Old 04-19-2013, 02:49 PM   #1
Philydrake
Member#: 344430
Default which fuse is for the boost gauge?
My lights out in my 2002 wrx stock boost gauge I'm guessing its the fuse. Just need help finding it and which one
Philydrake is offline   Reply With Quote
Old 04-19-2013, 04:52 PM   #2
25rsti
Member#: 166324
Did you check your fuses?
How did you wire you gauge?
Is your gauge working other than the light not being on?
25rsti is offline   Reply With Quote
Old 04-19-2013, 08:23 PM   #3
Philydrake
Member#: 344430
Its the factory gauge and the gauge still works but the light doesn't
Old 04-19-2013, 09:23 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The gauge is connected to the factory dimming circuit, so if all your other dash lights are working and dimming properly it's just a burned-out bulb.
Old 04-19-2013, 11:26 PM   #5
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
light out troubleshooting:
1. inspect bulb/test bulb
2. check for power at bulb socket
3. is the fuse blown/ test w/ multi-meter or swap a known good fuse
4. inspect wiring for continuity/short to ground
aerosaaber is offline   Reply With Quote
Old 04-19-2013, 11:37 PM   #6
Philydrake
Member#: 344430
Okay cool thank you all!
