
wolfwayne
Member#: 167012
Dark Grey
stock one is 6300, yeah i couldn't find the table holding the rpm back at 6100 .... if you can find anything please let me know : )
Old 07-01-2010, 02:22 PM   #10
wolfwayne
Member#: 167012
Dark Grey
do we have to do anything on the closed loop ? one thing i forgot to let you know. i closed all the front 02 and it seems not working no activity at all when i do log. Will it be something to do with the rpm ?
Old 07-08-2010, 12:00 PM   #11
wolfwayne
Member#: 167012
Dark Grey
bump.
Old 08-07-2010, 10:46 PM   #12
jackolafedon
Member#: 232089
2007 Impreza 2.5i
Crystal gray metallic
The ecu will hold the last value defined in a table if the input goes past the scale on the table. (example at 1900 rpm at full throttle you hit over 2 g/rev way higher then your load scale goes on you open loop fueling map) This means that what your editing on your open loop table has nothing to do with your fuel cut value, it only affects the particular rpm/load targeted afr. I'm currently running a 6750 rev limit with a 6400 rpm throttle limit, both defined in different tables. If you read through your defined tables carefully your should be able to figure it out.
jackolafedon is offline   Reply With Quote
Old 08-08-2010, 11:53 AM   #13
wolfwayne
Member#: 167012
Dark Grey
hey thanks for the tip ! so, that means i have to log my car engine load and to see how high the load can go then re-define the open loop engine load row into different increment, max value so, it match with my max load ?
would you mind to send me the map that you run right now ?
Old 09-12-2010, 08:47 PM   #14
wolfwayne
Member#: 167012
Dark Grey
bump for a solution.
Old 04-18-2013, 07:27 AM   #15
SkeetZ18
Member#: 338831
08 Legacy GT LTD
QSM
bump bump
SkeetZ18 is offline   Reply With Quote
Old 04-24-2013, 10:55 PM   #16
crash#2
Member#: 112128
2002 wrx
sedona red pearl
Wayne
first i would like for you to look at a dyno graph for your motor if you can. if the horsepower curve is falling before redline, raising your rev limit will not net you any gains without headwork/cams. save your motor. subarus with factory internals don't last very long past the factory fuel cut anyway.
crash#2 is offline   Reply With Quote
NOOB Questions - Putting a WRX motor into 2008 2.5i Sportshift Doug&Julie Subaru Conversions 6 03-10-2010 12:25 PM
questions about my header install on my 2.5i 2.5EYE Normally Aspirated Powertrain 4 08-11-2009 08:34 AM
Would like your opinions on Outback 2.5i Limited longislander1 General Community 5 01-19-2007 08:39 AM
MSD 2 step rev limiter thermite Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-22-2002 03:07 PM
Anyone had any success putting 5.25 mids in the door? AllWheelsDriven Car Audio, Video & Security 7 12-07-2000 10:19 PM
