Old 04-15-2013, 11:06 AM   #1
Danielreadams
Member#: 319021
2006 2.5i wagon
Question Engine compatibility 2006 Impreza
So, I'm dropping a used engine in my 06 Impreza 2.5i 5-speed. (oil starved head :P)
I picked up a another 06 2.5i motor, after I got it I realized it was from an auto car, and mine is 5-speed.
I'm assuming I can just remove the torque converter and such, and then bolt on my clutch and flywheel, is that true, or do I need to find a 5-speed engine?
Thanks!
Danielreadams is offline   Reply With Quote
Old 04-15-2013, 11:42 AM   #2
Danielreadams
Member#: 319021
2006 2.5i wagon
Also, if it is possible to use it, do I need to swap the intake as well?
Old 04-15-2013, 11:45 AM   #3
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
Thanks!
I think you can use it, but there is a little more than just taking off the TC. I believe that there are a couple of sensors and some pins on the ECU that need to be connected/disconnected so it knows it's a 5 speed. (idle speed and things get adjusted, I think...)
Rudgers73 is offline   Reply With Quote
Old 04-15-2013, 11:46 AM   #4
Danielreadams
Member#: 319021
2006 2.5i wagon
Hmm, ok anywhere I can get that info? It's sort of difficult to google this info, believe me, that's where I would normally go, I'm not lazy
Old 04-15-2013, 12:51 PM   #5
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
Should be like you said; swap the TC and the clutch/flywheel and toss it in. I would swap the intake/wiring from your stock engine just in case there is any difference in sensors and such. No repinning or anything would be necessary since you're not swapping ECUs or anything like that.
cal_look_zero is offline   Reply With Quote
Old 04-15-2013, 01:31 PM   #6
Danielreadams
Member#: 319021
2006 2.5i wagon
Ok thanks, I will swap the intake, put it together, and see how it runs.
Old 04-19-2013, 02:55 PM   #7
s00bn00b
Member#: 188956
2006 Impreza Wagon
Please keep this thread up to date. I'm in the same position you are in.
I've found some manual engines and some automatic engines.
The automatics are cheaper and lower mileage. I'm currently debating whether or not I should just shell out the extra money for the manual and risk the mileage.
So far the list of things to change stands at:
- Remove Torque Converters
- Re-use or replace clutch and flywheel from outgoing engine (manual)
- Re-use intake manifold from outgoing engine (manual)
- Re-use wiring from outgoing engine (manual)
Anything else? Links to other literature? I'm not lazy, just unlucky when it comes to research.
s00bn00b is offline   Reply With Quote
Old 04-19-2013, 03:20 PM   #8
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
Hopefully nobody is swapping the torque converter, since manuals don't have one...
Old 04-19-2013, 03:32 PM   #9
s00bn00b
Member#: 188956
2006 Impreza Wagon
Yeah I was 98% sure on that one. Figured it was easier to ask a stupid question than make a stupid mistake.
