Old 03-26-2013, 11:36 PM   #1
slapshot1994
Member#: 251524
2005 Sti
Psm
Default Timing belt tensioner
Ok so my new motor has 3k on it and I'm going to be replacing my second tensioner. The motor has bc 272 cams as well as +1 intake and exhaust valves. I did get the bc springs and retainers as well. The motor has a ticking sound in the front drivers side head. Replaced first tensioner and noise got quieter but still present. It almost sounds like a solid lifter issue for those of you that played with V8 engines. So my question is what in the hell is causing me to have this tapping on the one side and blowing out timing belt tensioners? Please help I'm at a loss here folks.
slapshot1994 is offline   Reply With Quote
Old 03-27-2013, 12:40 AM   #2
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
How do you know the tensioners are failing?
Did you replace all the idler pulleys too?
did you measure the lash or have someone else do it and just slap it all together?
are all the bolts for the idlers torqued properly?
I would start by checking all those before you pop the valve covers off to verify your lash.
Goodluck!
-Phil
Flat 4 Motorsport is offline   Reply With Quote
Old 03-27-2013, 01:07 AM   #3
slapshot1994
Member#: 251524
2005 Sti
Psm
Phil, all the pulleys and tensioners were replaced and torqued to spec per Subarus guide lines. The first tensioner was cracked in the back where the guide hole is for the pin to slide through. It was new as well. The builder who does all of the local dealer work said it was shimmed and lash is correct. I'm gonna have him recheck the lash on Friday
Old 03-27-2013, 08:13 AM   #4
spintheground
Member#: 239638
2007 WRX TR UGM
Aren't 05 STi's shimmless buckets?
spintheground is offline   Reply With Quote
Old 03-27-2013, 09:59 AM   #5
Member#: 301037
2004 Forester XT
Without hearing it I would say it could be bad valve lash adjustment if it is only on one side
art@grimmspeed is offline   Reply With Quote
Old 04-18-2013, 01:21 PM   #6
Quiksmith
Member#: 266230
2006 WRX STI
Any updates?
Quiksmith is offline   Reply With Quote
Old 04-18-2013, 10:50 PM   #7
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
does it do it when you rev the motor and let the rpms come down?almost sound like light rod knock? it may be the avcs gear on the left head chattering,don't ask me how I know.
john 1badSTI is offline   Reply With Quote
