Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 03-29-2013, 03:33 PM   #1
TheHighestCrew
Member#: 207133
Default Voltage Issue
Yesterday I was attempting to flash some tweaks I made to my map on my stg2 tune. Previously once I got the voltage too high error and was able to flash by turning the lights on. I am getting the same error. I have tried flashing probably 30-40 times now, going back to stock, the original stg2 map, and the latest one. Every time I am getting the voltage too high error. It does not say the voltage just that it is too high. Finally I had to give up and turn off the ignition.
I tried running every accessory in the car, radio all the way up, high beams on, defroster. Everything. Still the same damn error over and over. Starting to get SUPER pissed because it used to work fine. What could have happened?
I understand the ECU is possibly bricked now because I had to turn it off. I had no choice I did everything possible. I am now deleting and reinstalling the software on my laptop. Any help would be much appreciated.
A4sgc00c
memory model 68HC16Y5
kernel error: programming voltage is too high
failed to commit flash at (sometimes it is in the 00020000 range sometimes in the 00010000 range)
Test write is perfect every time. Then when I go to write it fails every time. Don't know what to do and my car is useless until I can fix this. Thanks for the help
TheHighestCrew is offline   Reply With Quote
Old 03-29-2013, 04:48 PM   #2
TheHighestCrew
Member#: 207133
[13:02:48.816] interface close
[13:02:48.847] interface close
[13:02:51.149] A4SGC00C (346 tables) inheriting 16BITBASE (561 tables)
[13:02:51.180] using metadata XML ID A4SGC00C from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/subaru/Impreza WRX/A4SGC00C.xml
which inherits XML ID 16BITBASE from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/subaru/Bases/16BITBASE.xml
[13:03:10.415] 163840 byte image read.
[13:03:10.415] using metadata XML ID A4SGC00C from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/subaru/Impreza WRX/A4SGC00C.xml
[13:03:36.389] J2534 API Version: 04.04
[13:03:36.389] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:03:36.389] Device Firmware Version: 1.12.3688
[13:03:36.389] Device Serial Number: TAwpJoSR
[13:03:39.620] denso02_bootloader_cmd_start
[13:03:40.852] denso02_bootloader_cmd_start
[13:03:42.085] denso02_bootloader_cmd_start
[13:03:43.317] denso02_bootloader_cmd_start
[13:03:44.550] denso02_bootloader_cmd_start
[13:03:44.971] kernel get version
[13:03:44.986] found oecu kernel!
[13:03:44.986] kernel already resident - skipping kernel load
[13:03:45.205] kernel get version
[13:03:45.220] kernel version is : OpenECU Subaru HC16 Kernel V1.06
[13:03:45.220] reading kernel comm buffer size
[13:03:45.236] comm buffer size set to 512
[13:03:45.236] reading kernel flash buffer size
[13:03:45.267] flash buffer size set to 4096
[13:03:45.267] -- flashing image to ECU memory --
[13:03:45.673] -- comparing ECU flash memory pages to image file --
[13:03:45.673] seg start len ecu CRC32 img CRC32 same?
[13:03:45.985] FB01 00000000 00004000 9E7D9C31 9E7D9C31 YES
[13:03:46.297] FB02 00004000 00004000 8F606882 8F606882 YES
[13:03:46.624] FB03 00008000 00004000 0216DE1B 0216DE1B YES
[13:03:46.936] FB04 0000C000 00004000 D3FE83A7 D3FE83A7 YES
[13:03:47.264] FB05 00010000 00004000 3ED4232E 3ED4232E YES
[13:03:47.576] FB06 00014000 00004000 9B898AB6 9B898AB6 YES
[13:03:47.904] FB07 00018000 00004000 939D0A27 939D0A27 YES
[13:03:48.216] FB08 0001C000 00004000 4BE24516 C58ED7E8 NO
[13:03:48.528] FB09 00028000 00004000 B9A6268E B9A6268E YES
[13:03:48.855] FB10 0002C000 00004000 55330EAF D220F13C NO
[13:03:49.183] kernel flash enable
[13:03:49.183] kernel blank flash page: addr: 0002C000
[13:03:49.401] erased in 1 pulse(s)
[13:03:49.401] kernel write flash buffer addr: 0002C000 len: 00000200
[13:03:49.542] kernel write flash buffer addr: 0002C200 len: 00000200
[13:03:49.682] kernel write flash buffer addr: 0002C400 len: 00000200
[13:03:49.822] kernel write flash buffer addr: 0002C600 len: 00000200
[13:03:49.947] kernel write flash buffer addr: 0002C800 len: 00000200
[13:03:50.088] kernel write flash buffer addr: 0002CA00 len: 00000200
[13:03:50.228] kernel write flash buffer addr: 0002CC00 len: 00000200
[13:03:50.368] kernel write flash buffer addr: 0002CE00 len: 00000200
[13:03:50.509] kernel commit flash addr: 0002C000 len: 00001000 crc32 8e930924
[13:03:50.883] written in 1 pulse(s)
[13:03:50.883] kernel write flash buffer addr: 0002D000 len: 00000200
[13:03:51.024] kernel write flash buffer addr: 0002D200 len: 00000200
[13:03:51.164] kernel write flash buffer addr: 0002D400 len: 00000200
[13:03:51.304] kernel write flash buffer addr: 0002D600 len: 00000200
[13:03:51.445] kernel write flash buffer addr: 0002D800 len: 00000200
[13:03:51.585] kernel write flash buffer addr: 0002DA00 len: 00000200
[13:03:51.710] kernel write flash buffer addr: 0002DC00 len: 00000200
[13:03:51.850] kernel write flash buffer addr: 0002DE00 len: 00000200
[13:03:51.991] kernel commit flash addr: 0002D000 len: 00001000 crc32 56a4f516
[13:03:52.084] kernel error: programming voltage is too high
[13:03:52.084] failed to commit flash at 0002D000!
[13:03:52.084] failure in flashing block
[13:03:52.084] kernel flash disable
[13:03:52.100] interface close
[13:03:52.116] interface close
[13:04:49.208] J2534 API Version: 04.04
[13:04:49.208] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:04:49.208] Device Firmware Version: 1.12.3688
[13:04:49.208] Device Serial Number: TAwpJoSR
[13:04:52.555] denso02_bootloader_cmd_start
[13:04:53.788] denso02_bootloader_cmd_start
[13:04:55.020] denso02_bootloader_cmd_start
[13:04:56.253] denso02_bootloader_cmd_start
[13:04:57.485] denso02_bootloader_cmd_start
[13:04:57.906] kernel get version
[13:04:57.922] found oecu kernel!
[13:04:57.922] kernel already resident - skipping kernel load
[13:04:58.140] kernel get version
[13:04:58.140] kernel version is : OpenECU Subaru HC16 Kernel V1.06
[13:04:58.140] reading kernel comm buffer size
[13:04:58.156] comm buffer size set to 512
[13:04:58.156] reading kernel flash buffer size
[13:04:58.187] flash buffer size set to 4096
[13:04:58.187] -- flashing image to ECU memory --
[13:04:58.593] -- comparing ECU flash memory pages to image file --
[13:04:58.593] seg start len ecu CRC32 img CRC32 same?
[13:04:58.905] FB01 00000000 00004000 9E7D9C31 9E7D9C31 YES
[13:04:59.217] FB02 00004000 00004000 8F606882 8F606882 YES
[13:04:59.544] FB03 00008000 00004000 0216DE1B 0216DE1B YES
[13:04:59.856] FB04 0000C000 00004000 D3FE83A7 D3FE83A7 YES
[13:05:00.184] FB05 00010000 00004000 3ED4232E 3ED4232E YES
[13:05:00.496] FB06 00014000 00004000 9B898AB6 9B898AB6 YES
[13:05:00.823] FB07 00018000 00004000 939D0A27 939D0A27 YES
[13:05:01.135] FB08 0001C000 00004000 4BE24516 C58ED7E8 NO
[13:05:01.463] FB09 00028000 00004000 B9A6268E B9A6268E YES
[13:05:01.775] FB10 0002C000 00004000 55330EAF D220F13C NO
[13:05:02.103] kernel flash enable
[13:05:02.103] kernel blank flash page: addr: 0002C000
[13:05:02.321] erased in 1 pulse(s)
[13:05:02.321] kernel write flash buffer addr: 0002C000 len: 00000200
[13:05:02.461] kernel write flash buffer addr: 0002C200 len: 00000200
[13:05:02.602] kernel write flash buffer addr: 0002C400 len: 00000200
[13:05:02.742] kernel write flash buffer addr: 0002C600 len: 00000200
[13:05:02.867] kernel write flash buffer addr: 0002C800 len: 00000200
[13:05:03.007] kernel write flash buffer addr: 0002CA00 len: 00000200
[13:05:03.148] kernel write flash buffer addr: 0002CC00 len: 00000200
[13:05:03.288] kernel write flash buffer addr: 0002CE00 len: 00000200
[13:05:03.429] kernel commit flash addr: 0002C000 len: 00001000 crc32 8e930924
[13:05:03.803] written in 1 pulse(s)
[13:05:03.803] kernel write flash buffer addr: 0002D000 len: 00000200
[13:05:03.943] kernel write flash buffer addr: 0002D200 len: 00000200
[13:05:04.084] kernel write flash buffer addr: 0002D400 len: 00000200
[13:05:04.224] kernel write flash buffer addr: 0002D600 len: 00000200
[13:05:04.365] kernel write flash buffer addr: 0002D800 len: 00000200
[13:05:04.505] kernel write flash buffer addr: 0002DA00 len: 00000200
[13:05:04.630] kernel write flash buffer addr: 0002DC00 len: 00000200
[13:05:04.770] kernel write flash buffer addr: 0002DE00 len: 00000200
[13:05:04.911] kernel commit flash addr: 0002D000 len: 00001000 crc32 56a4f516
[13:05:05.301] written in 1 pulse(s)
[13:05:05.301] kernel write flash buffer addr: 0002E000 len: 00000200
[13:05:05.425] kernel write flash buffer addr: 0002E200 len: 00000200
[13:05:05.566] kernel write flash buffer addr: 0002E400 len: 00000200
[13:05:05.706] kernel write flash buffer addr: 0002E600 len: 00000200
[13:05:05.847] kernel write flash buffer addr: 0002E800 len: 00000200
[13:05:05.987] kernel write flash buffer addr: 0002EA00 len: 00000200
[13:05:06.127] kernel write flash buffer addr: 0002EC00 len: 00000200
[13:05:06.268] kernel write flash buffer addr: 0002EE00 len: 00000200
[13:05:06.393] kernel commit flash addr: 0002E000 len: 00001000 crc32 928990d2
[13:05:06.783] written in 1 pulse(s)
[13:05:06.783] kernel write flash buffer addr: 0002F000 len: 00000200
[13:05:06.923] kernel write flash buffer addr: 0002F200 len: 00000200
[13:05:07.063] kernel write flash buffer addr: 0002F400 len: 00000200
[13:05:07.188] kernel write flash buffer addr: 0002F600 len: 00000200
[13:05:07.329] kernel write flash buffer addr: 0002F800 len: 00000200
[13:05:07.469] kernel write flash buffer addr: 0002FA00 len: 00000200
[13:05:07.609] kernel write flash buffer addr: 0002FC00 len: 00000200
[13:05:07.750] kernel write flash buffer addr: 0002FE00 len: 00000200
[13:05:07.890] kernel commit flash addr: 0002F000 len: 00001000 crc32 fc87c6e5
[13:05:07.968] kernel error: programming voltage is too high
[13:05:07.968] failed to commit flash at 0002F000!
[13:05:07.968] failure in flashing block
[13:05:07.968] kernel flash disable
[13:05:08.015] interface close
[13:05:08.046] interface close
[13:05:28.889] J2534 API Version: 04.04
[13:05:28.889] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:05:28.889] Device Firmware Version: 1.12.3688
[13:05:28.889] Device Serial Number: TAwpJoSR
[13:05:31.592] denso02_bootloader_cmd_start
[13:05:32.824] denso02_bootloader_cmd_start
[13:05:34.057] denso02_bootloader_cmd_start
[13:05:35.289] denso02_bootloader_cmd_start
[13:05:36.521] denso02_bootloader_cmd_start
[13:05:36.943] kernel get version
[13:05:36.958] found oecu kernel!
[13:05:36.958] kernel already resident - skipping kernel load
[13:05:37.177] kernel get version
[13:05:37.192] kernel version is : OpenECU Subaru HC16 Kernel V1.06
[13:05:37.192] reading kernel comm buffer size
[13:05:37.192] comm buffer size set to 512
[13:05:37.192] reading kernel flash buffer size
[13:05:37.208] flash buffer size set to 4096
[13:05:37.208] -- flashing image to ECU memory --
[13:05:37.613] -- comparing ECU flash memory pages to image file --
[13:05:37.613] seg start len ecu CRC32 img CRC32 same?
[13:05:37.925] FB01 00000000 00004000 9E7D9C31 9E7D9C31 YES
[13:05:38.237] FB02 00004000 00004000 8F606882 8F606882 YES
[13:05:38.565] FB03 00008000 00004000 0216DE1B 0216DE1B YES
[13:05:38.877] FB04 0000C000 00004000 D3FE83A7 D3FE83A7 YES
[13:05:39.205] FB05 00010000 00004000 3ED4232E 3ED4232E YES
[13:05:39.517] FB06 00014000 00004000 9B898AB6 9B898AB6 YES
[13:05:39.844] FB07 00018000 00004000 939D0A27 939D0A27 YES
[13:05:40.156] FB08 0001C000 00004000 4BE24516 C58ED7E8 NO
[13:05:40.468] FB09 00028000 00004000 B9A6268E B9A6268E YES
[13:05:40.796] FB10 0002C000 00004000 DFF350D3 D220F13C NO
[13:05:41.123] kernel flash enable
[13:05:41.123] kernel blank flash page: addr: 0002C000
[13:05:41.342] erased in 1 pulse(s)
[13:05:41.342] kernel write flash buffer addr: 0002C000 len: 00000200
[13:05:41.482] kernel write flash buffer addr: 0002C200 len: 00000200
[13:05:41.623] kernel write flash buffer addr: 0002C400 len: 00000200
[13:05:41.763] kernel write flash buffer addr: 0002C600 len: 00000200
[13:05:41.888] kernel write flash buffer addr: 0002C800 len: 00000200
[13:05:42.028] kernel write flash buffer addr: 0002CA00 len: 00000200
[13:05:42.169] kernel write flash buffer addr: 0002CC00 len: 00000200
[13:05:42.309] kernel write flash buffer addr: 0002CE00 len: 00000200
[13:05:42.449] kernel commit flash addr: 0002C000 len: 00001000 crc32 8e930924
[13:05:42.824] written in 1 pulse(s)
[13:05:42.824] kernel write flash buffer addr: 0002D000 len: 00000200
[13:05:42.964] kernel write flash buffer addr: 0002D200 len: 00000200
[13:05:43.105] kernel write flash buffer addr: 0002D400 len: 00000200
[13:05:43.245] kernel write flash buffer addr: 0002D600 len: 00000200
[13:05:43.385] kernel write flash buffer addr: 0002D800 len: 00000200
[13:05:43.526] kernel write flash buffer addr: 0002DA00 len: 00000200
[13:05:43.666] kernel write flash buffer addr: 0002DC00 len: 00000200
[13:05:43.791] kernel write flash buffer addr: 0002DE00 len: 00000200
[13:05:43.931] kernel commit flash addr: 0002D000 len: 00001000 crc32 56a4f516
[13:05:44.321] written in 1 pulse(s)
[13:05:44.321] kernel write flash buffer addr: 0002E000 len: 00000200
[13:05:44.462] kernel write flash buffer addr: 0002E200 len: 00000200
[13:05:44.602] kernel write flash buffer addr: 0002E400 len: 00000200
[13:05:44.727] kernel write flash buffer addr: 0002E600 len: 00000200
[13:05:44.867] kernel write flash buffer addr: 0002E800 len: 00000200
[13:05:45.008] kernel write flash buffer addr: 0002EA00 len: 00000200
[13:05:45.148] kernel write flash buffer addr: 0002EC00 len: 00000200
[13:05:45.289] kernel write flash buffer addr: 0002EE00 len: 00000200
[13:05:45.429] kernel commit flash addr: 0002E000 len: 00001000 crc32 928990d2
[13:05:45.803] written in 1 pulse(s)
[13:05:45.803] kernel write flash buffer addr: 0002F000 len: 00000200
[13:05:45.944] kernel write flash buffer addr: 0002F200 len: 00000200
[13:05:46.084] kernel write flash buffer addr: 0002F400 len: 00000200
[13:05:46.225] kernel write flash buffer addr: 0002F600 len: 00000200
[13:05:46.365] kernel write flash buffer addr: 0002F800 len: 00000200
[13:05:46.490] kernel write flash buffer addr: 0002FA00 len: 00000200
[13:05:46.630] kernel write flash buffer addr: 0002FC00 len: 00000200
[13:05:46.771] kernel write flash buffer addr: 0002FE00 len: 00000200
[13:05:46.911] kernel commit flash addr: 0002F000 len: 00001000 crc32 fc87c6e5
[13:05:46.989] kernel error: programming voltage is too high
[13:05:46.989] failed to commit flash at 0002F000!
[13:05:46.989] failure in flashing block
[13:05:46.989] kernel flash disable
[13:05:47.005] interface close
[13:05:47.020] interface close
[13:06:36.562] J2534 API Version: 04.04
[13:06:36.562] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:06:36.562] Device Firmware Version: 1.12.3688
[13:06:36.562] Device Serial Number: TAwpJoSR
[13:06:38.945] denso02_bootloader_cmd_start
[13:06:40.177] denso02_bootloader_cmd_start
[13:06:41.410] denso02_bootloader_cmd_start
[13:06:42.642] denso02_bootloader_cmd_start
[13:06:43.874] denso02_bootloader_cmd_start
[13:06:44.296] kernel get version
[13:06:44.311] found oecu kernel!
[13:06:44.311] kernel already resident - skipping kernel load
[13:06:44.530] kernel get version
[13:06:44.530] kernel version is : OpenECU Subaru HC16 Kernel V1.06
[13:06:44.530] reading kernel comm buffer size
[13:06:44.561] comm buffer size set to 512
[13:06:44.561] reading kernel flash buffer size
[13:06:44.576] flash buffer size set to 4096
[13:06:44.576] -- flashing image to ECU memory --
[13:06:44.982] -- comparing ECU flash memory pages to image file --
[13:06:44.982] seg start len ecu CRC32 img CRC32 same?
[13:06:45.294] FB01 00000000 00004000 9E7D9C31 9E7D9C31 YES
[13:06:45.606] FB02 00004000 00004000 8F606882 8F606882 YES
[13:06:45.934] FB03 00008000 00004000 0216DE1B 0216DE1B YES
[13:06:46.246] FB04 0000C000 00004000 D3FE83A7 D3FE83A7 YES
[13:06:46.573] FB05 00010000 00004000 3ED4232E 3ED4232E YES
[13:06:46.885] FB06 00014000 00004000 9B898AB6 9B898AB6 YES
[13:06:47.213] FB07 00018000 00004000 939D0A27 939D0A27 YES
[13:06:47.525] FB08 0001C000 00004000 4BE24516 C58ED7E8 NO
[13:06:47.852] FB09 00028000 00004000 B9A6268E B9A6268E YES
[13:06:48.164] FB10 0002C000 00004000 DFF350D3 D220F13C NO
[13:06:48.492] kernel flash enable
[13:06:48.492] kernel blank flash page: addr: 0002C000
[13:06:48.710] erased in 1 pulse(s)
[13:06:48.710] kernel write flash buffer addr: 0002C000 len: 00000200
[13:06:48.851] kernel write flash buffer addr: 0002C200 len: 00000200
[13:06:48.991] kernel write flash buffer addr: 0002C400 len: 00000200
[13:06:49.132] kernel write flash buffer addr: 0002C600 len: 00000200
[13:06:49.256] kernel write flash buffer addr: 0002C800 len: 00000200
[13:06:49.397] kernel write flash buffer addr: 0002CA00 len: 00000200
[13:06:49.537] kernel write flash buffer addr: 0002CC00 len: 00000200
[13:06:49.678] kernel write flash buffer addr: 0002CE00 len: 00000200
[13:06:49.818] kernel commit flash addr: 0002C000 len: 00001000 crc32 8e930924
[13:06:49.896] kernel error: programming voltage is too high
[13:06:49.896] failed to commit flash at 0002C000!
[13:06:49.896] failure in flashing block
[13:06:49.896] kernel flash disable
[13:06:49.943] interface close
[13:06:49.958] interface close
[13:07:30.582] J2534 API Version: 04.04
[13:07:30.582] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:07:30.582] Device Firmware Version: 1.12.3688
[13:07:30.582] Device Serial Number: TAwpJoSR
[13:07:54.125] denso02_bootloader_cmd_start
[13:07:54.437] writing kernel area addr: 020000 len: 0664
[13:07:56.355] kernel get version
[13:07:56.355] kernel version is : OpenECU Subaru HC16 Kernel V1.06
[13:07:56.355] reading kernel comm buffer size
[13:07:56.387] comm buffer size set to 512
[13:07:56.387] reading kernel flash buffer size
[13:07:56.402] flash buffer size set to 4096
[13:07:56.402] -- flashing image to ECU memory --
[13:07:56.808] -- comparing ECU flash memory pages to image file --
[13:07:56.808] seg start len ecu CRC32 img CRC32 same?
[13:07:57.120] FB01 00000000 00004000 9E7D9C31 9E7D9C31 YES
[13:07:57.432] FB02 00004000 00004000 8F606882 8F606882 YES
[13:07:57.759] FB03 00008000 00004000 0216DE1B 0216DE1B YES
[13:07:58.071] FB04 0000C000 00004000 D3FE83A7 D3FE83A7 YES
[13:07:58.399] FB05 00010000 00004000 3ED4232E 3ED4232E YES
[13:07:58.711] FB06 00014000 00004000 9B898AB6 9B898AB6 YES
[13:07:59.039] FB07 00018000 00004000 939D0A27 939D0A27 YES
[13:07:59.351] FB08 0001C000 00004000 4BE24516 C58ED7E8 NO
[13:07:59.663] FB09 00028000 00004000 B9A6268E B9A6268E YES
[13:07:59.990] FB10 0002C000 00004000 690B37D3 D220F13C NO
[13:08:00.318] kernel flash enable
[13:08:00.318] kernel blank flash page: addr: 0002C000
[13:08:00.333] kernel error: programming voltage is too high
[13:08:00.333] WARNING: failed to erase page at 0002C000!
[13:08:00.333] kernel flash disable
[13:08:00.349] interface close
[13:08:00.365] interface close
Old 03-29-2013, 05:14 PM   #3
Nuke209
Member#: 108089
2003 WRX
NF Performance
Which cable?
Nuke209 is offline   Reply With Quote
Old 03-29-2013, 05:50 PM   #4
TheHighestCrew
Member#: 207133
Tactrix 2.0. Got in contact with them today and they want to send me a new one and me send in the old one. After reviewing my logs they think the ECU is not bricked but car will not start until i can reflash. Hoping that it is a problem in the hardware and that I am good to go with the new cable.
Old 04-09-2013, 11:33 PM   #5
TheHighestCrew
Member#: 207133
just wanted to update this, got the new tactrix cable and after disconnecting everything and hooking it back up I was able to flash with the new cable. No more voltage issue. Looks like something went wrong with my OP. Big thanks to tactrix for good customer support and getting me a new unit quickly.
Old 04-18-2013, 05:27 PM   #6
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
I had the same problem a few months back. Tactrix sent me an updated version of the software and it never happened again. Also, now using their current version it doesn't happen either.
Soarer is offline   Reply With Quote
