Welcome to the North American Subaru Impreza Owners Club Friday August 29, 2014
Old 04-16-2013, 10:26 PM   #1
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
Default Sleeve-Style Ring Compressor
http://www.rallysportdirect.com/Wise...rce=GoogleBase
Anyone ever used one?
Seems like it would be easier if it works the way it's supposed to. Tapers down to bore size.
Old 04-16-2013, 10:39 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
We use them. They are size specific but wonderful as well.
Old 04-17-2013, 07:37 AM   #3
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
Only use them. Bought oversized for 2.0 2.5 and evo. Never will use that stupid clamp setup again.
Bamofo is offline   Reply With Quote
Old 04-17-2013, 10:39 AM   #4
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
Awesome, guys. Just want I wanted to hear!
Old 04-17-2013, 01:42 PM   #5
JayMeagher
Member#: 187911
03 WRX
Redish
True story. It's well worth the small investment.
JayMeagher is offline   Reply With Quote
Old 04-17-2013, 06:50 PM   #6
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
on e85@ 30psi--spinning
use them also even have a custom one made just for an oringed block.One problem though I have not found someone to list one for 99.75 bore without having it made special.
john 1badSTI is offline   Reply With Quote
Old 04-17-2013, 06:56 PM   #7
VTsuby
Member#: 81369
2007 STI
total seal sells something in the middle that is adjustable with a hose clamp might be more practical for the average joe for rebores, they work pretty good
VTsuby is offline   Reply With Quote
Old 04-17-2013, 07:05 PM   #8
rexworx
Member#: 103232
MY05 GDA,MY04FXT6spd
2.5ltr,PPG,Front LSD,4.44
+1 Ive been looking for one in 99.75mm bore. I like using that size...
rexworx is online now   Reply With Quote
Old 04-17-2013, 07:21 PM   #9
VTsuby
Member#: 81369
2007 STI
Old 04-17-2013, 08:29 PM   #10
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
I think Cosworth makes a 99.75mm
Old 04-18-2013, 12:41 AM   #11
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
Wiseco makes a 99.75 guys. I ordered their 99.5 for my stock bore sleeved engine and will my ordering a 99.75 soon because they are so common.
Old 04-18-2013, 02:04 AM   #12
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Interesting...its not on ther site. Must be new as thy didn't have one when I bought some others last year.
Old 04-18-2013, 12:35 PM   #13
rexworx
Member#: 103232
Great thank you...
Old 04-18-2013, 03:32 PM   #14
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
https://www.mdrtuning.com/ring-compr...leeve-9975mm-0
There you go. If you have any trouble getting one shoot me a PM.
Old 04-18-2013, 04:51 PM   #15
Serkan
Member#: 180514
2004 Sti White
Serkan is offline   Reply With Quote
Old 04-18-2013, 05:18 PM   #16
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
does anyone else have the issue with the cheaper clamp ones where sometimes a ring will pop between the compressor and top of sleeve like if the ring compressor moves slightly and a ring sneaks out??
jw if these ^ are better in that aspect? if so im on board.??
Old 04-18-2013, 07:05 PM   #17
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
All we use here at MPS is the wiseco style tapered installer.
NW2TONE is offline   Reply With Quote
Old 04-18-2013, 08:24 PM   #18
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
sounds like the one piece tapered ones are the tits
Old 04-18-2013, 08:34 PM   #19
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
That is exactly why I wanted to try a sleeve-style compressor. Countless times I would have a oil ring catch the sleeve on the way down.
Yes, can't wait to try her out
Old 04-18-2013, 08:58 PM   #20
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
yeah i always use a mallet or hammer and tap down my ring compressor as much as possible but now and again a ring comes out. after that i always worry if i weakened it or anything
Old 04-19-2013, 09:12 AM   #21
rexworx
Member#: 103232
^^^Ive had that happen and worry about the same thing...
Old 04-19-2013, 09:27 AM   #22
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
yeah wondered if i was the only one! once a ring pops out im like damn. guess ill buy one of the tapered ones and try it
Old 04-19-2013, 09:54 AM   #23
rexworx
Member#: 103232
nope deff not...
Old 04-19-2013, 11:01 AM   #24
kakarot09
Member#: 182375
08 Sti
Wrbm
I've used both kinds and they've both been fine. You have to be careful no matter which one you're using though. I bought a tapered one from Summit and then the regular old clamp style from O'reilly's.
I think I have these two.
kakarot09 is online now   Reply With Quote
