Welcome to the North American Subaru Impreza Owners Club Friday January 30, 2015
Old 04-22-2010, 01:44 PM   #1
SueBaroo
Member#: 140838
2002 WRX Wagon
03WRX/06STi/07FOZ/08LEG
Default Thanks Turn in Concepts! EMPI axles.
I would just like to thank TiC for the recommendation of EMPI axles. They work very swell!
I kept breaking A1 Cardone axles (POS) and turned to them for advice, after searching throuh Nasioc.
The EMPI axles have a larger diameter shaft than the A1 Cardone's AND OEM axles, and feel very durable compared to the A1 Cardone's.
I brought it to a recent track day and had no problems at all! I would like to recommend EMPI for fellow Nasioc'ers looking for an aftermarket replacement axle for a great price. They cost about $90 at Star Auto Parts for me. It was special ordered.
Thank TiC!
SueBaroo is offline   Reply With Quote
Old 04-22-2010, 01:58 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
You're very welcome!
Old 04-28-2010, 01:30 AM   #3
ra1337
Member#: 212455
2004 STi
I am about to replace my left rear, is the left rear the same as the left front axle? Lmk thanks.
ra1337 is offline   Reply With Quote
Old 04-28-2010, 02:01 AM   #4
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
No. ...
Old 04-28-2010, 03:02 AM   #5
SueBaroo
Member#: 140838
2002 WRX Wagon
No the rears are different from the fronts.
Just in the rear's alone, they are two different lengths.
Old 04-28-2010, 10:55 AM   #6
ra1337
Member#: 212455
2004 STi
Thanks guys! I am going to regrease and reclamp as I have no noises yet. WE'll see how that goes : |
Old 04-28-2010, 12:36 PM   #7
enjoyminutemaid
Member#: 210724
2009 Impreza WRX sdn
hoot! hoot! for TIC!
enjoyminutemaid is offline   Reply With Quote
Old 05-16-2010, 10:07 AM   #8
4wdwrx
Member#: 72042
2002 WRX impreza
WRB "Blue Mammoth" Return
I need to replace my pass front axles, because the boot got cut. How are these compared to OEM? and would I be fine replacing one side with it? thanks.
4wdwrx is offline   Reply With Quote
Old 05-16-2010, 10:56 PM   #9
SueBaroo
Member#: 140838
2002 WRX Wagon
Yeah I only have oneside. It's in the op. Thicker axles strong as well
Old 07-19-2010, 04:45 PM   #10
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Which is stronger/better OEM STI or EMPI axles?
Old 07-26-2010, 05:34 PM   #11
SueBaroo
Member#: 140838
2002 WRX Wagon
The empi's shaft was thicker in diameter. I don't knwo about the joints, but it never had the same problems as the crappy A1 Cardone
Old 11-11-2012, 12:14 AM   #12
LatentWagen
Member#: 50315
0508 Saabaru & specB
Stage: Maintenance
Bump from the dead... has anyone confirmed if the boots on these will rub against dRex strut extenders?
LatentWagen is offline   Reply With Quote
Old 04-17-2013, 04:57 PM   #13
BuggedWrx
Member#: 227893
Just installed the EMPI Axles as well. They seem to be well built it seemed that shipping had a little bit of effects on the exterior of the axle. Of course this is the vendor's fault and not EMPI's I assume.
The shaft is indeed thicker, and it was running pretty smooth. It also comes with a new axle nut which is nice, so i didn't have to go out and buy my own. However, I got on the freeway and I started feeling vibrations so I'm not sure if that is the axle or other drivetrain parts I will be taking my car in for a diagnosis next week and I'll keep you guys updated.
Here is a picture for comparison
BuggedWrx is offline   Reply With Quote
Old 04-17-2013, 05:47 PM   #14
rexworx
Member#: 103232
MY05 GDA,MY04FXT6spd
2.5ltr,PPG,Front LSD,4.44
Interesting, let us know what you figure out...
rexworx is online now   Reply With Quote
Old 04-18-2013, 10:44 AM   #15
kenliu84
Member#: 107618
2006 OBP WRX Wagon
PrecisionTuned/TiCSuspen.
Just my opinion, but I think you should've sourced the EMPI axles from TiC especially when you asked them for their advice.
Maybe it was 2 years ago I believe I also asked TiC about the front axles. They recommended them as well and the axles have been great. I did notice a lot more surface rusting in the bars compared to the oem ones ( which is none). Also one of the inner boot clips of my driver side came loose and a little grease was flung all over but I just but the clip on correctly and no further issues.
I am trying to find good rear axles but I might have to go with oem. The passenger one must have a tear or something as there's always a glob of grease sitting on top of the lateral link bolt housing on the upright.
kenliu84 is offline   Reply With Quote
Old 11-27-2013, 01:36 AM   #16
dagger108
Member#: 337743
2002 WRX Wagon
WRC Blue
It is always good to support those that are helpful, but if the vendor doesn't carry the part - as is the case with TiC and EMPI axles, a word of thanks may be the best you can do at the time. IMO, it also makes me that much more likely to return to give them business in the future. Positive word of mouth and repeat business is often the best support you can give.
dagger108 is offline   Reply With Quote
Old 11-30-2013, 01:44 PM   #17
Big-E
Member#: 123843
2006 WRX Sedan SGM
Let LED's light your way!
Subaru original equipment.
Aftermarket if you are in a bind, need an inexpensive replacement [for a regular, non-performance, daily-driver] or do not track (track, auto-x, etc) the car.
(PS, this has nothing to do with the OP or TiC)
Big-E is offline   Reply With Quote
Competition STi brakes and hubs, thanks to Stoptech and Turn in Concepts! coolblue05 Brakes, Steering & Suspension 36 03-16-2010 05:57 PM
Special thanks to TURN in CONCEPTS spatt General Community 2 09-06-2008 03:22 PM
Christmas early, Thanks to Turn in Concepts Brady12 Mid Atlantic Impreza Club -- MAIC 12 12-22-2007 04:54 PM
Make your car better thanks to Turn In Concepts Turn in Concepts MWSOC Vendor Classifieds 22 10-21-2007 10:00 AM
Have a better shifter thanks to Turn In Concepts Turn in Concepts Drivetrain 27 10-18-2007 10:27 AM
